12v - 12v charger
Old December 20th 05, 06:15 PM posted to rec.aviation.soaring
Default 12v - 12v charger
I currently charge the (hard to remove) batteries in my ASH-26E with a
solar panel and charger installed on/in my trailer. During a contest,
the plane may not spend much time in the trailer during daylight hours,
but it does spend most nights in there.
The solution would be to use the solar panel to charge a battery in the
trailer, which would then be used to charge the glider overnight. Best
would be to use this system all the time with two chargers in the
trailer and a single cable to hook up to the glider.
So... does anyone know of a charger that will accept 12v input to
charge a 12v/18ah SLA battery? I've found some charger chip
application notes, but I really don't want to build one of these.
Thanks,
-Tom
Old December 20th 05, 07:03 PM posted to rec.aviation.soaring
Hi Tom,
the airplane model builders are using chargers with 12V input.
You best look in Google for a supplier of airplane model equipment
in your aerea.
Walter
Old December 20th 05, 08:09 PM posted to rec.aviation.soaring
http://www.hobby-lobby.com/chargers.htm
I recommend Graupner Ultramat 12
Regards
Udo
Thanks,
-Tom
Old December 20th 05, 09:21 PM posted to rec.aviation.soaring
Thanks - that looks like the ticket. I had thought about RC model
chargers, but thought there might be issues using one on a lead acid
battery for prolonged trickle charging. The specs at the Graupner
website: http://shop.graupner.de/webuerp/servlet/AI?ARTN=6412.67 seem
to indicate this will not be a problem.
-Tom
Old December 20th 05, 11:43 PM posted to rec.aviation.soaring
check on http://www.strobl-solar.de who is specialised in Buffer
Batteries Systems
Regards
Old December 21st 05, 12:33 AM posted to rec.aviation.soaring
Batteries Systems
Very nice, but a bit outside my budget. The Graupner R/C charger is
looking like the best option so far. Now If I could find one with
fewer options - like just works for Lead-Acid the price might be even
better...
-Tom
Old December 24th 05, 05:24 AM posted to rec.aviation.soaring
The combination of a 12V inverter and 120VAC battery charger need not
be inefficient - it is dependent upon the efficiencies of the two
parts.
I am charging my batteries using a solar panel and voltage regulator.
Usually, I can recharge the batteries after landing using the remaining
daylight. If not, it easily recharges in the morning. I use this
combination of solar panel and regulator:
Affordable Solar
PO BOX 12952
Albuquerque, NM 87195-0952
800.810.9939 Toll Free
505.244.1154 Direct
505.244.9222 FAX
Web: www.Affordable-Solar.com
"Independence You can Afford"
Name Code Qty Each Options
Morningstar SunSaver 829 1 69.00
10L-12V Charge Controller
SunWize OEM20, 20 Watt 1142 1 165.00
Solar Panel
Subtotal 234.00
Shipping 25.20
Tax 0.00
Total 259.20
Old December 27th 05, 05:35 PM posted to rec.aviation.soaring
Any thoughts about putting one of these between the storage battery and
a charge controller?
http://store.l-f-l.com/prod/DC-DC-ADAPTER/51F1439494-
What would be the best voltage setting?
-Tom
Old December 28th 05, 10:20 PM posted to rec.aviation.soaring
I assume you are talking about charging your glider battery from a
storage battery, which you charge with a solar panel during the day.
This would probably work with the solar charger I mentioned, but I
offer no guarantees (there is nothing obviously wrong). I would NOT use
this without a charge controller, however. I would experiment with
output voltages to find which one was most efficient. To do this you
will need to measure both discharge current from the storage battery
and charge current into the battery you are charging. You probably can
use 18V safely. Be sure to measure voltages at both batteries to sure
something isn't going wrong (the battery under charge shouldn't measure
more than 15V unless it is cold (I did this when it was 26 deg and it
measured over 15V).
Tom Seim
DG-400
Richland, WA
RG Battery Charger by Jim Weir in Kitplanes Kevin O'Brien Home Built 4 January 6th 05 02:19 AM
Batteries, charger for Yaesu handheld - NiCad or NiMH? David Herman Owning 10 November 7th 04 05:30 PM
'73 Piper Charger Kobra Piloting 2 March 28th 04 05:46 PM
12 Volt DC input Battery Charger Michael I Green Soaring 5 March 14th 04 09:41 AM
Battery Chargers Mike Rapoport Owning 11 December 3rd 03 12:55 AM
