Can anyone suggest a text or other reference on abrasive ('sand')
blasting for removing rust from an aircraft steel frame? It should discuss size of compressor, components I'll need, whether or not a booth is needed, what abrassive material to use. Thanks, Mike (in the meanwhile I'll polish off GOOGLE) |
Do a search for CLEMCO.
They manufacture abrasive blasting equipment. Plastic beads or glass beads work well on many parts. Many other blast medias are also available. There is a material which is a coarse form of baking power. Works well and does little base metal removal but removes coatings and light surface rust. DO NOT USE SAND!!!!! Many dangers and problems with sand. It is outlawed in many countries but still widely used by many in the US. Black Beauty is an angular abrasive which will leave your surface too rough. |
| Remove references etc... | Andy Davey | Soaring | 0 | October 24th 04 11:49 PM |
| Blasting and painting | [email protected] | Home Built | 7 | June 3rd 04 04:14 PM |
