What about putting aluminum foil on your antenna?
Old June 16th 05, 06:05 AM
John Wier
Default What about putting aluminum foil on your antenna?
Doesn't putting aluminum foil on your TV's antenna (rabbit ears) help
reception by catching more rays? So in a composite airplane, with the
antenna inside the fuselage, what about putting some foil on it to
catch radio rays better?
Old June 16th 05, 06:22 AM
Pete Schaefer
Certainly. It also improves the odds of intercepting extraterrestrial
communications traffic.
For best results, you need to cover your entire head with tin foil, too.
This helps reject cosmic radiation, improving your signal-to-noise ratio.
"John Wier" wrote in message
Old June 16th 05, 03:01 PM
John Wier
On Wed, 15 Jun 2005 22:22:40 -0700, "Pete Schaefer"
Now I'm sure there isn't a reader on this site that at one time didn't
try putting foil on their rabbit ears back before we had cable and
satellite tv. And it seemed to help. We were in effect making dish
antenna's of sorts. So we could grab more radio beams if we put some
foil in our aircraft antenna's
Old June 16th 05, 03:26 PM
I used aluminum foil for a ground plane....
http://www.bowersflybaby.com/stories/ground_plane.JPG
Covered it with wood-grained contact paper.
Old June 16th 05, 03:03 PM
John Wier
Old June 16th 05, 03:15 PM
Darrel Toepfer
You put too much foil, its doubling your transmissions... G
There is the rule of size in that bigger is always better. I believe
your application fits reception. Our government has applied the rule to
operational budgets...
Old June 16th 05, 03:29 PM
John Wier
On Thu, 16 Jun 2005 09:15:59 -0500, Darrel Toepfer
Oh! I never thought about transmissions, I was just concerned with
improving reception. Good catch!
I bought one of Bob Archers antenna's from ACS, and it's nothing but
flat aluminum sheet cut to some wierd shape. So we can save that money
by just putting foil on a plain old whip antenna. Is it possible to
have one small antenna for transmissions and another with foil for
receiption? Using a splitter of sorts?
Old June 16th 05, 04:08 PM
Darrel Toepfer
Toggle switch? If everybody had Escort II's like Ron and me, that
wouldn't be an issue as they support 2 antennas right out the box...
I've saved all of my gum wrappers since I started chewing. If there a
simple method of joining them together conductively? And is trimming it
as simple as just folding it or should I wack it?
Old June 16th 05, 04:06 PM
John Wier
I'm thinking about using diodes and a splitter for transmitting on one
small antenna and recieving on the big foil one.
Old June 16th 05, 04:16 PM
Darrel Toepfer
Good one, transmitter rhymes with splitter, so that has to work...
Welding machines have those big honk'n ones with large amounts of
aluminum surface. Bigger/better...
I Hate Radios Ron Wanttaja Home Built 9 June 6th 05 05:39 PM
Foil Antenna on Carbon Fiber Dennis Mountains Home Built 7 April 24th 04 12:54 AM
Fixing the Transponder with Duct Tape and Aluminum Foil Ron Wanttaja Home Built 45 March 14th 04 12:18 AM
Ext antenna connection for handheld radio Ray Andraka Owning 7 March 5th 04 01:10 PM
Foil antenna and carbon fiber BD5ER Home Built 11 August 6th 03 04:44 AM
