forgotten trig for climb angle...
Old January 28th 07, 11:54 PM posted to rec.aviation.piloting
xerj
Default forgotten trig for climb angle...
I remember that sin c = excess thrust/weight
What step do I then do to convert sin c into degrees above the horizon?
TIA
Old January 29th 07, 12:21 AM posted to rec.aviation.piloting
Tony
You simply want to know what angle has that sine. arc sin (c) would be
the function on the calculator you're looking for.
TIA
Old January 29th 07, 12:40 PM posted to rec.aviation.piloting
xerj
Ahhh that's right!
Thanks.
"Tony" wrote in message
TIA
Old January 29th 07, 01:05 PM posted to rec.aviation.piloting
Tony
You can make it a little easier on yourself, for small angles just
multiply the sine by 57. For example, a 10 degree climb angle is
pretty steep. sin(10) is 0.1736. The approximation I mentioned would
return 9.9 degrees (that's because for small angles sin(angle) is
pretty much equal to tan(angle) and to the angle itself if measured in
radians.
j" wrote:
Ahhh that's right!
Thanks.
"Tony" wrote in ooglegroups.com...
TIA- Hide quoted text -- Show quoted text -
Old January 29th 07, 01:33 PM posted to rec.aviation.piloting
John T
ups.com
radians.
Cockpit math is hard enough. Cockpit trigonometry? Are you kdding??
John T
http://sage1solutions.com/blogs/TknoFlyer
Reduce spam. Use Sender Policy Framework: http://openspf.org
____________________
Old January 29th 07, 02:08 PM posted to rec.aviation.piloting
Tony
Sorry, I lost my head!
And my wife balances the checkbook. Go figure. (pun intended).
On Jan 29, 7:33 am, "John T" wrote:
"Tony" wrote in oglegroups.com
radians.Cockpit math is hard enough. Cockpit trigonometry? Are you kdding??
John Thttp://sage1solutions.com/blogs/TknoFlyer
Reduce spam. Use Sender Policy Framework:http://openspf.org
A Level 1 AOA clarification Ramapriya Piloting 64 January 9th 05 02:19 AM
Bending extruded angle Veeduber Home Built 8 August 29th 04 01:58 AM
Angle of climb at Vx and glide angle when "overweight": five questions Koopas Ly Piloting 16 November 29th 03 11:01 PM
Coordinated turning stall and spins Chris OCallaghan Soaring 20 November 18th 03 09:46 PM
Lift and Angle of Attack Peter Duniho Simulators 9 October 2nd 03 11:55 PM
