Cracked ribs
Old March 30th 06, 06:05 AM posted to rec.aviation.piloting
Default Cracked ribs
Piper has a new service bulletin, SB1161 that calls for inspection of
the rib just inboard of the landing gear and aft of the main spar.
http://www.newpiper.com/company/Publ...20Insp-Mod.pdf
The SB requires putting the plane on jacks and removing the gear side
brace and bracket.
As 04T is in for the annual, we figured it was a good time to have the
SB performed. It turns out we have cracks on both sides of the rib and
they're bad enough that the repair kit announced in the SB can't be
used. Solution: two new ribs. Cost for parts: 1.1 AMU. Labor is
unknown at the moment but the shop is putting together an estimate.
At least I can split the repair bill three ways...but it's still gonna
put a dent in the flying funds.
Jack Allison
PP-ASEL-Instrument Airplane
Arrow N2104T...soon to have two new zinc chromated ribs!
"When once you have tasted flight, you will forever walk the Earth
with your eyes turned skyward, for there you have been, and there
you will always long to return"
- Leonardo Da Vinci
(Remove the obvious from address to reply via e-mail)
Old March 30th 06, 06:06 AM posted to rec.aviation.piloting,rec.aviation.owning
Jack Allison wrote:
Oops...meant to post in r.a.o...bah, stupid fingers!
brace and bracket.
Jack Allison
Arrow N2104T
- Leonardo Da Vinci
Old March 30th 06, 05:47 PM posted to rec.aviation.piloting,rec.aviation.owning
Augh! That really, really sucks, Jack.
Two good things:
1. It sounds like the kind of thing that only gets worse over time.
You are wise to get it over and done with now.
2. You caught it far enough before OSH as to not interfere with your
trip. (Well, unless your shop REALLY sucks.) THAT could have ruined
your whole summer.
I'll bet this problem is going to rival the Lycoming crankshaft AD by
the time all is said and done. There are a LOT of Piper retracts out
there.
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old March 31st 06, 08:00 AM posted to rec.aviation.piloting
Bad luck Jay. Do they have a theory as to how/why the cracks developed?
....Edwin
__________________________________________________ _____
"Once you have flown, you will walk the earth with your
eyes turned skyward, for there you have been, there you
long to return."-- da Vinci ... www.shreve.net/~elj
Old March 31st 06, 08:34 AM posted to rec.aviation.piloting
...Edwin
Hey Edwin...I have no background data on this but would love to find some.
Jack Allison
Arrow N2104T
- Leonardo Da Vinci
Old March 31st 06, 08:14 AM posted to rec.aviation.piloting,rec.aviation.owning
Yes, suckage level is extremely high. Right at the one year ownership
point too. Oh well, I'll have some great show and tell pictures for
Oshkosh. What an excuse to have folks crawl around in the grass under
my plane :-)
Two good things:
Yep, and if it becomes an AD, I'd expect we will have permanently
complied by replacing the ribs.
your whole summer.
Also very true.
there.
It's going to be interesting to see how many folks opt for performing
the SB and how many find cracks. I only know of one other aircraft that
found cracks (Dick Russ's Lance)...but it's still very early with this
one.
I'm also very interested to see if this does become an AD.
Jack Allison
Arrow N2104T
- Leonardo Da Vinci
Old March 31st 06, 12:23 PM posted to rec.aviation.piloting
On Thu, 30 Mar 2006 22:14:31 -0800, Jack Allison
wrote in
If we're discussing PA28's, there was a mandatory service bulletin for
inspection of the wing spars that required removal of the wing tanks
issued around August 1996, IIRC. Have you had that inspection
performed?
Old April 1st 06, 05:52 AM posted to rec.aviation.piloting
performed?
SB 1006...yep, it was done a couple years ago. IMHO, this is a
mandatory SB to perform as part of buying a PA28.
Jack Allison
Arrow N2104T
- Leonardo Da Vinci
Old March 31st 06, 10:44 PM posted to rec.aviation.piloting,rec.aviation.owning
("Jack Allison" wrote)
Oshkosh. What an excuse to have folks crawl around in the grass under my
plane :-)
"...suckage level is extremely high."
Agreed! :-(
I'll have to gauge your temperature in a few months before we decide to
offer ribs at the Rec.Aviation N40 cookout this year.
Good luck harboring your AMU's.
Montblack
Old April 1st 06, 06:11 AM posted to rec.aviation.piloting,rec.aviation.owning
So long as you don't charge $.55 AMUs plus $.05 AMU crating fee per rib,
cook up all the ribs you want (or have Joe cook 'em up!
I think I'll have to rob the flying fund for the next few months.
Jack Allison
Arrow N2104T
- Leonardo Da Vinci
Cracked cylinder: Typical cause? Peter R. Owning 19 October 9th 04 05:24 AM
Testing Stick Ribs Bob Hoover Home Built 3 October 3rd 04 03:30 AM
How much to replace cracked crankshaft in 1972 skyhawk O-320-E2D engine Dave Gribble Owning 2 February 4th 04 09:30 AM
Heat treating wing ribs Holger Stephan Home Built 13 February 4th 04 12:59 AM
Is a cracked vent SCAT tube an urgent problem? Ben Jackson Owning 18 September 20th 03 04:31 AM
