GPS Question
Old March 9th 06, 08:35 PM posted to rec.aviation.ifr
Default GPS Question
I thought I understood this, but maybe not. GPS systems were certified
for approaches after I got my instrument ticket, so my knowledge is
more anecdotal than from actual training.
Can an approach-certified GPS be used to substitute for NDB and DME
during an approach (or even en route)? What if the approach says ADF
Required or DME Required? My understanding of the AIM is that you can
only use the GPS as a substitute when there is a published GPS overlay
for the approach.
(My question is about the legality and not about whether you'd be close
enough.)
Old March 9th 06, 08:50 PM posted to rec.aviation.ifr
for the approach.
enough.)
The AIM has a section devoted to the use of GPS in lieu of ADF and DME,
which will answer your question, and much more ;-)
Go to section 1-1-19, and look for "Use of GPS in lieu of ADF and DME".
The short answer is yes, you can use GPS as a replacement for ADF and DME
unless the navigational station is the primary for the approach (which
could be true for ADF, but not DME).
So, if you're flying an NDB approach, you could not use the GPS as a
replacement for the NDB ground station.
However, if you're flying an approach that requires DME, or an NDB to
identify the OM, you can use the GPS to provide that information.
Mark Hansen, PP-ASEL, Instrument Airplane
Cal Aggie Flying Farmers
Sacramento, CA
Old March 9th 06, 09:40 PM posted to rec.aviation.ifr
Here in the lower 48 states, the NDB approach is fast going the way of the
Dodo bird. Every Jepp update I have received over the last 6 months seems
to require the removal of more NBD approaches than those I replace.
Peter
Old March 10th 06, 01:37 AM posted to rec.aviation.ifr
They've gotten rid of a bunch of NDB approaches, but there were still 1,283
left as of 10/27/05.
"Peter R." wrote in message
Peter
Old March 9th 06, 09:51 PM posted to rec.aviation.ifr
Except, of course, for the famous VOR/DME OR TACAN Z RWY 15 approach at Martin
State:
http://www.naco.faa.gov/d-tpp/0602/05222VDTZ15.PDF
Old March 9th 06, 10:21 PM posted to rec.aviation.ifr
State:
Are you saying that you can't use the GPS in lieu of DME for that approach?
Why not?
Sacramento, CA
Old March 10th 06, 03:06 AM posted to rec.aviation.ifr
Martin State:
Why not?
Yes, because the DME is the "principal instrument approach navigation
source" - that approach is a DME arc to the runway.
Old March 10th 06, 03:10 AM posted to rec.aviation.ifr
"Barry" wrote in message
Martin State:
approach?
Why not?
A subtle but important observation! Have you won any bets with that one?
Old March 10th 06, 04:24 PM posted to rec.aviation.ifr
Martin State:
Why not?
Oh, right! I've never seen that before. Very cool looking approach.
I knew I was going to learn something new today :-)
Thanks for pointing it out.
Best Regards,
Sacramento, CA
Old March 11th 06, 06:41 PM posted to rec.aviation.ifr
navigation source" - that approach is a DME arc to the runway.
Sounds like pure speculation to me. Can you support with any FAA
material?
Lyc. O-360 cylinder question JB Owning 13 November 27th 04 10:32 PM
Handheld battery question RobsSanta General Aviation 8 September 19th 04 04:07 PM
A question on Airworthiness Inspection Dave S Home Built 1 August 10th 04 06:07 AM
Question Charles S Home Built 4 April 5th 04 10:10 PM
Partnership Question Harry Gordon Owning 4 August 17th 03 12:23 AM
