airbrake question
Old December 2nd 03, 10:06 AM
miso
Default airbrake question
Does the airbrake put it's force on the center of gravity of the
plane? If not, how does the pilot compensate for the force? [Yeah, I
know, there are no dumb questions, though maybe I'm asking one or
two.]
Old December 2nd 03, 04:26 PM
John R Weiss
"miso" wrote...
In some airplanes there is a cable interconnect between the airbrake and the
elevators that will compensate for pitching moments caused by the airbrakes.
Otherwise the pilot simply uses the stick/yoke to compensate for small changes.
After a pilot has flown a particular airplane type for a while, he naturally
adjusts when he uses the airbrakes.
Old December 3rd 03, 05:06 AM
miso
Thanks to both replies. I was thinking of the F15, so I thought it
might be the center of gravity. I'm going to see if I can find photos
of the other models mentioned.
"John R Weiss" wrote in message news:La2zb.392545$HS4.3201917@attbi_s01...
"miso" wrote...
Old December 3rd 03, 05:39 PM
Tarver Engineering
"miso" wrote in message
om...
Yes, a fighter speed brake is completely different from most of the replies
you got. A fighter has the speed brake on the fue forward of the tail and
it is only similar in name to a "spoiler deployed as a speedbrake".
Old December 3rd 03, 11:53 PM
Ed Rasimus
On Wed, 3 Dec 2003 08:39:19 -0800, "Tarver Engineering"
. com...
John, once again you illustrate the problem with usenet. "on the fue"?
"spoiler deployed as a speedbrake"?
Seriously, the 102 and 106 certainly didn't have it deployed "forward
of the tail" and those are the airplanes you were involved with in the
FAT ANG. The 105 didn't have it "forward of the tail" and the F-16
among current equippage doesn't have it "forward of the tail" either.
Some do. The F-15 certainly is forward and the F-111 was certainly
forward.
As for "spoiler deployed as a speedbrake"--that doesn't happen on any
fighter type that I've encountered. Certainly some tactical aircraft
used spoilers, primarily as a design counter to adverse yaw, but none
with spoilers have a choice of control surface or speed brake
function. Airliners do.
Tell me again about your fighter experience.
Speed brakes on fighters are single function surfaces.
Old December 4th 03, 12:07 AM
Tarver Engineering
"Ed Rasimus" wrote in message
. com...
replies
and
forward.
As does the F-18.
That does cause one to wonder why there was such a lengthly discussion of
airliner type speedbrakes.
The selection capability is however there for those tactical aircraft using
an actual "speed brake", as opposed to a "spoiler deployed as a speedbrake".
Exactly as I wrote, but thanks for playing.
Old December 4th 03, 04:35 AM
B2431
.com...
forward.
The term "fue" was to prove he's in the right clique I guess.
As for his fighter experience he was a engine mechanic on F-106s which, with
his EE degree, makes him an expert on everything aerospace, automotive etc as
he is fond of saying in several newsgroups.
Dan, U.S. Air Force, retired
Old December 2nd 03, 08:50 PM
Dudley Henriques
om...
two.]
There were no noticeable pitch changes that I've ever encountered with speed
brakes at any speed in the aircraft I've flown that had them. I should note
that on the F14, although there's no speed restriction on the brakes, they
will begin a blowback at 400kts.
It's interesting as well to note as to your question about pitch change,
that some designs like the Turkey, deploy both ways in pitch, but I've not
had a problem in the Talon either, and that is a split brake under the
fuselage. The 86 deploys on both sides rear; no problem there either that I
could see. It's interesting about the Thud's design as Ed has noted. That
flower back there extending into a circumference of the airstream must
create one hell of a linear deceleration.
Dudley Henriques
International Fighter Pilots Fellowship
Commercial Pilot/ CFI Retired
For personal email, please replace
the z's with e's.
dhenriquesATzarthlinkDOTnzt
Old December 2nd 03, 09:13 PM
WaltBJ
Air brake - speed brake is generally what we called it - has an effect
depending on how far it is above or below plus distance aft of the
center of gravity and the angle at which it meets the airstream. The
only aircraft I ever flew which had a pronounced reaction was the F86
Sabre - its speed brakes were mounted above the center of gravity and
had an axis of rotation canted forward. The plane would pitch up
noticeably on s/b extension, increasing with airspeed, and you learned
to deal with it. On occasion you might be flying the wing of a leader
(usually a desk pilot)who was shall we say out of practice and he'd
forget to signal (open and closing of hand much like a duck's bill
imitation followed shortly by nod of head for execution). he would
open his brakes and promptly have his wingmen struggling to get back
in formation - idle power, speed brakes, severe crossed controls to
generate drag.) Rather exciting in the weather, especially if he had
just dropped the nose to enter a jet penetration instrument letdown.
F102 had slight reaction (up), 104 even less, F4 about the same as
104. Air liners normaly have s/b (spoilers) on top of wing about on
the CG so any reaction is minimal. However, some, like the 727, say
'no speed brake use with flaps extended' since loss of lift because of
turbulence behind the s/b results in aero center shifting aft
resulting in a marked nose-down reaction and loss of altitude. Not
good on approach.
Walt BJ
VOR/DME Approach Question Chip Jones Instrument Flight Rules 47 August 29th 04 06:03 AM
A question on Airworthiness Inspection Dave S Home Built 1 August 10th 04 06:07 AM
Question Charles S Home Built 4 April 5th 04 10:10 PM
Tecumseh Engine Mounting Question jlauer Home Built 7 November 16th 03 02:51 AM
Question about Question 4488 [email protected] Instrument Flight Rules 3 October 27th 03 02:26 AM
