Yak close call
Old December 27th 06, 06:19 PM posted to rec.aviation.piloting
gatt
Default Yak close call
http://www.youtube.com/watch?v=C2PvcG4Vmyw
Old December 27th 06, 06:37 PM posted to rec.aviation.piloting
Paul Tomblin
Yikes.
Paul Tomblin http://blog.xcski.com/
Once we've got the bugs ironed out, we'll be running on flat bugs
Old December 27th 06, 06:50 PM posted to rec.aviation.piloting
Kingfish
Two observations he
1. He did better than that F-16 pilot that splatted his jet on the
ground
2. Whaddya think would happen if is insurance agent saw that clip?
Old December 27th 06, 08:28 PM posted to rec.aviation.piloting
Robert M. Gary
Kingfish wrote:
Two observations he
ground
The difference wasn't pilot skill, it was how fast he was coming down.
Probably a math error, probably didn't correctly add field elevation to
his top altitude.
Probably couldn't get insurance.
Old December 27th 06, 08:39 PM posted to rec.aviation.piloting
Newps
Nothing. There wasn't a loss.
Old December 28th 06, 12:23 AM posted to rec.aviation.piloting
Dave[_5_]
He was awful close to a prop strike - at the very least. Perhaps it was
intentional - note that he did a roll right after the near miss. I
don't think that anyone who had just had an unintentional near miss
could regain his composure so quickly.
Old December 28th 06, 12:27 AM posted to rec.aviation.piloting
Newps
Old December 28th 06, 12:29 AM posted to rec.aviation.piloting
Newps
He was awfully close to death but that's not relavant as far as
insurance is concerned.
Old December 28th 06, 12:57 AM posted to rec.aviation.piloting
Morgans[_5_]
Although he was way too close, there is a possibility that he was not as
close as you think. I saw another performer that looked like he was way too
low, even below the runway.
Is it possible that there is a dip, and the runway is lower than the
surrounding ground?
Still, no loss, no claim, no foul.
Jim in NC
Old December 28th 06, 01:20 AM posted to rec.aviation.piloting
Dudley Henriques
"Morgans" wrote in message
too low, even below the runway.
surrounding ground?
Jim in NC
No, that was close Jim. In fact, you don't get closer than that and fly out
of it. In any low altitude vertical recovery, you only have X amount of
radial g to play against Y amount of remaining air under the airplane. At
the top gate apex, you need the exact airspeed through the gate that has
been predermined against the gate altitude AGL to produce the downline
within that available radial g. If you are slow inverted through the gate at
your apex, you can generate nose rate which puts you mushing through with a
vertical component you definitely don't want. If you are fast through the
gate, you get an extended arc on your downline pull that can easily kill you
at the bottom.
This guy looked slow through the apex pull which was real bad. He added to
the problem with a quarter roll on his downline to his exit heading. Going
through a vertical downline in a low altitude vertical recovery will nail
you every time. As he finished the quarter roll, he was running out of air
and radial g at the same time. Past a certain point, you enter mush as you
climb the angle of attack curve.
This guy was one lucky SOB! In the Yak, as in the Mustang, when you get it
THAT low during a pull, you have a forward ground visual cue that is far
enough ahead of the aircraft you can easily miss exactly how low you
actually are to the ground.
I'd be willing to bet two things on this one with a real good chance of
winning. First, that during the pull through his low apex he didn't actually
realize how low he was, and secondly, that had he been checking his
peripheral cues at the lower corners of the windshield through the low apex,
he would have soiled his drawers :-)
I'm glad he made it. You don't get many second chances in the low altitude
acro business!
Dudley Henriques
Air Force One Had to Intercept Some Inadvertent Flyers / How? Rick Umali Piloting 29 February 15th 06 05:40 AM
Close encounter with a Blackhawk today Michelle P Piloting 8 May 20th 05 03:08 AM
Reamed out by Approach Bob Chilcoat Piloting 26 March 29th 05 01:32 AM
Comming close Tony Owning 17 May 18th 04 07:22 AM
Veteran fighter pilots try to help close training gap Otis Willie Military Aviation 0 December 2nd 03 11:09 PM
