I have a '79 Piper Warrior with a floor-mounted flap lever/trim wheel
and cover. The trim wheel has a metal needle pointing to a sticker on the cover to show "neutral". The only reason this matters is that setting the trim wheel/tab to neutral is part of the pre-flight checklist. The plastic cover was old and cracked so I replaced it, carefully noting where neutral was and (my mistake) re-used the old label. Whatever glue was left on the sticker after 25 years quickly faded and the sticker is now gone. I can replace it with a new one from a label maker, but I can only estimate where neutral is. My local FBO/shop says finding neutral is not simply the 1/2 point between full up and full down. You need protractors, string, and an advanced degree in Euclidean geometry. I'm not worried that the plane will violently pitch up or nose down on take-off, but it would be nice to set it properly. Any guidance on how to find the neutral position? Thanks!! --Jeff |
ps.com... Just put tape on the surface next to the pointer, make several landings, takoffs and mark each one on the tape. That will get you closer then any other way. After all, you only use the setting during the preflight to get you close on the trim setting. Once airborne you I would think that you would at least want to know what the factory marking indicated. Mine has a green band and the POH says that it MUST be in that range for takeoff. The neutral position of the elevator is somewhere in that range but it's not in the middle. If that's the case for the OP, wouldn't you want to mark the practical limits? Weight and CG is going to alter the "neutral" feeling position on takeoff and landing. I would use markable tape and mark it under several different flight regimes. I haven't flown a lot of different types but I have seen some that have just the neutral position indicated. I don't remember if the SOP was to set it at neutral no matter what. I know that solo, I want it to be near the forward end of the range of my green band. Fully loaded, I put it a little beyond the forward end of the range. Keeping it in the range and trimming a lot just after rotation just seems stupid to me. A little nose heavy is a good thing in my plane. When the engine quits, it pitches up significantly. ------------------------------- Travis Lake N3094P PWK |
I did. He was the one who told me about the protractors and string!
(Although the higher math degree was my add.) He said they don't even bother setting it to neutral but rather try hard to rely on the old sticker and position of the tab. Unfortunately, its too late for that since the wheel was already moved by a co-owner. --Jeff Michelle P wrote: Your best bet it to talk to your A&P and get the rigging procedures for the trim. That way it will be right. Setting it by flying will result in incorrect markings. Michelle P (A&P) |
The sticker for my overhead trim indicator fell off at one time, and I just glued it back in it's "approximate" position. I think you're probably over thinking this. Benford2's idea was probably as good as anyone's. I'd start with the center most position (half way between all the way forward and all the way back), and then do 5 or 6 take offs and landings and find what feels right. Then mark accordingly. I somehow doubt that Piper was that precise when they were applying the decals in the factory (especially since you can easily bend the little pointer). --- Jay wrote: I did. He was the one who told me about the protractors and string! (Although the higher math degree was my add.) He said they don't even bother setting it to neutral but rather try hard to rely on the old sticker and position of the tab. Unfortunately, its too late for that since the wheel was already moved by a co-owner. -- Jay Masino "Home is where My critters are" http://www.JayMasino.com http://www.OceanCityAirport.com http://www.oc-Adolfos.com |
Michelle P wrote: Your best bet it to talk to your A&P and get the rigging procedures for the trim. That way it will be right. Setting it by flying will result in incorrect markings. Michelle P (A&P) I know that there is a trim rigging procedure, but is there one for matching a particular trim setting to a particular position in the little window? Given the loose tolerances of the plastic trim wheel cover, I've always thought is was an approximation. I've flown a lot of Cherokees and one thing I've noticed is that the trim settings don't always match up from plane to plane. One of the questions I'll always ask the owner or instructor is where they normally set the trim for takeoff. John Galban=====N4BQ (PA28-180) |
My local FBO/shop
says finding neutral is not simply the 1/2 point between full up and full down. You need protractors, string, and an advanced degree in Euclidean geometry. And an answer like that would turn me off totally to that shop. True, it is not 1/2 way between the stops, but it also IS a simple procedure. Given the slop in the plastic cover and the variability of the pointer's position (when bent), why obsess? Fly it in still air and trim it off level. Mark that position and you are done. There is no need to go through complex and expensive procedures. Yes, it will change a bit with varying loads, power settings, altitude, and temperature. The neutral position is only approximate. So, approximate it! Good Luck, Mike |
| VFR position reporting | Mxsmanic | Piloting | 154 | November 26th 06 05:45 PM |
| GPS and old-fashioned thinking? | G Farris | Instrument Flight Rules | 92 | December 22nd 05 06:39 PM |
| Nearly had my life terminated today | Michelle P | Piloting | 11 | September 3rd 05 03:37 AM |
| New Piper Aircraft Designations | EDR | Piloting | 8 | October 27th 03 02:18 PM |
| USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 04:17 PM |
