Lost comm altitude?
Old January 10th 04, 05:11 PM
Roy Smith
Default Lost comm altitude?
The Dutchess Four Departure has lost comm instructions which read, "If
radio contact is not established/lost for more than two minutes after
departing, proceed on course and climb to 5000 feet. Ten minutes after
departure, climb to requested altitude/flight level".
Let's say my clearance is "Cleared to HPN via Dutchess Four, V157,
HAARP, direct. Maintain 3000, expect 4000 after 10". If I go lost
comm, do they expect me to climb to 5000, stay there for 10 minutes,
then descend back down to 4000? Or stop my climb at 4000? Or climb to
5000 and stay there (which would presumably leave me WAFDOF).
I'm inclined to think stopping my climb at 4000 makes the most sense,
but one could make arguments in support of any of the alternatives.
The OROCA is 4700. 5 miles to the west, the OROCA goes up to 6700. MEA
on V157 is 4000, MOCA is 2700.
Old January 10th 04, 06:56 PM
Gary Drescher
"Roy Smith" wrote in message
Heh, that's a nice dilemma. The instructions are contradictory enough that
there isn't anything you can do that would assure that you're doing what ATC
expects. So I'd vote for climbing to 5000' (since at least that part of the
directive is unambiguous), and then staying there (since there's no clear
directive to descend, and other things being equal, higher is better). I
would hope and expect that ATC would at least clear a block for you from
3000 to 5000 to cover the plausible interpretations.
--Gary
Old January 10th 04, 07:22 PM
Barry
I would say that the altitudes you were issued constitute an amendment to the
Dutchess Four clearance, so I'd stop at 3000, intercept V157, then climb to
4000 10 minutes after takeoff. If I was nervous about terrain, then I'd use
my emergency authority to go to whatever altitude I felt was necessary, and
then back to 4000 once established on V157.
Related question: looking at the approach plates for POU, I see that the
VOR/DME RNAV or GPS RWY 6 shows no MSA. Does anyone know why? All the other
approaches to POU show an MSA circle.
Barry
Old January 10th 04, 07:44 PM
Ron Rosenfeld
The Jepp chart states that no MSA is published for this approach.
Old January 10th 04, 07:51 PM
Gary Drescher
"Barry" wrote in message
to
Sure the altitudes amend the Dutchess Four clearance itself, but not the
clearence's explicit lost-comm procedure. That would only be amended if ATC
issued explicit lost-comm altitudes too.
--Gary
and
other
Barry
Old January 10th 04, 08:12 PM
Barry
But when ATC tells you "Maintain 3000, expect 4000 after 10," isn't "expect
4000" explicitly for lost-comm? From the AIM:
EXPECT (ALTITUDE) AT (TIME) or (FIX)- Used under certain conditions to provide
a pilot with an altitude to be used in the event of two-way communications
failure. It also provides altitude information to assist the pilot in
planning.
Barry
Old January 10th 04, 08:32 PM
Gary Drescher
ATC
"expect
Hm, yes, that's a good point. But then "maintain 3000" isn't for lost comm.
So I guess the most literal (but not the most sensible) interpretation would
be to climb to 5000' as per the explicit Dutchess Four lost-comm procedure,
then descend to 4000' as per the overriding "expect 4000 after 10". Or
something like that.
Old January 10th 04, 07:49 PM
Ron Rosenfeld
I would do exactly as the chart states and not try to second-guess the
reasons. (Except that after ten minutes, to get from 5000 to 4000
obviously requires a descent).
Certainly if you climbed to 5000 when cleared to 4000, that would also
serve to get ATC's attention, and might lead to sooner establishment of
radio contact.
Old January 10th 04, 08:34 PM
Teacherjh
I'd climb to 5000, then MEAs permitting) descend to 4000. In no case would I
stop before 5000. The (explicit) instructions to do so on lost comm may be to
get you high enough to receive a different outlet, or to be picked up on a
better radar sweep. Who knows... they asked me to do that, I do that.
Jose
Old January 10th 04, 08:52 PM
Ron Natalie
"Teacherjh" wrote in message ...
Is this one of those Radar Vectors departures? 5000 feet might be required
to allow you to get "on course" via your own navigation in lieu of radar vectors.
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) Rich Stowell Aerobatics 28 January 2nd 09 03:26 PM
Retractable Comm Antenna Ron Wanttaja Home Built 11 September 6th 04 07:59 PM
FS: Soft Comm ATC-4Y 4 place portable intercom Jaysen Underhill Instrument Flight Rules 0 December 11th 03 10:41 PM
GPS Altitude with WAAS Phil Verghese Instrument Flight Rules 42 October 5th 03 01:39 AM
Lost comm - Arrival Michael 182 Instrument Flight Rules 3 July 28th 03 01:04 AM
