Blackburn Iris
Old October 29th 20, 05:57 AM posted to alt.binaries.pictures.aviation
Miloch
Default Blackburn Iris
https://en.wikipedia.org/wiki/Blackburn_Iris
The Blackburn Iris was a British three-engined biplane flying boat of the 1920s.
Although only five Irises were built, it wasused as a long-range maritime
reconnaissance aircraft by the Royal Air Force, where it equipped a squadron for
four years, being used to carry out a number of notable long-distance flights.
The final version of the Iris, the Iris Mark V was developed into the aircraft
that replaced it in Squadron service, the Blackburn Perth.
Development and design
In 1924, the British Air Ministry issued Specification R.14/24 for a long-range
reconnaissance flying boat for the Royal Air Force. To meet this requirement,
Blackburn Aircraft proposed the R.B.1 (Reconnaissance Biplane 1), designed by
Major John Douglas Rennie, who as Chief Technical Officer worked with John Cyril
Porte at the Seaplane Experimental Station, Felixstowe.
The R.B.1 was a three-engined, three-bay biplane. The equal-span wings were of
mixed wood-and-metal construction, with ailerons fitted to both upper and lower
wings and floats fitted under the wingtips, while the aircraft had a large
biplane tail (with a span of 30 ft (9.14 m)) with three fins and rudders. The
aircraft's hull had a wooden structure covered in plywood, with a V-bottom with
two steps to give good water handling. Three 650 hp (485 kW) Rolls-Royce Condor
III water-cooled V12 engines driving four-bladed propellers were mounted in
individual nacelles between the wings. It carried a crew of five, with two
pilots sitting side by side in a cockpit forward of the wings, with nose and
dorsal gun positions mounting Lewis guns on Scarff rings, with provision for a
further two guns which could be operated through portholes in the rear fuselage.
Bomb racks under the wings could carry up to 1,040 lb (470 kg) of bombs.
The prototype R.B.1, with the designation Iris I, and with the serial number
N185, made its maiden flight from Blackburn's factory at Brough on 19 June 1926,
being delivered to the Marine Aircraft Experimental Establishment at Felixstowe
the next day, being fully tested during July and August. Wooden hulls were prone
to soaking up large quantities of water (which could amount
to several hundred pounds in additional weight) when kept afloat for long
periods of time, so Rennie designed an all-metal hullfor the Iris, constructed
of duralumin before the Iris first flew. N185 returned to Brough in March 1927
when it was fitted with the new metal hull, together with more powerful engines
and an additional gunner's position in the tail, becoming the Iris II.
On 12 August 1927, shortly after being redelivered, the Iris II started, along
with the prototype Short Singapore I, an experimental metal-hulled Supermarine
Southampton, and the prototype wooden-hulled Saunders Valkyrie (a direct
competitor to the Iris), a 3,000 mi (4,800 km) tour of Scandinavia and the
Baltic. The Iris performed well on the tour, particularly compared to the
Valkyrie, which suffered much heavier water soakage than expected as well as
engine problems, and the Air Ministry issued Specification R.31/27 for an
improved version of the Iris, to act as a long-range supplement to the smaller
Southampton
Role
Flying Boat
National origin
United Kingdom
Manufacturer
Blackburn Aircraft
Designer
John Douglas Rennie
First flight
18 June 1926
Introduction
1929
Retired
1934
Primary user
Royal Air Force
Number built
5
Variants
Blackburn Perth
Operational history​
On 4 February 1928, a contract was placed for three Iris III aircraft, similar
to the Iris II but with fabric-covered metal wings. The Iris II, meanwhile,
continued in use, setting out on another long-range cruise on 27 September,
carrying Sir Philip Sassoon, the Under-Secretary of State for Air and Air
Commodore Sir Arthur Longmore on a tour of RAF Stations of the Mediterranean and
Middle East. It reached Karachi on 14 October, finally returning to RAF Calshot
on 14 November, having flown a total distance of 11,360 mi (18,290 km) with a
flight time of 125 hr 5 min.
The first Iris III flew on 21 November 1929, with the three Iris IIIs equipping
No. 209 Squadron which reformed at RAF Mount Batten, Plymouth in January 1930.
209 Squadron continued the pattern of long-range flights carried out by the Iris
II, with one Iris visiting Reykjavík in June 1930 to celebrate the 1,000th
anniversary of the Icelandic Althing (parliament), and another making the first
crossing of the Bay of Biscay by flying boat when visiting Lisbon in August
1930.
The first Iris III was destroyed in a fatal crash on 4 February 1931, killing
nine of twelve aboard, when the pilot misjudged a landing approach over a
glassy-smooth Plymouth Sound. A replacement was ordered. Although still an Iris
III, this had a number of changes, being fitted with provision to carry a COW 37
mm gun in its bow. The weight of the Iris had grown considerably since the Iris
I, and it was decided to replace the Iris III's Condors with more powerful (825
hp (615 kW) Rolls-Royce Buzzard engines to restore performance and improve
reliability, with the three re-engined aircraft re-entering service in 1932 as
the Iris V.
The Iris II was also re-engined, being fitted with three 800 hp Armstrong
Siddeley Panther radial engines, with the centre engine in a pusher
configuration to become the Iris IV.
An Iris III S1263 of 209 Squadron, Mount Batten, sank following collision with
dockyard launch after landing in Plymouth Sound; 12 Jan 1933; of 9 airmen, 1
drowned and 7 injured
The Iris Vs were replaced in squadron service in 1934 by the Blackburn Perth,
four very similar Buzzard-powered aircraft closely based on the Iris. One of the
Iris Vs was converted for use as a testbed for the Napier Culverin, a
licence-built Junkers Jumo 204 diesel engine, flying in this form in June 1937
and continuing flight trials until April 1938.
Specifications (Iris III)
General characteristics
Crew: 5
Length: 67 ft 4.75 in (20.5423 m)
Wingspan: 97 ft 0 in (29.57 m)
Height: 25 ft 6 in (7.77 m)
Wing area: 2,461 sq ft (228.6 m2)
Empty weight: 19,301 lb (8,755 kg)
Max takeoff weight: 29,489 lb (13,376 kg)
Fuel capacity: 906 imp gal (1,088 US gal; 4,119 l) in 3 tanks above each engine
Powerplant: 3 × Rolls-Royce Condor IIIB V-12 water-cooled piston engines, 675 hp
(503 kW) each
Propellers: 4-bladed fixed-pitch propellers
Performance
Maximum speed: 118 mph (190 km/h, 103 kn)
Endurance: 4 hours 54 minutes
Service ceiling: 10,600 ft (3,200 m)
Rate of climb: 630 ft/min (3.2 m/s)
Wing loading: 11.8 lb/sq ft (58 kg/m2)
Power/mass: 0.0699 hp/lb (0.1149 kW/kg)
Armament
Guns: 3 × .303 in (7.7 mm) Lewis guns, 1 mounted forward and two aft in open
cockpits
Bombs: Up to 2,000 lb (910 kg) of bombs
Blackburn Iris pics 2 - The Blackburn Iris Mk III, S1263, before conversion to a Mk V.jpg ... Miloch Aviation Photos 0 March 30th 18 12:02 PM
Blackburn Iris pics 2 [7/9] - LAUNCH OF A NEW BLACKBURN 'IRIS'.jpg (1/1) Miloch Aviation Photos 0 March 30th 18 12:01 PM
Blackburn Iris pics 2 [5/9] - FIFTH AND LATEST The Blackburn Iris 'family'.jpg (1/1) Miloch Aviation Photos 0 March 30th 18 12:01 PM
Blackburn Iris pics [11/11] - Blackburn 'Iris' metal flying-boat.jpg (1/1) Miloch Aviation Photos 0 March 30th 18 11:59 AM
Blackburn Iris pics [07/11] - Blackburn 'Iris' flying-boat with Rolls Royce 'Condor' engines.jpg (1/1) Miloch Aviation Photos 0 March 30th 18 11:59 AM
