Auto. engine >> vertical shaft power output
Old June 1st 05, 12:00 AM
Default Auto. engine >> vertical shaft power output
Anybody know of a bolt on device to get a vertical shaft output from a
100+ HP auto. engine? No transmission.
Current options:
1. A RWD car with IRS. Turn IRS 90 degrees and block one IRS output
shaft from turning.
Problem: Transmission weight and "crude" design.
2. Shaft drive motorcycle - turn the rear wheel axel shaft 90 degrees
to give a vertical shaft power output.
Old June 1st 05, 02:08 PM
Vaughn Simon
Current options:
shaft from turning.
3) Modify an auto engine to use a dry oil sump, run with crank
vertical.
4) Use an engine from a large outboard motor.
Old June 2nd 05, 02:13 PM
Steve R.
"Vaughn Simon" wrote in message
Didn't B.J. Schramm try that in his early Rotorway designs? Wasn't too
successful from what I remember reading about. Of course, they do have the
modern 4-stroke outboards around these days. Might do better?
Fly Safe,
Steve R.
Are you gliding when you touch down? John Doe Piloting 29 January 23rd 05 01:52 AM
more radial fans like fw190? jt Military Aviation 51 August 28th 04 05:22 AM
Dennis Fetters Mini 500 EmailMe Home Built 70 June 21st 04 10:36 PM
Autorotation ? R22 for the Experts Eric D Rotorcraft 22 March 5th 04 07:11 AM
Corky's engine choice Corky Scott Home Built 39 August 8th 03 05:29 AM
