So you think you have a low glide ratio!
Old January 7th 06, 06:57 PM posted to rec.aviation.soaring
Default So you think you have a low glide ratio!
The January 2006 issue of AOPA Pilot has an article about a Pilatus PC-12
single engine turboprop. Beautiful airplane.
In the article is the following comment: "It's a great glider. ... the PC-12
has a 2.7-1 power off glide ratio at maximum gross weight - not bad at all
for a 9,920 pound airplane".
Just for reference, I calculated the glide ratio of the Schweizer 300C
helicopter I was flying and it is not far off from that, engine out. I
never could attain the calculated glide ratio with the helicopter, though.
I would never call anything with a 2.7-1 glide ratio as being great,
although it probably is better than the space shuttle.
Colin
Old January 7th 06, 07:35 PM posted to rec.aviation.soaring
I saw that too and figured it's gotta be a typo.
Shawn
Old January 9th 06, 12:07 AM posted to rec.aviation.soaring
I would guess that the glide ratio would be about 8 to 1?
Old January 9th 06, 01:36 AM posted to rec.aviation.soaring
Shawn
Old January 8th 06, 03:34 AM posted to rec.aviation.soaring
I think that just has to be a typo... most training Cezzna's are about 7 to
1.
But it would be hard to believe the Pc-12 could get 27/1... I'd believe
maybe 10 or 12 to 1.
3/1 is not much better than a brick. (1/1)
BT
"COLIN LAMB" wrote in message
ink.net...
PC-12 has a 2.7-1 power off glide ratio at maximum gross weight - not bad
at all for a 9,920 pound airplane".
Colin
Old January 8th 06, 04:27 AM posted to rec.aviation.soaring
In article cR_vf.8501$V.4724@fed1read04,
1.
Thatlooks like a sin == tan error. Lift is the component of
aerodynamic force that is perpendicular to the relative airflow, not the
component that is vertically upward. The L/D of a brick is not 1:1 --
which would imply it could fly at an angle of descent of 45 degrees --
but very close to zero.
Well, ok, a canonball has an L/D of zero, if it is not spinning. A
brick would have a slightly better L/D, if you could stabilize it,
perhaps by spinning it, as with a ruler or business card which appear to
have L/Ds of about 1 in stabilized backward-tumbling flight. Maybe a
brick could do that too, at sufficiently high speed?
Bruce | 41.1670S | \ spoken | -+-
Hoult | 174.8263E | /\ here. | ----------O----------
Old January 8th 06, 05:07 AM posted to rec.aviation.soaring
true bruce.. I miss spoke.. a one to one would be 1ft down for every 1 ft
forward.. or about 45degree glide.. I don't think even a tumbling brick
could do that.. maybe 0/1
BT
"Bruce Hoult" wrote in message
to
1.
My Mooney has 12 to 1 with prop stopped (not windmilling). The PC-12 has
less cooling drag plus the prop feathers too. So I would expect it to be
better than 12/1.
I have a friend who has a PC-12 . . . I could ask.
bumper
"BTIZ" wrote in message
news:cR_vf.8501$V.4724@fed1read04...
1.
BT
ink.net...
though.
Colin
Old January 9th 06, 02:35 AM posted to rec.aviation.soaring
Pilatus' web site states that the glide ratio of a PC-12 is 16:1.
It is a very clean aircraft (as turboprops go), but the wing loading is
35 lb./ft2. 16:1 seems optimistic, but I since it is on the internet,
I am sure that it is true.
Bob Zahradnik
Old January 9th 06, 07:45 AM posted to rec.aviation.soaring
Just got an answer from my friend who owns a 2 year old PC-12. Glide ratio
is 12:1 or approx. 2 nm per 1000 ft.
My Mooney 201 is the same, but lots cheaper!
All else being equal, the probability that I might "test" the Mooney's glide
ratio some day is much more than the chance of that PT-6 going quiet.
bumper
Bob Zahradnik
GPS glide ratio calculations james Soaring 0 May 4th 04 10:00 PM
Garmin gpsmap 76s, glide ratio, airspace zone Gilles_Sauvagnat Soaring 11 April 15th 04 01:39 AM
Angle of climb at Vx and glide angle when "overweight": five questions Koopas Ly Piloting 16 November 29th 03 11:01 PM
GPS glide ratio calculations Jason Armistead Soaring 16 September 12th 03 05:50 AM
A Waikerie slip up? Vassilios Mazis Soaring 4 July 29th 03 12:34 AM
