Something missing on the missed?
Old April 8th 06, 07:33 PM posted to rec.aviation.ifr
Default Something missing on the missed?
OK, am I missing something or is there something missing on this missed
approach procedure at Petaluma? What do you do when you get to the
VOR? Hover?
http://204.108.4.16/d-tpp/0603/06838G29.PDF
-Dan
Old April 8th 06, 08:31 PM posted to rec.aviation.ifr
VOR? Hover?
Didn't you see the note in the upper left corner: "Magic required"?
Jose
Nothing takes longer than a shortcut.
Old April 8th 06, 08:47 PM posted to rec.aviation.ifr
The Jepp version is the same. I presume the expectation is that you
will negotiate with ATC to establish a new plan before you get to PYE,
or if you're NORDO, you'll make up a new plan of your own or proceed to
your alternate (assuming O69 was not already your alternate.)
3500 at PYE is high enough for you to go north or south on V25-27 or
north on V301, so if you were NORDO you could transition back to the
enroute chart and go somewhere else without bumping anything. The MORA,
however, is higher, so even though you're /G, I'd stick to the airways
until higher.
-- dave j
VOR? Hover?
-Dan
Old April 8th 06, 09:05 PM posted to rec.aviation.ifr
hold and request further clearance.
James H. Macklin
ATP,CFI,A&P
"Dan" wrote in message
on this missed
get to the
| VOR? Hover?
| -Dan
Old April 8th 06, 11:49 PM posted to rec.aviation.ifr
VOR? Hover?
Since you know the problem AND as long as I am not NORDO, I'd be putting an
annotation on the procedure to question ATC "What are the missed
procedures" on my IFR briefing portion of my initial approach into the
airport.
Maybe a call to the local airport (or one nearby) will have the answer?
Allen
Old April 9th 06, 12:41 AM posted to rec.aviation.ifr
VOR? Hover?
-Dan
The end of a missed approach must support holding or en route flight.
The design is at the option of the controlling ATC facility.
Old April 9th 06, 05:25 AM posted to rec.aviation.ifr
Not that it's any excuse, but how much do you want to bet that no aircraft
that has ever gone missed at this airport has ever even gotten halfway to
the holding fix before being vectored back to the IAF.
Kobra
VOR? Hover?
-Dan
Old April 9th 06, 07:16 PM posted to rec.aviation.ifr
Maybe NACO made a mistake. It happens. Does anyone have a Jepp for
comparison? Missed procedure is probably missing the words "and hold." To
report chart errors:
http://www.naco.faa.gov/index.asp?xm...eportingerrors
"Kobra" wrote in message
Kobra
VOR? Hover?
-Dan
Old April 10th 06, 01:04 AM posted to rec.aviation.ifr
groups.com...
VOR? Hover?
-Dan
Although it looks odd and most procedures have a holding pattern, the
procedures design regulation doesn't require it (TERPs paragraph 270).
The missed approach procedure only has to specify an altitude and a
clearance limit. The altitude specified in the missed approach must be
sufficient to allow enroute flight or holding. If you still have radio
contact with approach, then you're expected to relay your intentions to
them. If you don't have radio contact, just do what you would do if you
were NORDO.
John
Old April 10th 06, 06:44 AM posted to rec.aviation.ifr
Jepp is the same. It is not a mistake.
There are lots of missed approaches without holding patterns.
KPOC ILS 26
KEMT both VOR IAPs
Missing in Action Serviceman Identified Otis Willie Naval Aviation 0 March 19th 05 12:58 AM
missing man formation for Reagan Paul Hirose Military Aviation 1 June 14th 04 01:50 AM
Approach Question- Published Missed Can't be flown? Brad Z Instrument Flight Rules 8 May 6th 04 05:19 AM
Search for missing plane C J Campbell Piloting 2 March 4th 04 02:42 AM
Ellery Queen and the Case of the Missing Magneto Gear Teeth MikeremlaP Owning 3 July 26th 03 04:01 AM
