Training for my CFII - Got a couple questions
Old April 30th 04, 04:43 AM
BoDEAN
Default Training for my CFII - Got a couple questions
What is the best course of action I should take to get my CFII?
I am currently a CFI at a 141 school. My instrument skills are weak
(I only have 10 hours actual, 60 simulated) and rarely fly instruments
because all my students are primary.
I need to get my knowledge test done, and I want to get my CFII as
soon as I can. What steps should I take to get it done?
Thanks in advance
Old April 30th 04, 05:34 AM
Teacherjh
I don't know the answer to the question you are asking. But I am prompted to
ask why you want to be a CFII if your instrument skills are weak. Why do you
want to teach something you don't know?
I'd say (opinion only) your first task is to get good instrument skills, and
learn more about weather flying.
Jose
Old April 30th 04, 03:33 PM
BoDEAN
Thanks
I'll hit the sim today
On 30 Apr 2004 12:33:58 GMT, Andrew Sarangan
(Teacherjh) wrote in
prompted to ask why you want to be a CFII if your instrument skills
are weak. Why do you want to teach something you don't know?
skills, and learn more about weather flying.
Jose
I would concur with that. If your instrument skills are weak, what
exactly will you be teaching, not to mention that you will also have
difficulty with the CFII checkride.
The written test is a no brainer. The CFII written is exactly the same as
the IR written. If you are having difficulty with the written, then you
have some serious work to do. Not only should you be able to effortlessly
pass the written, you should be able to score near 100% since this is
really the second time around.
The flying portion requires practice and experience. Look for IMC days,
rent an airplane and fly around to get some actual experience and dealing
with ATC. Proficiency in IFR requires a lot more knowledge and experience
than what a typical IR checkride demands. In order to give effective
instruction, you must have that experience.
Old April 30th 04, 04:44 PM
Roy Smith
BoDEAN wrote:
Thanks
With all due respect, I think this was the wrong answer. Hitting the
sim will probably help you pass the CFI-I checkride, but it won't do
much towards making you a better instrument pilot, or a better
instrument instructor.
When I took my CFI-I ride, I did a bunch of sim work too. I hadn't
really flown any NDB approaches since my initial instrument training,
and was having trouble getting them back up to snuff. It was a lot
cheaper to buy a copy of X-plane and fly a bunch of approaches at my
desk than to bore holes in the sky re-learning how an ADF works.
But, flying good approaches in the sim doesn't make you a good
instrument pilot, and being a good instrument pilot is essential to
being a good instrument instructor. A fair amount of instructing
involves letting the student make mistakes, both in terms of procedures,
and in judgement. With instruments, the limits of how big a mistake you
can let them make are smaller, and the consequences of going too far
much worse than VFR. But, you still need to let them explore the edges
of envelope. And to do that, you need to know what's safe w/r/t getting
killed, what's safe w/r/t getting ATC ****ed at you, and what's safe
w/r/t you being able to recover from the mess you let your student dig
themselves into.
Another thing I've discovered about instructing (especially in busy
airspace like around New York), is that a fair part of your job is being
able to anticipate what ATC will let you do and what they won't. Some
of my biggest failures have been flights where I came up with a lesson
plan only to discover that ATC denied us the clearances required to
execute the plan.
The problem is, unless you're out there flying in the system, in
weather, experiencing and coping with real-life problems yourself, you
won't have the experience to pass on to your students, and you won't
have the judgement to know where to draw the line on making mistakes.
You won't get that in a sim.
Old May 3rd 04, 01:42 PM
john price
"Roy Smith" wrote in message
execute the plan.
Ditto here... I fly on the other side of NY from Roy and spend a lot
of time with my students teaching how much difference there is
between the book world and the real world...
It's like chess... Always be thinking ahead... As one of my buddies
always asks his instrument students... What are the two most
important things in instrument flying??? (you'd really be suprised
at the variety of things you get back)... The next 2 things...
John Price
CFII/AGI/IGI
http://home.att.net/~jm.price
Old April 30th 04, 09:29 PM
Michael
Start by reading the other replies (from Andrew and Roy) - I won't
repeat what they covered, but I agree with every word they said. I
also understand that you probably have financial constraints that
preclude you from renting/buying an airplane and acquiring real
in-the-system and in-the-weather experience. I have a suggestion.
Seek out pilot-owners who have real instrument airplanes and actually
fly IFR in IMC on a regular basis, and ask if you can ride along.
Offer to act as safety pilot, sign off BFR's (and IPC's once you get
your CFII), wash the airplane, etc. Carefully observe and ask
questions - you may be flying with a private pilot, but if he's the
one who flies IFR regularly and you're the one with 10 hours of
actual, then you are the student and he's the instructor - and getting
your CFII won't change that.
To quote Yogi Berra, "Sometimes you can observe a lot by watching."
If you do a good job of observing, you will be able to answer the
following questions:
How does the pilot negotiate with ATC? What are normal deviations in
attitude when the pilot is focused? How about when he's looking up
charts and copying clearances? How does the pilot deal with bad
weather? Bad vectors?
Being a CFII will give you the authority to give dual instruction
required for the instrument rating; you ALREADY have the authority to
give dual instruction in IMC. Approach this carefully, and don't
start by doing it with an instrument student. Ideally, start by
sitting in the right seat and observing a proficient instrument pilot
in IMC. Then move up to giving instruction in IMC to someone who is
already a proficient instrument pilot, and just needs an aircraft
checkout or IPC. In these situations you can't do much damage.
Or you can ignore all of this, hit the sim, squeak out a checkride,
and teach instruments strictly under the hood to career-track students
who will never fly any significant amount of IMC until they hit the
right seat of a commuter. Your call.
Michael
Old May 1st 04, 01:08 AM
Max T, CFI
Michael wrote in message om...
True, as long as it's not training for an instrument rating per 61.195(a)(3)
So you could take your student pilot into IMC as part of the 3 hours of instrument training;
just not an instrument student.
My recollection is that you need a CFII to give an IPC (or an IGI if you give
it in a sim). As I recall when I looked it up on Lynch some time ago, a CFI
cannot give IPC's.
Max T, MCFI
Old May 1st 04, 02:28 AM
Bill Zaleski
An IGI cannot give an IPC, only the training for one. He cannot sign
one off. (FAR 61.215, training and endorsements vs. 61.193 (g),
training only) An IGI can only give the endorsement for an instrument
knowlege test and none other. He can give the training, however for
an IPC.
On Fri, 30 Apr 2004 23:08:36 GMT, "Max T, CFI"
cannot give IPC's.
Max T, MCFI
Old May 1st 04, 08:12 AM
Max T, CFI
A key point for BoDEAN is that a CFI is not an "authorized instructor"
and hence could not give an IPC when it was suggested to him
checkout or IPC"
Regarding an IGI giving an IPC, I've posted the latest text from Lynch below.
It's certainly convoluted. It sounds like he previously said an IGI "can conduct the IPC,"
(which is what I recalled) but now is saying they can "perform the training for an IPC," but not the check itself,
since IGI's aren't listed in 61.215(c)(2)
Max T, MCFI
QUESTION: Can an personal computer aviation training device (PCATD) be used for the instrument proficiency check?
ANSWER: Ref. § 61.57(d)(1): No.
{Q&A-94}
QUESTION: In § 61.57 of the "Frequently Asked Questions of parts 61& 141" the question is asked whether an IGI can
conduct the proficiency check required in an approved ground training device. The answer given is yes. However, I have a
letter from AFS 840 signed by Michael Sacrey stating that "Only a certificated instrument flight instructor may conduct
the instrument competency check, regardless of whether given in a ground training device, an aircraft simulator, or in
an aircraft." Which interpretation is the correct one?
ANSWER: Ref. § 61.215(c)(2). Yes, an IGI can perform training in a flight simulator or flight training device ". . . for
an instrument proficiency check."
It has been brought to my attention that my earlier answer on Question 2 may have confused training vs. checking. Only
those persons identified in § 61.57(d)(2) can GIVE the instrument proficiency check.
{Q&A-104}
Bill Zaleski wrote in message ...
an IPC.
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) Rich Stowell Aerobatics 28 January 2nd 09 03:26 PM
Homebuilt Aircraft Frequently Asked Questions List (FAQ) Ron Wanttaja Home Built 0 September 2nd 04 06:15 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 June 2nd 04 08:17 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 May 1st 04 08:29 PM
First couple hours of real CFII dual given.... Blaine Instrument Flight Rules 17 January 15th 04 06:48 PM
