Percent power altitude
Old October 21st 06, 05:33 PM posted to rec.aviation.ifr
Doug[_1_]
Default Percent power altitude
Anyone tell me at what altitude I get 75% and 65% power respctively
(with full throttle, normally aspirated).
Old October 21st 06, 07:00 PM posted to rec.aviation.ifr
Mitty
You don't have a POH?
On 10/21/2006 10:33 AM, Doug wrote the following:
Old October 21st 06, 07:46 PM posted to rec.aviation.ifr
Bob Moore
You know, he might not even have an airplane. He just asked
a question and expected an answer, not a wise crack.
No POH required, answer is not aircraft specific, see:
http://www.kellyaerospace.com/articl...bocharging.pdf
Bob Moore
Old October 22nd 06, 03:17 AM posted to rec.aviation.ifr
Mitty
Possibly Cessna and Piper have not seen your chart. I have several POHs he
An Arrow PA28R-201 POH shows 75% power, full throttle, at 6,000 feet/2400 RPM
and 7,500/2700 RPM. 65% power at about 9,800/2400 and 12,000/2700. (IO-360/200
Lyc.)
A Cessna 182T (T-model, not T for turbo) POH has tables that are a little harder
to read than the Arrow's graphs, but the highest % power they show at 8,000 feet
is 74% and at 12,000 feet 64%. (IO-540/230 Lyc.)
A carburated Cherokee Six/260 shows 75% power, full throttle, at 8,300 feet and
65% power at 11,200 feet. Engine RPM is not stated. (O-540/260 Lyc.)
I also have a tiny and very complicated power chart from Lycoming for the O-540
but I am too lazy to figure it out.
I am no fluid dynamicist (and may be about to prove it), but my dim
understanding is that the Reynolds number has a major effect on fluid flow and
in its calculation there is a density term. Certainly the mixture velocities at
various points in each different intake system would be different. Velocity is
also a term in the Reynolds number calculation. So (leaping) it does not
surprise me that intake systems with different geometries would perform at least
slightly differently at different altitudes. Exhaust systems, too, I'd guess.
Possibly I should have been more diplomatic in how I suggested that the OP
needed a POH but that still seems to me to be the case.
On 10/21/2006 12:46 PM, Bob Moore wrote the following:
Bob Moore
Old October 21st 06, 07:42 PM posted to rec.aviation.ifr
Bob Moore
See the graph at:
Bob Moore
Old October 21st 06, 09:01 PM posted to rec.aviation.ifr
john smith
In article .com,
Depends on the engine, depends on the OAT (density altitude).
Old October 21st 06, 09:10 PM posted to rec.aviation.ifr
Bob Moore
Not on the engine as long as it's "normally aspirated' as
specified in the OP.
Bob Moore
Old October 21st 06, 11:16 PM posted to rec.aviation.ifr
Jim Macklin
5 and 7 thousand
"Doug" wrote in message
respctively
Old October 22nd 06, 01:50 AM posted to rec.aviation.ifr
Bob Moore
Jim Macklin wrote
5 and 7 thousand
Running on (faulty) memory again, Jim?
How about 7,500' and about 12,500', ISA of course.
See my previous replies to this thread for a real chart
answer.
The formula answer is:
bhp at altitude equals bhp at sea level times the quantity
(density ratio minus the quantity(1 minus density ratio divided by 7.55))
Works out to 76% at 7,500' and 64% at 12,500', or thereabouts.
Bad information is worse than no information at all.
Bob Moore
Old October 22nd 06, 02:06 AM posted to rec.aviation.ifr
Bob Noel
OK, I'm confused. Full throttle, 64%, is 12,500' for any engine?
How come my cherokee 140 couldn't even get to 12,500'?
What am I overlooking?
Bob Noel
Looking for a sig the
lawyers will hate
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) Rich Stowell Aerobatics 28 January 2nd 09 03:26 PM
Backup Flight Data Recorder? Fox Two Soaring 14 August 27th 06 10:42 AM
The Deaf vs. The Colorblind Bret Ludwig Piloting 17 August 21st 06 03:08 AM
Catastrophic Decompression; Small Place Solo Aviation Piloting 193 January 13th 04 09:52 PM
Change in TAS with constant Power and increasing altitude. Big John Home Built 6 July 13th 03 04:29 PM
