Primary nav source
Old December 1st 05, 05:03 AM posted to rec.aviation.ifr
Default Primary nav source
The recent GPS/IFR discussions here got me to thinking. I generally fly an
Arrow, equipped with a Garmin 430, 2 VORs, Loran, my handheld GPS, my
sectionals, low enroute charts, and since I got my IFR ticket, I try to fly
under ATC control as often as possible to keep my comm skills up.
On cross county flights, I fiddle with the VORs and cross check my location,
I set the Loran (if it's working that day), etc. In other words, for
navigation, I use everything inside and out the cockpit that is operational.
Which one is considered primary?
Jeff 'The Wizard of Draws' Bucchino
Cartoons with a Touch of Magic
http://www.wizardofdraws.com
More Cartoons with a Touch of Magic
http://www.cartoonclipart.com
Old December 1st 05, 05:25 AM posted to rec.aviation.ifr
In article m,
Your brain.
Old December 1st 05, 05:33 AM posted to rec.aviation.ifr
I fly an Arrow that is equipped with a Garmin 430, King KX-155 nav-com, ADF and
a DME that's crapped out at the moment. I use the GPS as my primary nav radio
for enroute segments and the King for approaches. I generally have the GPS
showing the moving map and feeding one of the OBSs as well. If the GPS were to
go tango uniform on me, I'd just use the King to get myself on an established
victor airway and go from there.
Mortimer Schnerd, RN
VE
Old December 1st 05, 04:09 PM posted to rec.aviation.ifr
Seems to me the primary is related to the route you filed. If you're
flying direct, likely the GPS is primary. If you filed airways,
technically the VOR is primary because the airway is defined by
radials. Even though my 2 VOR's usually agree within 1 degree, The GPS
doesn't give me exactly the same course. Even so, I tend to use the
GPS as primary and use the VORs to check cross bearings. Part of the
reason is that I can enter the flight plan into the GPS and let the
STEC do the work while I monitor traffic and communications.
Old December 2nd 05, 12:55 AM posted to rec.aviation.ifr
Ham Sandwich
Old December 3rd 05, 07:05 PM posted to rec.aviation.ifr
"Robert M. Gary" wrote in message
Ham Sandwich
I can't comment on the legality but I would like to point out from a
historical perspective that the sandwich envisaged in the classic
Travis-Noel 1998 debate (which I believe was its first occurence on
rec.aviation.ifr) was in fact, tuna.
Julian
Old December 3rd 05, 09:12 PM posted to rec.aviation.ifr
If it was Charlie the Tuna, wouldn't it be a ham?
Jose
You can choose whom to befriend, but you cannot choose whom to love.
Old December 3rd 05, 09:21 PM posted to rec.aviation.ifr
Ham Sandwich
Julian
We used to use tuna, but then we discovered that the mercury content
interferes with the GPS signal.
Old December 2nd 05, 01:36 AM posted to rec.aviation.ifr
In article m,
How about this: primary is the one(s) used to meet the requirements
for the particular navigation (a VOR for a VOR approach, the ADF when
flying an NDB approach, IFR GPS when etc etc). Everything else is used for
situational awareness.
Bob Noel
New NHL? what a joke
Old December 2nd 05, 03:36 PM posted to rec.aviation.ifr
On Wed, 30 Nov 2005 23:03:15 -0500, Wizard of Draws
What do *you* mean by "primary"?
I don't see "primary" defined in either 1.1 or the P/CG in the sense of
navigation equipment. However, there is this quote from the AIM which may
be applicable to your situation. Note that the use of GPS as "primary"
(from an FAA point of view) depends on where you are using it:
"...The FAA has granted approval for U.S. civil operators to use properly
certified GPS equipment as a primary means of navigation in oceanic
airspace and certain remote areas. Properly certified GPS equipment may be
used as a supplemental means of IFR navigation for domestic en route,
terminal operations, and certain instrument approach procedures (IAPs). "
Also:
"VFR and hand-held GPS systems are not authorized for IFR navigation,
instrument approaches, or as a primary instrument flight reference. During
IFR operations they may be considered only an aid to situational
awareness."
A Remote Compass- java source [email protected] General Aviation 0 July 3rd 04 07:39 PM
Winscore source code now available Guy Byars Soaring 0 February 5th 04 11:43 AM
Are handheld GPSes becoming a defacto primary nav source? Paul Tomblin Instrument Flight Rules 44 September 13th 03 11:36 PM
OT- north korean nuke weapon plutonium - source? patrick mitchel Military Aviation 11 August 31st 03 05:01 AM
Source for copper crush gaskets??? Jim Owning 0 August 22nd 03 07:31 PM
