Cessna Launches Light Sport Aircraft Program
Old July 10th 07, 06:49 PM posted to rec.aviation.homebuilt
Default Cessna Launches Light Sport Aircraft Program
Just released information on their new plane.
http://cessna.com/news/article.chtml...Uh6JfkkJNoEMTK
Larry Fitzgerald
Old July 10th 07, 08:19 PM posted to rec.aviation.homebuilt
Gig 601XL Builder
Larry Fitzgerald
IMHO, The best thing about Cessna getting into the LSA market is not the
aircraft they will produce. The more important aspect is that it lends a
certain amount of legitimacy to LSA.
Old July 11th 07, 03:16 AM posted to rec.aviation.homebuilt
On Tue, 10 Jul 2007 13:19:27 -0500, "Gig 601XL Builder"
....and will generate a nice healthy batch of used ~ 100 HP engines for the small
homebuilders to install. A-65s are getting pretty long in the tooth.
Old July 11th 07, 03:23 AM posted to rec.aviation.homebuilt
cavelamb himself
The one in the T-Cart I used to fly was built in 1939.
Still runs just fine.
Old July 11th 07, 04:10 PM posted to rec.aviation.homebuilt
Mine's a 1946. Just finished regrinding the crank. Getting
plenty tired otherwise.
Dan
Old July 11th 07, 09:25 PM posted to rec.aviation.homebuilt
Ken Finney
small
Ron-
I was looking at one of your books in Borders last night, and then wondered
if I can get one direct from you, signed by the author?
Old August 26th 07, 01:37 AM posted to rec.aviation.homebuilt
Bret Ludwig
The last thing a modern experimental needs is an "AIRCRAFT ENGINE".
A modern "AIRCRAFT ENGINE" is a P&W PT-6. Half a mil last time I
checked.
Piston aircraft engines made for that purpose are museum pieces.
The Harley Davidson V-twin is also a museum piece, but it's a museum
piece made in some considerable quantity, and it will put out more
sustained power longer than any Continental before the 0-200, and the
engine with a belt redrive is, if overpriced, at least something you
can count on parts being available for for awhile, from NON-AVIATION
sources.
Aviation means turbine and corporate money. It basically did in 1980,
and it almost exclusively does today, and it absolutely will tomorrow
unless there is a massive change from globalism and outsourcing and
the extirpation of the middle class in America. LSA is a sop to keep a
few cranks quiet, and if you buy some thing designed just for that
market you can expect it to be both heinously expensive and all of a
sudden not available when you need it.
Motorcycles and little airplanes were niche items for nuts in 1950.
The bikers had Evel and Sonny and the aviators had a Polack in
Milwaukee. Funny how it worked, accordions went out of favor, and so
did little airplanes.
Old August 26th 07, 05:11 AM posted to rec.aviation.homebuilt
Morgans[_2_]
sources.
Check your facts. The Harley engine that makes 100 HP is a modified engine,
and therefore unlikely to be able to come close to sustained 100 HP on an
extended time period test.
Jim in NC
New discussion forum for Sport Pilots and Light Sport Aircraft [email protected] Piloting 6 February 25th 06 07:51 PM
New discussion forum for Sport Pilots and Light Sport Aircraft [email protected] Owning 0 February 9th 06 08:16 PM
Sport Pilots and Light Sport Aircraft gilan Piloting 5 December 21st 05 12:37 PM
Light-Sport Aircraft / Sport Pilot group gilan Piloting 0 November 13th 05 05:53 PM
Light-Sport Aircraft / Sport Pilot group gilan Owning 0 November 13th 05 05:53 PM
