Master Switch
Old July 18th 05, 02:57 PM
Lakeview Bill
Default Master Switch
On an aircraft with separate "battery" and "alternator" switches, should you
turn on BAT and leave ALT off during engine start, or should you turn them
both on prior to start?
A little bit of the "why" on this would be nice also...
Old July 18th 05, 03:16 PM
Jose
I leave alt off during start, to prevent a power surge from going
through the alternator. Part of my checklist in several places is to
ensure that the switch is set on both before takeoff (it's easy to forget!)
Jose
Nothing takes longer than a shortcut.
Old July 18th 05, 03:28 PM
JohnH
should you turn on BAT and leave ALT off during engine start, or
should you turn them both on prior to start?
What would be the source of this surge? If it's such a problem, why don't
automobiles have alternator switches?
The only reason I could come up with having an alternator switch is to make
it easy to pull offline in case of a problem.
Old July 18th 05, 06:04 PM
Jose
I don't know. But there is an avionics master also, and it is off when
I start the engine for the same reason. Cars don't have that either.
Jose
Old July 18th 05, 06:22 PM
Gig 601XL Builder
"Jose" wrote in message
don't automobiles have alternator switches?
I don't know. But there is an avionics master also, and it is off when I
Yeah, they do. it's just automatic. Same may go for the alternator.
Old July 18th 05, 09:12 PM
Casey Wilson
My '97 Chev. Lumina has an avionics cut-out switch for starting. Come to
think of it, so does my '96 GMC Sonoma pickup.
Old July 19th 05, 01:10 AM
Dave Stadt
"JohnH" wrote in message
Many do but it is automatic. They don't power the buss for a second or two
after start to allow the alternator circuit to stabilize.
Old July 18th 05, 03:42 PM
Larry Dighera
On Mon, 18 Jul 2005 12:57:42 GMT, "Lakeview Bill"
wrote in
Of course, you should follow the starting procedure stated in the POH.
That usually has you turning on the alternator field winding after the
engine starts. Energizing the field winding causes about a 5 ampere
current draw. That five amps is better used for turning the starter
motor until the alternator is able to spin fast enough to produce
useable electrical output current.
Old July 18th 05, 05:25 PM
I was told the same thing from a UPS pilot friend of mine. While the
current draw to energize the alternator field is minimal it could make
a difference on a cold day(?) Just don't forget to hit the ALT switch
after engine start and verify the draw on the amp gauge.
Old July 18th 05, 07:23 PM
Maule Driver
It's a great little nugget of knowledge to have if you've let your
battery age to the point where it just barely starts you up. You can
get one or two more starts by knowing to keep it off during the crank.
Worked for me at a time of great need!
What does REC mean on the switch? Jose Piloting 10 June 15th 05 06:55 AM
C-172 landing light switch JFLEISC Piloting 16 May 6th 04 02:15 AM
C-172 landing light switch JFLEISC Owning 10 May 6th 04 12:05 AM
C172SP engine start with battery switch only? Robert Winn Piloting 8 April 13th 04 01:31 AM
ANG Woman Wing Commander Doesn't See Herself as Pioneer, By Master Sgt. Bob Haskell Otis Willie Military Aviation 0 March 18th 04 09:40 PM
