Cockpit Audio wiring (hyjacked from "gear warning")
Old November 18th 05, 01:42 AM posted to rec.aviation.soaring
Default Cockpit Audio wiring (hyjacked from "gear warning")
"Mike Lindsay" wrote in message
In article DdqdnYPHoYf1J-benZ2dnUVZ_v
Snip-------
We put in a new vario this year, the only snag was we had
nowhere to put the speaker except behind the panel. We thought we could
do with a bit more audio. I remembered our radio, a Dittel clone, has an
input for an intercom. We fed the audio from the vario into the radio,
and now we have all the volume we need.
Mike Lindsay
Mike, that's interesting. Did the radio squelch the vario audio when
transmitting and receiving?
A quick check of my Microair 760 manual shows that Pin 14 is "Music in" on
the DB15 connector. Now, I'm not going to connect a $1000 vario to a $1000
radio without some specific guidance from the respective manufacturers but
that's a cool idea. The audio from the little pizeo squeekers that come
with the Borgelt instruments isn't that great (Even Mike B suggests that
there are better speakers.) and it would be nice to squelch the vario audio
when using the radio.
Bill Daniels
Old November 18th 05, 08:55 PM posted to rec.aviation.soaring
"and it would be nice to squelch the vario audio
when using the radio. "
Why?? One of the great pleasures of cross country is to key the mic
from a 10k thermal when you know your competitors looking at the dirt.
Andy
Old November 18th 05, 09:47 PM posted to rec.aviation.soaring
"Andy" wrote in message
oups.com:
Andy
Exactly, Andy!!!
How many times have you postponed a radio call a few seconds until you
were in the "hot" side of the thermal so everyone could hear a faster
pitched audio vario? ;-)
Larry
Old November 19th 05, 04:24 AM posted to rec.aviation.soaring
If cutting the vario when the mic is keyed is the objective, could the
PTT be wired to cause a relay to open the vario speaker circuit? Then
the technique could be used with any radio?
Old November 19th 05, 06:03 PM posted to rec.aviation.soaring
Sure! I'd suggest using a small DPDT ("double pole, double throw") relay
(check Radio Shack) behind the panel. One set of contacts would key the
radio; the other set of contacts would open the lead to the vario speaker.
The coil would be driven by the PTT switch. A 12 volt coil would work as
long as it closes with 10 volts or less, because you don't want the
radio to stop working just because you can't key it. If you are
concerned about this, you could mount a PTT switch on the panel that is
in parallel with the contacts to the radio, for use if the relay fails.
You might have to use a relay with a lower voltage coil and use a
resistor in series with it, or carefully adjust the metal tab holding
the contact spring.
A small diode should be placed across the coil to protect the PTT
contacts. Connect the diode so current does not flow through it when the
PTT is keyed; i.e., the band on the diode body should connect to the
positive side of the coil.
Undoubtedly, your club has a member that can assist you, if needed.
Eric Greenwell
Washington State
USA
Old November 19th 05, 06:24 PM posted to rec.aviation.soaring
Eric Greenwell wrote in
the PTT be wired to cause a relay to open the vario speaker circuit?
Then the technique could be used with any radio?
relay (check Radio Shack) behind the panel. One set of contacts would
key the radio; the other set of contacts would open the lead to the
vario speaker.
as long as it closes with 10 volts or less, because you don't want the
is in parallel with the contacts to the radio, for use if the relay
fails. You might have to use a relay with a lower voltage coil and use
a resistor in series with it, or carefully adjust the metal tab
holding the contact spring.
the PTT is keyed; i.e., the band on the diode body should connect to
the positive side of the coil.
You could also use a DPDT PTT switch on the stick to control both
functions. A SPST PTT switch with both NO and NC contacts would probably
do the job, too. This would eliminate the relay and diode and the extra
complication and current draw, reducing potential failure points at the
expense of routing more wires to the PTT. KISS. :-)
-Bob Korves
Old November 19th 05, 05:42 PM posted to rec.aviation.soaring
"01-- Zero One" wrote in message
oups.com:
Andy
Exactly, Andy!!!
How many times have you postponed a radio call a few seconds until you were
in the "hot" side of the thermal so everyone could hear a faster pitched
audio vario? ;-)
Larry
I get really annoyed with endless "vario reports". Everybody in the air
probably already knows the typical thermal strengths and, if they aren't
playing with the radio, they've probably already cored a better thermal.
If you want to play with radios, get a HAM license.
The glider frequencies are so congested that it's often hard to hear really
important messages. If I am going to transmit, I want a clear, quiet
channel so I don't have to repeat the transmission. A pilot shouldn't be
forced to use a cellphone to contact his crew.
Squelching the vario audio is a good thing since a loud vario in the
background can saturate the transmitter and garble the message. Mixing the
vario audio through the radio takes advantage of a much better amplifier and
speaker than the vario has.
Bill Daniels
Old November 19th 05, 09:48 PM posted to rec.aviation.soaring
The only disadvantage of this idea that I can see is that you loose the
vario sound if you turn the radio off or down to get rid of annoying
chatter.
For that reason alone I prefer the idea of a separate audio amp with
inputs for the radio and vario (and warning horns?).
martin@ | Martin Gregorie
gregorie. |
org | Zappa fan & glider pilot
Old November 19th 05, 10:38 PM posted to rec.aviation.soaring
"Martin Gregorie" wrote in message
chatter.
Any ideas on where to get one?
Bill Daniels
Wiring cell phone into audio panel Mike Rapoport Owning 1 April 1st 05 12:06 AM
