A: The Navy intends to reduce it's purchase of F-35Cs by deploying more
Marine Corps strike fighter squadrons on board big deck carriers. B: The USMC plans to buy zero F-35Cs. Does A + B mean that the next USN big deck carrier will have a ski ramp? ;-) -HJC |
"Henry J Cobb" wrote in message ... A: The Navy intends to reduce it's purchase of F-35Cs by deploying more Marine Corps strike fighter squadrons on board big deck carriers. B: The USMC plans to buy zero F-35Cs. Does A + B mean that the next USN big deck carrier will have a ski ramp? ;-) -HJC No why should they have ramps. They Navy doesn't have ramps on the Amphibs when the Marines deploy the Harriers on them. The F-35B's deployed on the carrier would most likely be used as air to ground attack aircraft with the Navy F-35C's doing the air to air/ fleet protection mission. Besides they may still put some kind of catapult launch system on the F-35B (bridle ?). |
Diamond Jim wrote:
"Henry J Cobb" wrote in message ... A: The Navy intends to reduce it's purchase of F-35Cs by deploying more Marine Corps strike fighter squadrons on board big deck carriers. B: The USMC plans to buy zero F-35Cs. Does A + B mean that the next USN big deck carrier will have a ski ramp? No why should they have ramps. They Navy doesn't have ramps on the Amphibs when the Marines deploy the Harriers on them. The F-35B's deployed on the carrier would most likely be used as air to ground attack aircraft with the Navy F-35C's doing the air to air/ fleet protection mission. Besides they may still put some kind of catapult launch system on the F-35B (bridle ?). The Gators are mainly helicopter carriers with a reduced (i.e. TAIP-sized, around 10 planes) Harrier squadron. They need flightdeck space more than range. Wouldn't a ramp cause problems for V-22 takeoffs? -HJC |
Henry J Cobb wrote:
Diamond Jim wrote: "Henry J Cobb" wrote in message ... A: The Navy intends to reduce it's purchase of F-35Cs by deploying more Marine Corps strike fighter squadrons on board big deck carriers. B: The USMC plans to buy zero F-35Cs. Does A + B mean that the next USN big deck carrier will have a ski ramp? No why should they have ramps. They Navy doesn't have ramps on the Amphibs when the Marines deploy the Harriers on them. The F-35B's deployed on the carrier would most likely be used as air to ground attack aircraft with the Navy F-35C's doing the air to air/ fleet protection mission. Besides they may still put some kind of catapult launch system on the F-35B (bridle ?). The Gators are mainly helicopter carriers with a reduced (i.e. TAIP-sized, around 10 planes) Harrier squadron. They need flightdeck space more than range. Wouldn't a ramp cause problems for V-22 takeoffs? Assuming a V-22 STO instead of a VTO it might, depending on where the V-22 began its t/o run, the length of same,the ramp height/angle and the V-22's climb slope. Of course, it's possible that the V-22 has enough proprotor clearance at 60 or 70 degrees that it could use a ski jump with no problem -- E-2s were successfully tested off low-angle (2.1deg. IIRR) ski jumps. Whether the proprotors are designed to take the rapidly changing vertical acceleration as they transit the ramp, I couldn't say. Guy |
Diamond Jim wrote: No why should they have ramps. They Navy doesn't have ramps on the Amphibs when the Marines deploy the Harriers on them. The F-35B's deployed on the carrier would most likely be used as air to ground attack aircraft with the Navy F-35C's doing the air to air/ fleet protection mission. Besides they may still put some kind of catapult launch system on the F-35B (bridle ?). I cannot agree with the opinion that F-35C is going to be the air-to-air aircraft, and F-35B air-to-ground aircraft. Right, Marine squadrons are better specialized in CAS for their troops on the ground, but this is also the the mission usually performed by Navy aircraft nowadays (though sometimes called in a bit different way). After the Cold War ended, and considering the fact most attack aircraft of nowadays are strikefighters, the need for air-to-air seems to be decreasing. Also such a division like you told about would deny current TACAIR integration concept of mission-commonality. Kind regards, Jacek |
wrote in message ups.com... Diamond Jim wrote: No why should they have ramps. They Navy doesn't have ramps on the Amphibs when the Marines deploy the Harriers on them. The F-35B's deployed on the carrier would most likely be used as air to ground attack aircraft with the Navy F-35C's doing the air to air/ fleet protection mission. Besides they may still put some kind of catapult launch system on the F-35B (bridle ?). I cannot agree with the opinion that F-35C is going to be the air-to-air aircraft, and F-35B air-to-ground aircraft. Right, Marine squadrons are better specialized in CAS for their troops on the ground, but this is also the the mission usually performed by Navy aircraft nowadays (though sometimes called in a bit different way). After the Cold War ended, and considering the fact most attack aircraft of nowadays are strikefighters, the need for air-to-air seems to be decreasing. Also such a division like you told about would deny current TACAIR integration concept of mission-commonality. Kind regards, Jacek Oh really! When did the need for a CAP over the fleet disappear? Don't you still need a BARCAP to protect the attack aircraft, no matter how unlikely opposition from air to air is? Just because an aircraft such as the F-35 can perform both missions, doesn't mean that it can do both at the same time, with 100% effectiveness. If the aggressor can make you jettison all or part of your bomb load, why that defeats the attack doesn't it? Remember such pearls of wisdom from the past as these and many others; Lord Cardigan the Russian battery at the end of the valley is the object of attack. The reply of Lord Cardigan was, "Very good, sir." To the Light Brigade he then gave the word of command, "The Brigade will advance." General Custer said "Leave the gatlin guns with the supply wagons; they are just slowing us down". OK lads. Over the top and lets go get them Turks! (Gallipoli) Well if the radios are out because of static, send the warning to Pearl Harbor by Western Union. We don't need guns on fighters; missiles will do the job now. "The foam coming off the tanks isn't a problem for the shuttle". |
OK, you've got a point here! The air threat for the fleet is not very
significant now (practically no threat from Iraq and Afghanistan's air forces), but that could change instantly with every encounter with North Korea, Iran or China. But still I think that saying F-35C is going to be a pure fighter and F-35B only a striker sounds like a big exaggeration to me. Best regards, Jacek Diamond Jim wrote: Oh really! When did the need for a CAP over the fleet disappear? Don't you still need a BARCAP to protect the attack aircraft, no matter how unlikely opposition from air to air is? Just because an aircraft such as the F-35 can perform both missions, doesn't mean that it can do both at the same time, with 100% effectiveness. If the aggressor can make you jettison all or part of your bomb load, why that defeats the attack doesn't it? Remember such pearls of wisdom from the past as these and many others; Lord Cardigan the Russian battery at the end of the valley is the object of attack. The reply of Lord Cardigan was, "Very good, sir." To the Light Brigade he then gave the word of command, "The Brigade will advance." General Custer said "Leave the gatlin guns with the supply wagons; they are just slowing us down". OK lads. Over the top and lets go get them Turks! (Gallipoli) Well if the radios are out because of static, send the warning to Pearl Harbor by Western Union. We don't need guns on fighters; missiles will do the job now. "The foam coming off the tanks isn't a problem for the shuttle". |
Henry J Cobb wrote: A: The Navy intends to reduce it's purchase of F-35Cs by deploying more Marine Corps strike fighter squadrons on board big deck carriers. IIRC, the TAIP came about prior to any firm numbers of F-35 purchases. In fact, for better or worse, the TAIP is currently be executed -- long before the first production F-35 enters either the USN or USMC. Second, the USMC F-35s are to replace AV-8Bs; and those VSTOL birds haven't deployed aboard Navy big decks since the A mondel did, once, back in 1976-77 aboard FDR ... B: The USMC plans to buy zero F-35Cs. So? That means, what? That the USMC is going to keep their F/A-18s is what it means ... Does A + B mean that the next USN big deck carrier will have a ski ramp? ;-) Nope. |
Mike Weeks wrote:
Henry J Cobb wrote: B: The USMC plans to buy zero F-35Cs. So? That means, what? That the USMC is going to keep their F/A-18s is what it means ... Forever? This looks like a plan for a breakup, not a merger to me. The USMC F/A-18s will serve their last few years on the big decks and then not be replaced there by another Marine aircraft, ever. -HJC |
Henry J Cobb wrote: Mike Weeks wrote: Henry J Cobb wrote: B: The USMC plans to buy zero F-35Cs. So? That means, what? That the USMC is going to keep their F/A-18s is what it means ... Forever? Who stated anything about "forever"? Nothing is "forever". This looks like a plan for a breakup, not a merger to me. Well, since the "merger" has already taken place, then it's possible a "breakup" could be the next step; but only if it's agreed to by the major partner, the USN ... The USMC F/A-18s will serve their last few years on the big decks and then not be replaced there by another Marine aircraft, ever. No, the USMC F/A-18s will serve both aboard the big decks, and ashore -- as currently is being done. Down the road, a good number of years from now, you might wish to wonder what will happen to USMC fix-wing air (non-VSTOL) and how that will impact the TAIP -- but given that just about everything now days is written in jello, I might suggest waiting to see how the intro of the F-35 series goes; it might then become more obvious. |
| Thread Tools | |
| Display Modes | |
| UAV's and TFR's along the Mexico boarder | John Doe | Piloting | 145 | March 31st 06 07:58 PM |
| CRS: V-22 Osprey Tilt-Rotor Aircraft | Mike | Naval Aviation | 0 | October 14th 05 09:14 PM |
| Navy helo pilots plan tactical training in multi-phase exercise | Otis Willie | Naval Aviation | 7 | August 23rd 05 11:41 PM |
| Lot of noise being made about Purple Hearts | Jack | Military Aviation | 154 | September 8th 04 08:24 PM |
| Marine Corps or Navy | [email protected] | Naval Aviation | 33 | October 31st 03 06:31 AM |
