I've spent the past couple of hours researching this in the regs and
newsgroups... and am still a little confused If I require an alternate airport for a IFR Flight plan, does that alternate have to have official weather reporting? I read somewhere that: "The requirements for an airport to qualify for alternate minimums are weather reporting and approach facility (navaid) monitoring" But I also read that I can file an alternate with no approaches and no weather reporting as long as I can descend under Basic VFR from the MEA to the airport (Part 91). What gives? |
"Anthony Chambers" wrote in
: I've spent the past couple of hours researching this in the regs and newsgroups... and am still a little confused If I require an alternate airport for a IFR Flight plan, does that alternate have to have official weather reporting? I read somewhere that: "The requirements for an airport to qualify for alternate minimums are weather reporting and approach facility (navaid) monitoring" But I also read that I can file an alternate with no approaches and no weather reporting as long as I can descend under Basic VFR from the MEA to the airport (Part 91). You can file a destination with no approaches and no weather reporting as long as you can descend VFR. But you have to have a legal alternate to do so. See FAR 91.169, http://tinyurl.com/no9h -- Regards, Stan |
"Stan Gosnell" wrote in message ... You can file a destination with no approaches and no weather reporting as long as you can descend VFR. But you have to have a legal alternate to do so. That's not what he asked. |
"Ron Natalie" wrote in
m: "Stan Gosnell" wrote in message ... You can file a destination with no approaches and no weather reporting as long as you can descend VFR. But you have to have a legal alternate to do so. That's not what he asked. I thought it was. Perhaps I wasn't clear. He can file a destination with no approaches or weather, but he can't file an alternate with no approaches or weather. I think he was confusing destination and alternate requirements. -- Regards, Stan |
"Stan Gosnell" wrote in message ... I thought it was. Perhaps I wasn't clear. He can file a destination with no approaches or weather, but he can't file an alternate with no approaches or weather. I think he was confusing destination and alternate requirements. He specifically asked if the alternate had to have weather reporting. There is no requirement that the alternate have an approach nor is their a strict requirement for "on-field" weather at the alternate. If the forcast is for severe clear with no "chance of" or "probability of" lower than VFR conditions from the MEA down to the ground, it's legal to use that airport as an alternate. |
Unless that airport is one that is not authorized as an alternate. As I understand it, most that don't
have wx reporting are so designated. Ron Natalie wrote: "Stan Gosnell" wrote in message ... I thought it was. Perhaps I wasn't clear. He can file a destination with no approaches or weather, but he can't file an alternate with no approaches or weather. I think he was confusing destination and alternate requirements. He specifically asked if the alternate had to have weather reporting. There is no requirement that the alternate have an approach nor is their a strict requirement for "on-field" weather at the alternate. If the forcast is for severe clear with no "chance of" or "probability of" lower than VFR conditions from the MEA down to the ground, it's legal to use that airport as an alternate. -- --Ray Andraka, P.E. President, the Andraka Consulting Group, Inc. 401/884-7930 Fax 401/884-7950 http://www.andraka.com "They that give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety." -Benjamin Franklin, 1759 |
"Anthony Chambers" wrote in message ... I've spent the past couple of hours researching this in the regs and newsgroups... and am still a little confused If I require an alternate airport for a IFR Flight plan, does that alternate have to have official weather reporting? I read somewhere that: The rule is: (c) IFR alternate airport weather minima. Unless otherwise authorized by the Administrator, no person may include an alternate airport in an IFR flight plan unless appropriate weather reports or weather forecasts, or a combination of them, [600-2, 800-2, or VFR from MEA down as appropriate]. Whether you can glean this from area forcasts in the absence of on-field reporting is up for you to decide (as a non-commercial operator). Airports without weather that have approaches will generally have NA Alternate Minimums. |
| Thread Tools | |
| Display Modes | |
| alternate carb heat | Ray Toews | Home Built | 16 | October 29th 04 01:41 PM |
| Alternate turbine fuel | Robert Bates | Home Built | 24 | June 7th 04 08:16 AM |
| Battery Requirements | jgarner | Home Built | 3 | March 28th 04 07:32 AM |
| NA as alternate...redux | Bob Gardner | Instrument Flight Rules | 1 | September 11th 03 11:26 PM |
| Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 4 | August 7th 03 06:12 AM |
