I own a bicycle shop and we use cable lube on all tune
ups. When a cable goes over a pulley or through housing, there is friction and wear. The original rudder cables off my Libelle (replaced) were braided over hemp rope. This reduces internal friction and holds lube. Lubing the cable will make a big difference on the brakes and rudder. You can get wax type lubes that don't pick up and hold grit, as grit on the cables can cause wear also. Cable lube will prevent internal corrosion which causes wear and lots of friction. On older gliders the brake cable is a moped or bicycle cable. Replace the cable and housing with a modern coated cable with teflon lined housing. Prelube the cable before installing and you will get much more stopping power to the wheel. |
| Thread Tools | |
| Display Modes | |
| Maintenance | Steve Freeman | Soaring | 9 | November 29th 07 04:08 PM |
| SZD55 Maintenance | icsonka | Soaring | 6 | October 13th 06 06:13 AM |
| What do you do about maintenance? | Andrew Gideon | Owning | 5 | July 2nd 06 05:00 PM |
| Maintenance Manuals | RST Engineering | General Aviation | 6 | April 4th 05 07:47 PM |
| B-25 Maintenance | Randy | Military Aviation | 1 | July 11th 03 04:37 AM |
