Headset: Unexpected safety bonus
Old January 15th 06, 07:14 PM posted to rec.aviation.owning
Default Headset: Unexpected safety bonus
Bought myself a new headset for Christmas. I expected it to just be a new
toy, but I was amazed at the increase in understandability. Lets face it, like
many pilots looking retirement age in the eye, my hearing ain't what it used to
be. Previously, when I got into a plane, I would automatically turn the volume
well north of 50% just so I could hear above the din. I had come to assume
that the mush-mouth barely-understandable audio I was getting was just part of
the normal deal for those AM aviation radios.
For the budget I had in mind (between .3 and .4 AMU) I could get a pretty
fair conventional headset or a bottom-of-the-line ANR unit. For better or
worse, I went for the ANR, (the Lightspeed R20XL). To my surprise, and for the
first time in ages, I could suddenly hear and (more importantly) understand
every word that was being spoken. Further, I noticed that I was running my
volume control in a more normal position, (perhaps 10 db lower than before)
because there was so much less background noise to overcome.
If you find yourself saying "say again?" often, perhaps it is time to open
up the wallet and invest. There is no longer any valid reason to be flying
without ANR.
Vaughn
Will poofread for food.
Old January 16th 06, 01:10 AM posted to rec.aviation.owning
On Sun, 15 Jan 2006 18:14:27 GMT, "Vaughn"
That a good angle to justify a new headset to the wife. Congrats on
the equipment.
Scott D.
Old January 16th 06, 02:45 AM posted to rec.aviation.owning
Vaughn, what were you using before you got the new headset?
Old January 18th 06, 03:27 AM posted to rec.aviation.owning
"john smith" wrote in message
FWIW: a Sigtronics S-2M-CE. It is old, but was at the factory for refurb
about two years ago. It now serves as my passenger unit.
Vaughn
Old January 16th 06, 03:10 AM posted to rec.aviation.owning
In addition to the ANR, I still use foam earplugs and then turn up the
radio. That makes it even clearer.
Old January 16th 06, 04:20 AM posted to rec.aviation.owning
You put earplugs in your ears, and then turn up the volume?
Isn't that sorta like holding the brakes whilst flooring the accelerator?
What, exactly, are you trying to accomplish?
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old January 16th 06, 05:25 AM posted to rec.aviation.owning
Well, the earplugs shut out the ambient noise. Increasing the volume of the
radio cancels the effects of the earplugs, as far as the radio is concerned. Now
all he hears is radio.
The main problem with this is that many radios have poorer signals at high
volume. You may be introducing electronic noise.
George Patterson
Coffee is only a way of stealing time that should by rights belong to
your slightly older self.
"Jay Honeck" writes:
Greater isolation from sounds *other than* the ones coming through the
amplifier. I use this same trick at the shooting range using
electronic muffs.
David Dyer-Bennet, , http://www.dd-b.net/dd-b/
RKBA: http://noguns-nomoney.com/ http://www.dd-b.net/carry/
Pics: http://dd-b.lighthunters.net/ http://www.dd-b.net/dd-b/SnapshotAlbum/
Dragaera/Steven Brust: http://dragaera.info/
Old January 16th 06, 05:45 AM posted to rec.aviation.owning
On Mon, 16 Jan 2006 03:20:46 GMT, "Jay Honeck"
George and David answered the acoustical part (BTW, years ago, before
there were headsets, I used earplugs just to listen to the speaker,
for the reasons they give.), but as a newly-returned-to -the-activity
motorcycle rider, I note that what you describe is pretty much what is
necessary to pass the m'cycle driving test in most states today.
(Unless you pass the MSF course, which I did today, without using that
Jerry Paladino technique.)
Don
Old January 16th 06, 06:12 PM posted to rec.aviation.owning
"DT" == Don Tuite writes:
DT George and David answered the acoustical part (BTW, years ago,
DT before there were headsets, I used earplugs just to listen to
DT the speaker, for the reasons they give.), but as a
DT newly-returned-to -the-activity motorcycle rider, I note that
DT what you describe is pretty much what is necessary to pass the
DT m'cycle driving test in most states today.
Hey, could you tell our governor this trick? He needs to pass that
test too....
Nearly had my life terminated today Michelle P Piloting 11 September 3rd 05 03:37 AM
ASRS/ASAP reporting systems - how confidential? Tim Epstein Piloting 7 August 4th 05 06:20 PM
Parachute fails to save SR-22 Capt.Doug Piloting 72 February 10th 05 06:14 AM
SSA to Safety Group at Convention: "Clear Off!" ? SoarPoint Soaring 11 February 13th 04 05:48 PM
