Cloud Flying
Old March 17th 07, 07:01 PM posted to rec.aviation.soaring
Default Cloud Flying
Does anyone still do this? It is illegal in the USA but does anyone do
it anywhere else? Be glad to have any info about articles/accounts of
people who have done this.
Also has anyone been able to climb up the sunny side of a cumulus
cloud? Read somewhere that one famous glider pilot did this and he
said it was the flight of his life.
TIA
George (ex-kestrel254)
Old March 17th 07, 07:43 PM posted to rec.aviation.soaring
Erik Braun
In Germany, too, AFAIK.
I did this twice on different occasions. It isn't always the sunny side you
can climb, but the upwind one.
The first time was several years ago over a power plant with a special
cooling tower that provides great thermals. While circling around a kind of
cloud hose, another Cu showed up about 300 ft below me. Because of strong
wind that day, I flew to the upwind side of it and was able to climb a few
hundred feet above cloud level in front of the quickly building cloud.
It was very similar to ridge soaring but without fear of catching a tree or
rock.
Another time I found very different cloud base altitudes at the border of
two different masses of air. Flying from the higher cloud base in the
direction of the lower one against the wind, I found laminar lift without
seeing a cloud near me. At first, I thought I had found wave, but a Cu
built some minutes later directly below me.
I think, an important thing for trying this kind of gliding is strong wind
at the level of cloud base and strong thermals with a small diameter. The
climbing thermal then pushes a bumb into the airflow of the wind which can
be used like a ridge or wave.
I'm not a famous glider pilot but I hope to have helped.
Greetings from southern Germany, Erik.
TIA
Old March 17th 07, 09:52 PM posted to rec.aviation.soaring
rock.
TIA
George (ex-kestrel254)- Hide quoted text -
- Show quoted text -
Erik
thanks for this. the occasion you mentioned where there were two
dofferent airmasses sounds like a sea-breeze front which I have only
flown once in my life. On gets theses at Lasham occasionally with one
airmass from the north and the sea air coming in from the south. IIRC
I flew figure-of-eights to stay up.
Thanks
George
Old March 17th 07, 09:53 PM posted to rec.aviation.soaring
On 17 Mar, 19:22, Jack wrote:
Does anyone still do this? It is illegal in the USA....
Do not make that assumption. It can be done legally in the USA.
Certain requirements must be met.
This has been dealt with extensively on this News Group twice in the
last year -- check the archives.
Jack
Thanks jack. Will take a look
George
Old March 18th 07, 04:01 PM posted to rec.aviation.soaring
Jack
George
yes, cloud flying is perfectly legal in the US. You simply have to
equip the glider in accordance with the POH (certified) or Operating
Limitation (Experimental). If the POH or Op. Lims dont allow it then
you cannot do it in that glider. Then you have to meet the currency
requirements of Part 61 and have an instrument rating in Single or
Multiengine Airplanes, or an ATP.
Shawn Knickerbocker flies clouds in Florida in his Nimbus, he
presented at the convention in Memphis and had his glider on display,
it was quite amazing. The climb rates are phenomenal, you really dont
have to spend that much time in the cloud. with 3-5k fpm climbs you
can cruise!
Old March 20th 07, 02:01 AM posted to rec.aviation.soaring
Mike Schumann
I would assume that you need to be flying IFR with all the attendant issues
(equipment, talking to ATC, etc...)
Mike
Jack
George
can cruise!
Posted via a free Usenet account from http://www.teranews.com
Old March 21st 07, 04:39 AM posted to rec.aviation.soaring
of course, and they really aren't "issues" Pretty standard flying for
many pilots.
Cloud Flying Shawn Knickerbocker Soaring 1 August 26th 06 07:40 PM
Cloud Flying Shawn Knickerbocker Soaring 0 August 24th 06 11:17 AM
Cloud Flying Shawn Knickerbocker Soaring 0 August 24th 06 11:11 AM
Cloud Flying Shawn Knickerbocker Soaring 0 August 24th 06 11:02 AM
Cloud Flying Shawn Knickerbocker Soaring 0 August 24th 06 10:53 AM
