Airliner landing technique
Old January 8th 05, 06:28 AM
Matt Whiting
Default Airliner landing technique
This isn't an IFR topic, but I figure there might be a heavy iron pilot
or two reading this. There's a thread on the FS group about landing
747/777 class airplanes. I've read that they typically kick out the
crab right before touchdown much as some lighter airplane pilots do.
Slips are out because of the risk of dragging an engine. However, a
number of folks there claim that the airliners are simply landed with
the crab angle held during the approach.
I know that the B-52 has gear designed to align for a crab landing and I
think one or two models of the 747 may have this as well, but everything
I've read always said that standard procedure with airliners was to
remove the crab before touchdown. And this is certainly what has been
done on almost all airline flights I've made.
Any '47 or '77 or similar pilots here who can comment on the generally
accepted technique for crosswing landings in the heavy machines?
I searched around this evening and found a number of sources that
claimed both methods are the "right" method, but no source that I'd
consider authoritative.
Matt
Old January 8th 05, 01:28 PM
I can't speak to the 747 or 777, but I can the 767 and L-1011. There is
always controversy about it, but the truth is in watching the autopilot do
an auto-land. It's all crab until about 150 feet, HAT, where the autopilot
goes into align mode; that is it transitions from crab to wing down into the
wind with a slight amount of upwind rudder. This last throughout the flare
to touchdown.
Good pilots manually land those models using the same technique. So long as
the certificated cross-wind limits are observed and the technique is done
correctly you won't scrape an engine.
The most critical airplane with which I was familiar for scrapping an
outboard engine was the 707. There, you had to observe a 5-degree bank angle
limit, so in a 30 knot cross-wind some combination slip and crab became
necessary. If it is just crab it is really tough to "kick it out" at the
last moment without it becoming a spectacular event.
Matt
Old January 8th 05, 04:06 PM
Matt Whiting
to touchdown.
Did you ever intentionally land with the crab angle intact? This is
what is advocated by a gentleman on the MSFS group who says he is a
retired "heavy" captain.
I searched on Avweb and found an article about this by Deakin. He also
advocates kicking out the crab on all airplanes up to and including the
747, unless they have gear designed to be landed in a crab (B-52 and a
few others). However, I don't think the folks on the simulator group
believe it.
Why would kicking out the crab become a spectacular event?
Matt
Old January 8th 05, 09:39 PM
Jon Kraus
The spectacular event would be touching down with the crab still in...
Jon Kraus
PP-ASEL-IA
Student Mooney Owner
autopilot do
autopilot
into the
flare
to touchdown.
long as
angle
believe it.
Matt
Old January 8th 05, 09:57 PM
Matt Whiting
Jon Kraus
PP-ASEL-IA
autopilot do
autopilot
into the
flare
to touchdown.
long as
done
bank angle
also advocates kicking out the crab on all airplanes up to and
including the 747, unless they have gear designed to be landed in a
crab (B-52 and a few others). However, I don't think the folks on the
simulator group believe it.
Matt
I suspect there is more to it than that, but we'll have to wait for
Tim's reply.
Matt
Old January 9th 05, 12:13 AM
I saw it done once in a 707 and I thought the landing gear was going to collapse.
"bush flying" in the suburbs? [email protected] Home Built 85 December 29th 04 12:04 AM
RAH'er has forced landing Ron Wanttaja Home Built 33 December 24th 04 01:58 PM
Diamond DA-40 with G-1000 pirep C J Campbell Instrument Flight Rules 117 July 22nd 04 06:40 PM
Cessna Steel Landing Gears, J-3 Seat Sling For Auction Bill Berle Home Built 0 February 19th 04 07:51 PM
Off topic - Landing of a B-17 Ghost Home Built 2 October 28th 03 05:35 PM
