No wing runner?
Old August 23rd 07, 04:21 PM posted to rec.aviation.soaring
JJ Sinclair
Default No wing runner?
OK, you just landed at a deserted strip and called for an aero-
retrieve, but there's nobody around to run your wing.
Been there, done that, and it wasn't pretty! I put the right wing down
and aimed the fuselage 30 degrees left of runway heading, hooked up
the rope, climbed in and crossed my fingers! As expected, the drag
from the down wing swung the nose to the right, but I almost nailed a
runway light before aileron control kicked in and I was able to get
the right wing up. There's got to be a better way!
For several years, now I have carried a wing tip wheel that I use for
wing-runner-less, aero-retrieves. It consists of a padded aluminum
glove that slips over the leadind edge and is held in place with duct-
tape. The wing tip is raised about 6" off the ground which is high
enough to avoid gravel and low weeds. I once used it at strip that was
only 40 feet wide. I placed the main gear 7 feet from the runway
lights on the right and my tip wheel 7 feet from the lights on the
left. She rolled straight as an arrow!
Several pilots have asked me to make them one of my tip wheels, so I
finally ordered the parts and made a batch of 10 units. Assembled, it
measures 8" X 8" X 6". Remove the hinge pins and slip the 5" wheel
inside the glove and the height is reduced to only 2" for easy
storage. E-mail me for photos, price is set at $125 and I'll pay the
shipping (US).
JJ Sinclair
Old August 23rd 07, 10:30 PM posted to rec.aviation.soaring
Philip Plane
In article . com,
A solution that I've seen used a bit is to carry a large rubber sucker,
nearly the size of a plumbing plunger, and a piece of dowel/bambo/PVC pipe
of the appropriate length for your glider. When you need it you stick
the sucker under the wingtip and poke the support in. As you take off
the support either falls out (wood or bamboo are bio degradable) or
just dangles there till you get home.
This saves scouring the area for a suitable support for the wing. It has
its drawbacks though. The retrieve stories are much less interesting
than the ones that involve creative use of local resources.
We have this in the clubs Duo, but I've never used it. I get the student
to run the wing and leave them behind.
Philip Plane _____
Glider pilots have no visible means of support
Old August 23rd 07, 11:59 PM posted to rec.aviation.soaring
Andy[_1_]
Me too and decided never again. I built a compact tip wheel from a
rectangle of sheet aluminum, 2 short length of aluminum angle section,
and a roller blade wheel. It took about an hour to make form scrap I
had on hand. It's pre-prepared with double sided carpet tape and
wrapped with enought tape to fair it. It can be stuck under either
wing tip in a minute or so. It tested ok on a paved runway but may
not stand up to a rough strip. The adavantage of the flat plate
design over a shaped leading edge cuff if that it fits both wings.
Disadvantage more likely to get knocked off.
Andy
Old August 24th 07, 06:58 PM posted to rec.aviation.soaring
Andy
I use any handy local vegetation (commonly called "a stick")
Prop up the wing with that.
Get in...
Ask Tow plane to hang on the brakes and do a full power run up before
releasing brakes.
Hold onto your brake as the tension comes on.
Release brake and your off..
The "stick" is bio de-gradable too.
Regards
Al
Old August 27th 07, 12:50 PM posted to rec.aviation.soaring
Andy[_1_]
On Aug 24, 9:58 am, "
I have also use the stick method. One time there was a suitable
source, the stick stayed in place, and I did a perfect takeoff. The
only other time I tried it the wing dropped immediately and I had to
abort. Then a farm worker showed up and, even though we had no
language in common, I was able to show him how to be more reliable
than the stick.
It's often hard to find suitable sticks in Arizona, creosote bush is
about the only source in many places. I had thought of carrying
suitable lengths of dowel in the glider but decided the stick on tip
wheel would be better, at least for paved runways. So carry a tip
wheel for paved runways and dowels for unprepared surfaces?
Andy
Old August 25th 07, 01:30 AM posted to rec.aviation.soaring
Andy Blackburn
I am working on a set of small, throttleable rocket
motors at each wingtip, controlled by a computer tied
into a gyroscopic inertial platform in the luggage
area - but the stick seems like a good idea too.
9B
for an aero-
tip wheel from a
angle section,
make form scrap I
carpet tape and
under either
runway but may
the flat plate
fits both wings.
Andy
I use any handy local vegetation (commonly called 'a
stick')
Get in...
run up before
releasing brakes.
The 'stick' is bio de-gradable too.
Regards
Al
Old August 26th 07, 12:54 AM posted to rec.aviation.soaring
JJ Sinclair
Last year a couple of local pilots landed at a very dusty strip
(little more than a road in the middle of a pasture) and called for
areo-retrieves. Using the first-to land; first-to-tow rule; No. 1 gets
no. 2 to run his wing. No. 1 goes IFR in dust, but is able to keep his
wings level by looking sideways (down the wing).
No. 2 tried it without a wing runner, went IFR and didn't realize he
was into a full blown ground loop, until it was too late. No. 2's ship
spent the Winter in the repair shop!
Guess who just ordered one of my wing tip wheels?
JJ
Old August 26th 07, 01:57 AM posted to rec.aviation.soaring
Eric Greenwell
I say No. 1! Next time he lands out with another pilot, he talks No. 2
into running his wing by loaning him the wing tip wheel.
Did anyone consider shortening the tow rope, so the dust is kicked up
behind the glider? I know, it might be only 60' long, but I'm told the
Poles use short ropes for field retrieves.
* "Transponders in Sailplanes" http://tinyurl.com/y739x4
Old August 26th 07, 10:58 PM posted to rec.aviation.soaring
Uri
Maybe the Poles just use long poles?
(sorry....couldn't resist)
Uri
4X-GGG
Old August 27th 07, 04:06 AM posted to rec.aviation.soaring
Mike the Strike
I remember well using the stick technique with my Jantar-1. As the
glider starting moving, the wing fell onto the ground with a thud,
pulled me off the runway and I only just managed to avoid a ground-
loop by aggressively using full rudder and aileron.
A later similar attempt in my ASW-20 wasn't much better. I now refuse
to try a field retrieve with my present ship without a wing runner and
think the stick-on wheels are a great idea.
Mike
Soft field landings - low wing vs high wing aircraft Justin Gombos Piloting 19 May 23rd 07 06:21 AM
Books on Military Rotary Wing to Civilian Fixed Wing Transition? Greg Copeland Piloting 5 May 2nd 07 04:23 AM
Anyone building/flying a Ridge Runner? Russell Duffy Home Built 10 September 16th 05 03:58 PM
High wing to low wing converts...or, visa versa? Jack Allison Owning 99 January 27th 05 12:10 PM
Mylar tape wing seals - effect on wing performance Simon Waddell Soaring 8 January 1st 04 04:46 PM
