Someone sent me a B-58 Hustler patch with a white background. I'd like to
trim the white background out and just leave the patch. I tried PaintShopPro but the only method I see is laboriously and carefully delete the white. Does someone here have a program to delete just the background? I'll post it here. It's very large but I'd like to edit the background out before I reduce the size. Thanks. Darrell R. Schmidt B-58 Hustler Web Site http://members.cox.net/dschmidt1 USAF Pilot Class 55-I Web Site http://pilotclass55india.org |
On Thu, 9 Aug 2007 13:14:11 -0700, "Panic" wrote:
Someone sent me a B-58 Hustler patch with a white background. I'd like to trim the white background out and just leave the patch. I tried PaintShopPro but the only method I see is laboriously and carefully delete the white. Does someone here have a program to delete just the background? I'll post it here. It's very large but I'd like to edit the background out before I reduce the size. Thanks. Darrell R. Schmidt B-58 Hustler Web Site http://members.cox.net/dschmidt1 USAF Pilot Class 55-I Web Site http://pilotclass55india.org I'm not sure of your purpose--are you trying to simply paste it on another image, as I've done here with a B58 pic somebody else had posted? Let me know. In any case, I've also attached a PSP file of the patch with a transparent background. There are several easy ways of creating it. I'm also guessing that a more savvy PSP or Photoshop user will know the easiest way! |
Just Plane Noise wrote in
: On Thu, 9 Aug 2007 13:14:11 -0700, "Panic" wrote: Someone sent me a B-58 Hustler patch with a white background. I'd like to trim the white background out and just leave the patch. I tried PaintShopPro but the only method I see is laboriously and carefully delete the white. Does someone here have a program to delete just the background? I'll post it here. It's very large but I'd like to edit the background out before I reduce the size. Thanks. Darrell R. Schmidt B-58 Hustler Web Site http://members.cox.net/dschmidt1 USAF Pilot Class 55-I Web Site http://pilotclass55india.org I'm not sure of your purpose--are you trying to simply paste it on another image, as I've done here with a B58 pic somebody else had posted? Let me know. In any case, I've also attached a PSP file of the patch with a transparent background. There are several easy ways of creating it. I'm also guessing that a more savvy PSP or Photoshop user will know the easiest way! use photoshop and save it as a png file |
"Panic" wrote in message ... Someone sent me a B-58 Hustler patch with a white background. I'd like to trim the white background out and just leave the patch. I tried PaintShopPro but the only method I see is laboriously and carefully delete the white. Does someone here have a program to delete just the background? I'll post it here. It's very large but I'd like to edit the background out before I reduce the size. Thanks. Darrell R. Schmidt B-58 Hustler Web Site http://members.cox.net/dschmidt1 USAF Pilot Class 55-I Web Site http://pilotclass55india.org Here's a low res tif file if you can use it. I can send this at about 4mb size if it works out. TP |
"muff528" wrote in message
news:dZNui.20530$ug3.19866@trnddc06... "Panic" wrote in message ... Someone sent me a B-58 Hustler patch with a white background. I'd like to trim the white background out and just leave the patch. I tried PaintShopPro but the only method I see is laboriously and carefully delete the white. Does someone here have a program to delete just the background? I'll post it here. It's very large but I'd like to edit the background out before I reduce the size. Thanks. Here's a low res tif file if you can use it. I can send this at about 4mb size if it works out. TP I tried opening it in PaintShopPro and it wouldn't work. In Windows Picture and Fax Viewer it came out with light pastel colors and not much detail. If you would try sending me that 4mb file I'll see how that one works. |
On Thu, 9 Aug 2007 17:16:09 -0700, "Panic" wrote:
"muff528" wrote in message news:dZNui.20530$ug3.19866@trnddc06... "Panic" wrote in message ... Someone sent me a B-58 Hustler patch with a white background. I'd like to trim the white background out and just leave the patch. I tried PaintShopPro but the only method I see is laboriously and carefully delete the white. Does someone here have a program to delete just the background? I'll post it here. It's very large but I'd like to edit the background out before I reduce the size. Thanks. Here's a low res tif file if you can use it. I can send this at about 4mb size if it works out. TP I tried opening it in PaintShopPro and it wouldn't work. In Windows Picture and Fax Viewer it came out with light pastel colors and not much detail. If you would try sending me that 4mb file I'll see how that one works. Mine should have worked for you, especially since it was a PSP image. Did you try it? |
OOPS! tried to upload "too big" file.
check your email -- png file seems to work ok in paint shop. TP |
Try this....it's a TIFF from Photoshop, and it has a transparent background
layer. Sorry for the size! I had to shrink it a little to make it upload! |
| Thread Tools | |
| Display Modes | |
| Patch | Jim[_10_] | Naval Aviation | 3 | May 24th 07 11:52 AM |
| USAF(?) unit patch ID | Allen Thomson | Military Aviation | 63 | June 18th 05 08:48 PM |
| MS FS2004 - No CD patch | Silent Bob. | Simulators | 15 | December 2nd 04 10:16 PM |
| FS2004 patch | Mike Kirkland | Simulators | 9 | October 19th 04 06:57 AM |
| No CD Patch | Dave Schwartz | Simulators | 5 | April 20th 04 01:10 AM |
