The other day I was doing some instrument work brush up for my flight
test. The first five hours of IF I did about 9 moths ago, and at that time I recall that I did not find it all hard to roll out of turns on a heading. However that seems to have changed, this week I found it quite hard to steady the plane after a long rate 1 (TC only as this was partial panel work). I've been puzzling over this and wonder if the trouble is that I'm starting to feel the flight more by other senses -in effect have I developed a sensitivity to the leans as my body has learned to feed more flight attitude info to my cranium? In any case, there could not have been a more dramatic demo for why MSFS is a pale shadow of the reaql thing! Is this to be expected when just using the TC in partial panel? Any thoughts welcome. Cheers |
WingFlaps wrote:
The other day I was doing some instrument work brush up for my flight test. The first five hours of IF I did about 9 moths ago, and at that time I recall that I did not find it all hard to roll out of turns on a heading. However that seems to have changed, this week I found it quite hard to steady the plane after a long rate 1 (TC only as this was partial panel work). I've been puzzling over this and wonder if the trouble is that I'm starting to feel the flight more by other senses -in effect have I developed a sensitivity to the leans as my body has learned to feed more flight attitude info to my cranium? In any case, there could not have been a more dramatic demo for why MSFS is a pale shadow of the reaql thing! Is this to be expected when just using the TC in partial panel? Any thoughts welcome. Cheers Yes, it's quite common, especially when starting partial panel. It will pass. That you're aware of it is the biggest step in that direction. Just relax; concentrate on your scan and fly deliberitely based on what the panel is telling you. The usual problem in partial panel work is that you're working the pitot static instruments. They have lag and you most likely will have a tendency to wander into your physical senses as you correct due to that lag. Working partial panel is a longer learning curve as you adjust to the idiosyncrasies involved. Don't worry. If you know what's causing the problem, you are well on the way to solving it :-)) -- Dudley Henriques |
| Thread Tools | |
| Display Modes | |
| Why is LOP (lean of peak) controversial? | Andrew Gideon | Owning | 54 | October 2nd 06 09:11 PM |
| TSIO 360 EB running lean at 12000 | Silvio Mecucci | Piloting | 12 | August 10th 05 12:39 AM |
| Lean of Peak video | Roger Long | Piloting | 7 | August 24th 04 10:46 AM |
| Lean of Peak Test Flight | Roger Long | Piloting | 0 | April 22nd 04 11:13 AM |
| Whether to Lean or Enrich | jls | Owning | 12 | March 3rd 04 08:56 AM |
