homemade EFIS system and EMI
Old January 25th 05, 09:06 PM
jcpearce
Default homemade EFIS system and EMI
As a pet/learning project I made a data aquisition unit using an 8051
microprocessor and an EPIA M motherboard running a variant of Linux to
process and display the information. It all works but the EMI from the
EPIA M causes way too much noise to the aircraft radios. I have tried
shielding the whole device in an aluminum case with very little
improvement.
Any ideas on how to smother the EMI or some other small motherboard
which may not have as much an issue (as a test I took my portable
aviation radio and within 6' of any my home computers the same occurs
which gives me little hope)
Thanks
Old January 25th 05, 10:30 PM
Peter
improvement.
Physically separate the offender from the victim, especially the point of
entry of the signals into the victim. Don't forget about coax cables, comm
antenna and things like that, not just the radio box. You could try
reorienting the motherboard 90 degrees in various axis.
Old January 26th 05, 12:36 AM
jcpearce
This is without the system connected to any of the sensors, just
turning it on and with an external battery so it is physically isolated
but within 6' or so it causes interference. Rotating the motherboard
does not help either. Thanks for the reply.
Old January 26th 05, 12:57 AM
Blueskies
"jcpearce" wrote in message oups.com...
I have the same problems with my desktop machine and handheld radio...Wrap with aluminum foil and see what happens...
Old January 26th 05, 03:23 AM
UltraJohn
isolatedseparateithin 6' or so it causes interference. Rotating the
motherboard
Possibly try remotely mounting it back in the fusilage and running
fiberoptic to it. You can get inexpensive hobby FO and FO to rs232 modules
designed for experimenting.
Other than that try a non-aluminum case and use feed thru caps on all leads
and ferrite beads also. try some additional filtering on the PS and/or try
using separate PS for processor.
Just some thoughts.
John
ps those hobby aluminum cases do lousy for rfi prevention!
Old January 26th 05, 06:14 AM
kumaros
improvement.
Thanks
You obviously are knowledgeable in the
subject, but have you tried the simple
stuff first, like ferrite doughnuts on
all cables to and from the boards and
grounding one side of cable shielding etc.?
It sounds like a very interesting
project, do you have a site for more info?
Kumaros
It's all Greek to me
Old January 26th 05, 02:12 PM
Bob
The "noise" could be coming through the connector and could be emitting
from the wires.
Try using a connector with a metal housing and backshell and wires with
shields, terminate the shields to the connector backshell/housing which
will ground to the chassis.
The other end of the wires, try to terminate their shields where they
connect to.
Aircraft environment is not the same as home environment. Different
applications different techniques.
to
improvement.
Thanks
Old January 26th 05, 04:44 PM
jcpearce
Thanks for the suggestions, no I have not posted what I did anywhere
but I think I will as it took me a little while to learn rudimentary
assembly, come up with a variant of linux running off flash memory,
write the code to process the serial output and display etc..
I did not use a hobby aluminum case, I custom built one with no gaps
(motherboard has a temperature sensor so I could check this for
possible overheating) and this was grounded. Without hooking up the
data aquisition card and just powering up the EPIA M in the seperate
aluminum case with no connections of any kind to the airplane I get the
interference in the radio. There are no connections coming out of the
aluminum box except for power and this line has caps on it for
filtering.
So it is coming solely from the motherboard, some chip on the board is
oscillating in the 107~130 Mhz range, given this occurs against one
home computer running at 2Ghz, another at 2.4 Ghz and the EPIA and 500
Mhz I would guess it is some supporting chip, but even if I knew I am
not sure that would do me much good. Perhaps changing the aluminum case
to a different size/shape would catch the offending frequency but I am
in the dark here and would be shooting in the dark.
There only seems two generic routes,
A) find a small computer which does not emit these frequencies (but I
do not know what is emmiting them so I would not know which computer
choice would alleviate this)
B) Some vastly better shielding approach for the motherboard.
Ideas?
Thanks
emitting
from the wires.
with
which
connect to.
8051
to
tried
improvement.
occurs
Thanks
Old January 27th 05, 03:06 PM
AINut
Look up info on "Tempest" PC's. Lots of good methods for RFI suppression.
filtering.
Ideas?
Thanks
emitting
from the wires.
with
which
connect to.
8051
to
tried
improvement.
occurs
Thanks
Old January 27th 05, 03:13 PM
Bob
Some IMPRESSIVE experience in this group.
I have not heard "tempest" in years.
But again, in my experience, if you've got a metal box already. It's
most likely the connector and harness.
Carry those grounds (on the harness shields) through!
suppression.
anywhere
rudimentary
gaps
seperate
filtering.
is
500
am
case
am
I
computer
Ideas?
Thanks
emitting
from the wires.
with
which
they
connect to.
Different
8051
Linux
to
tried
improvement.
motherboard
occurs
Thanks
