Fiberglass revisited
Old October 29th 06, 03:11 AM posted to rec.aviation.homebuilt
Lou
Default Fiberglass revisited
I came across some fiberglass at 1.6oz per yard. I bought a small
sample to play with but it's an extremely fine weave. I've been using
the 1.45 oz e-glass for a while now. Can anyone tell me if this is just
as good, better or worse to use?
Lou
Old October 29th 06, 07:26 PM posted to rec.aviation.homebuilt
flybynightkarmarepair
Lou
It's harder to wet out. Strength should be the same, or better.
Old October 30th 06, 07:50 PM posted to rec.aviation.homebuilt
Bob Kuykendall
Earlier, Lou wrote:
...1.6oz per yard...
Just out of curiosity, what are you doing that requires such
lightweight glass?
Thanks, Bob K.
Old October 31st 06, 01:50 PM posted to rec.aviation.homebuilt
Lou
Well, I was putting my fuel tank together but ran out of the 1.45 that
I had from A/S
So I ordered some from another company just to try out. At the same
time I ordered some
..73oz and .5 just to play with. I was just a bit concerned when the
stuff I ordered was
extremely fine compared to the A/S stuff.
Lou
Fiberglass / Mold release advice requested Mark Zivley Home Built 10 April 3rd 04 12:15 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 1 November 24th 03 03:46 PM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 0 November 24th 03 04:52 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart D. Hull Home Built 0 November 22nd 03 07:24 AM
Fiberglass Tip Tanks Question Jay Honeck Owning 7 September 26th 03 05:23 AM
