Anti-Ice on Combat Aircraft
Old December 14th 03, 06:43 AM
Charles Talleyrand
Default Anti-Ice on Combat Aircraft
We have an A-4 and a B-52 on the airport here. Neither seems to have
an anti-ice system as far as I can see (of course the B-52's wing is rather
above my head, and currently covered in snow).
Do Air Force/Navy planes have de-ice equipment? What happens
when the radar dome gets coated in ice while flying through cold clouds?
-Thanks
Old December 14th 03, 05:20 PM
John Pelchat
"Charles Talleyrand" wrote in message ...
-Thanks
Charles,
I am not sure about the specifics for the B-52 or the A-4, but many
jets use hot bleed air ducted from the engine(s) to warm the leading
edge and thus prevent/remove ice building on up wings and other
aero-surfaces. Pneumatic boots common on (piston and jet) prop
aircraft have problems at higher jet speeds (probably related to drag
and durability). Maybe a few scooter, buff, and blow-torch drivers
will elighten us all.
Best to all
John Pelchat
Old December 14th 03, 09:02 PM
John R Weiss
"Charles Talleyrand" wrote...
IIRC the A-4 had engine anti-ice and heated windscreen and pitot tube. No wing
anti-ice. Don't know about the B-52.
Engine anti-ice is necessary in more environmental conditions than is wing
anti-ice. WAI installations are also comparatively heavy and power-hungry.
FWIW, I turned on the WAI in the 747 for the second time in 5 years just the
other day -- more out of curiosity than need; we use nacelle anti-ice routinely.
We were picking up a bit on the descent into ANC, and wanted to see if it made
any difference. Found that the ice on the outboard leading edges melted
first...
Old December 14th 03, 11:08 PM
BUFDRVR
wing
The B-52 uses bleed air to prevent ice build up on the inlets, inlet guide
vanes, EPR inlet probes and, on the H model, the cowling. I'm not sure if you
can see anything visably though, most of it is internal.
BUFDRVR
"Stay on the bomb run boys, I'm gonna get those bomb doors open if it harelips
everyone on Bear Creek"
Old December 14th 03, 11:27 PM
Bob Liberty
Think the 135 was similar
ole nav
"BUFDRVR" wrote in message
No
wing
you
BUFDRVR
harelips
Old December 16th 03, 12:09 AM
ole nav
No
wing
you
BUFDRVR
The Argus (ASW aircraft slightly bigger than a C-130) was used in
severe icing conditions (low level over the North Atlantic) and
was well equipped with anti-icing and deicing equipment. They had
huge gas fired heaters (600 BTU each) one for each wing and one
for the tail, plus a 300 BTU one for cabin heating. They also had
numerous anti-ice mats for cowlings and other air-scoops plus
electrical prop deicers and 'Nesa windscreens'. I've flown
through some horrendous icing conditions believe me. The
replacement aircraft for the Argus (P-3 Aurora/Orion) has great
wing anti-icers utilizing engine bleed air, very effective
indeed.
-Gord.
"I'm trying to get as old as I can,
and it must be working 'cause I'm
the oldest now that I've ever been"
Old December 16th 03, 02:10 AM
Ron
indeed.
-Gord.
Low level severe icing, over the north atlantic in the winter, does not sound
like something for the faint of heart...
Ron
Pilot/Wildland Firefighter
Old December 16th 03, 06:40 AM
WaltBJ
The only fighter I ever flew with surface anti-ice was the F86D/L. The
only time I ever heard of anybody in the outfit using it he got
serious damage to electrical circuitry inside the wing from a break in
the ducting.
FWIW if the indicated airspeed is around 300 knots the ram temp rise
is high enough to prevent icing. Most jets I know of do have engine
anti-ice and heated windscreens.
Walt BJ
Old December 17th 03, 01:36 AM
Scet
"Gord Beaman" wrote in message
ole nav
No
wing
guide
if
you
BUFDRVR
indeed.
-Gord.
The engines on the P3 also Anti-ice "themselves". One switch per engine
opens two solenoid valves, one of which directs air to the air scoop, the
other causes a pressure imbalance in two valves fitted at the nine and three
o clock positions on the air inlet housing. These two valves anti-ice the
air inlet housing, IGV's CIP and CIT probes and the torque meter shroud. The
solenoids are energised closed so are fail safe. Two thermal switches wired
in series, are fitted to the air scoop and torque meter lines, they
illuminate an anti-ice light in the flight station within 60 -90 seconds of
selection when the temperature of the pipe reaches 93 Degs C. A TIT increase
of approxamately 22 Degs C and a SHP drop of Approx. 9% will also be noted.
The props are electrically de-iced with the first 22 " of the spinner
anti -iced. :-)
Scet
Homebuilt Aircraft Frequently Asked Questions List (FAQ) Ron Wanttaja Home Built 40 October 3rd 08 04:13 PM
Homebuilt Aircraft Frequently Asked Questions List (FAQ) Ron Wanttaja Home Built 0 December 2nd 04 08:00 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 October 1st 04 03:31 PM
Homebuilt Aircraft Frequently Asked Questions List (FAQ) Ron Wanttaja Home Built 0 September 2nd 04 06:15 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 October 2nd 03 04:07 AM
