Jim, I like some of the PDA based nav software (TeleType, Control Vision),
but can't live with the tiny little screens on a PDA. And a nice little subnotebook computer--even used--is outrageously expensive. J.C. Whitney sells a Pyramid 7" TFT/LCD monitor for DVD or Videocassette players (System: NTSC. Video input: composition video signal.) $150. Will this kind of monitor work with a cheap laptop computer? Thanks. |
That is outside my field of expertise. Any bit twiddlers in here care to
respond? Jim "John S" wrote in message k.net... Jim, I like some of the PDA based nav software (TeleType, Control Vision), but can't live with the tiny little screens on a PDA. And a nice little subnotebook computer--even used--is outrageously expensive. J.C. Whitney sells a Pyramid 7" TFT/LCD monitor for DVD or Videocassette players (System: NTSC. Video input: composition video signal.) $150. Will this kind of monitor work with a cheap laptop computer? Thanks. |
RST Engineering wrote:
"John S" wrote... Jim, I like some of the PDA based nav software (TeleType, Control Vision), but can't live with the tiny little screens on a PDA. And a nice little subnotebook computer--even used--is outrageously expensive. J.C. Whitney sells a Pyramid 7" TFT/LCD monitor for DVD or Videocassette players (System: NTSC. Video input: composition video signal.) $150. Will this kind of monitor work with a cheap laptop computer? That is outside my field of expertise. Any bit twiddlers in here care to respond? Dual output laptops (notebooks) use SVGA/SVideo, so you'd have to convert SVideo or SVGA to NTSC composite to be compatible. The dual output allows you to have basically 2 desktops, an extension of your current desktop or mirror the desktop to both displays... |
However, be careful of RFI noise that some LCD's create in the aviation
band. Darrel Toepfer wrote: RST Engineering wrote: "John S" wrote... Jim, I like some of the PDA based nav software (TeleType, Control Vision), but can't live with the tiny little screens on a PDA. And a nice little subnotebook computer--even used--is outrageously expensive. J.C. Whitney sells a Pyramid 7" TFT/LCD monitor for DVD or Videocassette players (System: NTSC. Video input: composition video signal.) $150. Will this kind of monitor work with a cheap laptop computer? That is outside my field of expertise. Any bit twiddlers in here care to respond? Dual output laptops (notebooks) use SVGA/SVideo, so you'd have to convert SVideo or SVGA to NTSC composite to be compatible. The dual output allows you to have basically 2 desktops, an extension of your current desktop or mirror the desktop to both displays... |
RST Engineering wrote: "John S" wrote... Jim, I like some of the PDA based nav software (TeleType, Control Vision), but can't live with the tiny little screens on a PDA. And a nice little subnotebook computer--even used--is outrageously expensive. J.C. Whitney sells a Pyramid 7" TFT/LCD monitor for DVD or Videocassette players (System: NTSC. Video input: composition video signal.) $150. Will this kind of monitor work with a cheap laptop computer? That is outside my field of expertise. Any bit twiddlers in here care to respond? Dual output laptops (notebooks) use SVGA/SVideo, so you'd have to convert SVideo or SVGA to NTSC composite to be compatible. The dual output allows you to have basically 2 desktops, an extension of your current desktop or mirror the desktop to both displays... I think there are some laptops around with composite video output, a couple years ago we had some P-3 Dells at work with it I'm sure. Composite is the one with a single yellow connector, right? (The same type of connectors colored white and red are optional left and right stereo sound.) My desktop computer has all 3 (VGA, S-Video, and composite) inputs and outputs. I know, the original question is for laptops. Since a key part of the question is "cheap," it might take some shopping around. I think there are inexpensive S-video to composite adapters made too. |
Jim Carriere wrote:
Composite is the one with a single yellow connector, right? (The same type of connectors colored white and red are optional left and right stereo sound.) My desktop computer has all 3 (VGA, S-Video, and composite) inputs and outputs. I know, the original question is for laptops. CGA was easy to port to NTSC and RGB. VGA/SVGA took more hardware... Most everything (cheap) is now Svideo only. To get the dual desktops, does take a special videocard (chipset)... |
Jim Carriere wrote:
Darrel Toepfer wrote: RST Engineering wrote: "John S" wrote... Jim, I like some of the PDA based nav software (TeleType, Control Vision), but can't live with the tiny little screens on a PDA. And a nice little subnotebook computer--even used--is outrageously expensive. J.C. Whitney sells a Pyramid 7" TFT/LCD monitor for DVD or Videocassette players (System: NTSC. Video input: composition video signal.) $150. Will this kind of monitor work with a cheap laptop computer? That is outside my field of expertise. Any bit twiddlers in here care to respond? Dual output laptops (notebooks) use SVGA/SVideo, so you'd have to convert SVideo or SVGA to NTSC composite to be compatible. The dual output allows you to have basically 2 desktops, an extension of your current desktop or mirror the desktop to both displays... I think there are some laptops around with composite video output, a couple years ago we had some P-3 Dells at work with it I'm sure. Composite is the one with a single yellow connector, right? (The same type of connectors colored white and red are optional left and right stereo sound.) My desktop computer has all 3 (VGA, S-Video, and composite) inputs and outputs. I know, the original question is for laptops. Since a key part of the question is "cheap," it might take some shopping around. I think there are inexpensive S-video to composite adapters made too. I'm typing from a computer that has composite out. Most Toshiba notebooks have them. I have the Satellite model. Unfortunately, it's useless for anything other than the DVD display as the text is completely unreadable on the TV out. |
Ernest Christley wrote:
Jim Carriere wrote: Darrel Toepfer wrote: "John S" wrote... Jim, I like some of the PDA based nav software (TeleType, Control Vision), but can't live with the tiny little screens on a PDA. And a nice little subnotebook computer--even used--is outrageously expensive. J.C. Whitney sells a Pyramid 7" TFT/LCD monitor for DVD or Videocassette players (System: NTSC. Video input: composition video signal.) $150. Will this kind of monitor work with a cheap laptop computer? Since a key part of the question is "cheap," it might take some shopping around. I think there are inexpensive S-video to composite adapters made too. I'm typing from a computer that has composite out. Most Toshiba notebooks have them. I have the Satellite model. Unfortunately, it's useless for anything other than the DVD display as the text is completely unreadable on the TV out. TV CRT screens are much lower quality than computer video screens. I guess the same must apply to DVD players. Also, NTSC (and PAL and other TV standards) are analog and designed for low bandwidth, so you're never going to get that really sharp picture that you see on a laptop. OTOH, perhaps you don't need a really sharp picture... careful use of colour and graphics (eg bar graphs that change to red to indicate dangerous values and the like) might be usable to impart information. Perhaps also some clever use of sound too? |
On Wed, 02 Feb 2005 15:07:52 GMT, "John S"
wrote: Jim, I like some of the PDA based nav software (TeleType, Control Vision), but can't live with the tiny little screens on a PDA. And a nice little subnotebook computer--even used--is outrageously expensive. J.C. Whitney sells a Pyramid 7" TFT/LCD monitor for DVD or Videocassette players (System: NTSC. Video input: composition video signal.) $150. Will this kind of monitor work with a cheap laptop computer? You will need an SVGA to NTSC converter to solve this problem. I am not sure of the cost of commercial solutions, nor the chipsets to roll your own. There may be issues with losing portions of the screen. Ie, you may lose the bottom and right portions of the screen in this setup. Before you jump into building this LCD + laptop setup, I relate my story as I went through the same hoops you are trying to get through. Background: I run moving map software as a secondary navigational tool in my Cherokee 180. The computing platform has always been a Windows based PC. I started off using a laptop in the cockpit, and got my first realization of how much the cables are a pain in the cockpit. Worse, the display is dim, washed out by the smallest amount of daylight. It also did not have a contrast/brightness control, which made it overwhelming at night. As well, the only place to put it in a single is on the passenger seat. Fine if you are solo. Bad if you have passengers. So I moved the laptop to the backseat and bought a touchscreen VGA monitor with approx 8" diagonal viewing area. This unit was about $300 used on eBay. Again, brightness was my enemy. You don't realize how much of a greenhouse the aircraft cabin is until you try do some computing up there... It takes a LOT of nits to give a good display in the daylight. Also, this setup brought to light another issue. What do you do when the touchscreen isn't enough. Ie, when the inevitable Ctrl-Alt-Del comes along or a full system reboot. Turning on the autopilot and reaching into the backseat did not seem like a safe solution, so eventually I abandoned it completely. I ended up purchasing a Fujitsu ST4121 tablet PC. This tablet PC has a transflective display, which allows sunlight to pass through the LCD, hit the reflector behind the display, and then act as a backlight for the LCD. The end result, it is sunlight readable. The colors wash out a bit, ie, the particular shades of colors blend together, but the base colors are distinguishable. You would not mistake red for blue for green for black... The PC is NOT touchscreen, it has a stylus as input, but my moving map software only rarely requires keyboard input, so that is not as big an issue for me as perhaps others... Anyway, I'm really happy with the ST4121, and I would encourage anyone else to give it a go. The ST4121 is also a very capable PC (933MHz + 512MB + 60G HDD), so I use it outside of the plane as well. If you want to have a look at my setup and are in the Chicago area, I'm sure we can arrange for a breakfast at Morris, Clow, or elsewhere. -Nathan |
"Nathan Young" wrote in message ... On Wed, 02 Feb 2005 15:07:52 GMT, "John S" wrote: You will need an SVGA to NTSC converter to solve this problem. I am not sure of the cost of commercial solutions, nor the chipsets to roll your own. There may be issues with losing portions of the screen. Ie, you may lose the bottom and right portions of the screen in this setup. In my experience with these converters, you will also lose significant resolution. In my case, it was so bad that some text was difficult to read. Vaughn |
| Thread Tools | |
| Display Modes | |
| RG Battery Charger by Jim Weir in Kitplanes | Kevin O'Brien | Home Built | 4 | January 6th 05 02:19 AM |
| SWRFI update... Moving again (argghh!!)... | Dave S | Home Built | 14 | October 15th 04 04:34 AM |
| Aircraft Builders Mailing List is moving. | Gil G. | Home Built | 0 | May 10th 04 06:28 PM |
| Engine moving day... | Gene Z. Ragan | Home Built | 2 | March 16th 04 02:26 AM |
| Jim Weir and radio racks | Matthew M. Jurotich | Home Built | 4 | November 13th 03 04:51 AM |
