Remote controled weapons in WWII
Old January 19th 04, 09:57 PM
Charles Gray
Default Remote controled weapons in WWII
Numerous bombers and heavy fighters, especially thowse that entered
service post 1943 have reference to remote controlled weapons.
Now, the remote control part should be fairly easy, but how were
they aimed? I'm assuming that you linked the gunners controls in such
a way thatthe gun always fired at the point where he was aiming,
making allowences for the location of the gun-- but how effective were
they? How hard was it to keep them in repair, as that sounds like a
fairly complex and advanced system for the 1940's.
Old January 19th 04, 10:51 PM
Kevin Brooks
"Charles Gray" wrote in message
The B-29 had remote controlled turrets. Each gunner (and the bombadier,
IIRC) had a computerized gun sight that he used to track the target. He was
required to be able to identify the target by aircraft type, as the wingspan
of the target had to be entered into the system in order for it to be
accurate. The information from his sight track went to the central fire
control computer which crunched the numbers (electromechanically) and
adjusted the guns under his control accordingly. The central fire control
gunner was perched in the rear dorsal blister, and he could switch control
of various turrets to the various gunners, who normally had primary control
of one particular turret.
It faced it s fair share of teething troubles during development, but it was
judged to be very effective during WWII (and even later, as the Soviets
copied the system for their Tu-4 Bull and then carried the same basic system
over for use in the later Tu-16 and Tu-20/95). My father trained as a B-29
gunner and flew missions over Japan--he had also trained on the B-17 and
B-24 with their manually operated guns, and he definitely considered the
B-29's system to be superior to those. During Korea the original system was
found wanting versus higher speed jet attacks; that should not have been a
big surprise, as B-29 crews facing early generation jets during training
towards the close of WWII had already reported that tracking the faster
interceptors was a real challenge (my dad's crew had rotated back stateside
to attend lead crew school before returning to Guam, and he had the
opportunity to particpate in such a training experiment out of what was then
Muroc AAF (later Edwards AFB).
Brooks
Old January 20th 04, 11:32 AM
Cub Driver
Apart from the B-29, these weren't very sophisticated. The Boeing B-17
tail gunner aimed with a little stick; the guns tracked the movement
of the stick. The gunner at the rear of the Mitsubishi Ki-21 "Sally"
bomber had a manually aimed gun that was tracked by a stinger in the
tail. When his own rudder was in his sight, he could fire the stinger
by pulling on a lanyard. (Well, he could fire it at any time, but it
was most useful on those occasions.)
all the best -- Dan Ford
email:
see the Warbird's Forum at
www.warbirdforum.com
and the Piper Cub Forum at www.pipercubforum.com
Old January 20th 04, 02:57 PM
Peter Stickney
Charles Gray writes:
There were quite a few implementation of remote-controlled weapons
during WW 2. The level of sophistication varied greatly - from fixed
light machine guns pointing directly behind some bombers that couldn't
cover that area with aimed gune - (HE 111, and, IIRC, the Martin
Maryland - it worked about as well as could be expected, which is to
say, not very well at all) - to the U.S. A-26 and B-29's computer
controlled systems that automatically computed lead, jump, drop, and
the effects of altitude and temperature on the gun's trajectory, and
could aim several gun turrets from a single sighting station. (Oh,
yeah, it corrected for parallax errors for having the turrets adn the
sights in different locations. A B-29 gunner only had to place the
pipper of his sight on the target, and adjust the stadiametric range
circle as he tracked. The Fire COntrol System did the rest.
Remote control was also a feature of AAA (Anti-Aircraft Artillery).
All combatants used this to some degree, eslecially for Medium &
Heavy (40mm & up) guns. Targets were tracked by radar or optical
systems, which fed the target's motion and position data to a
Mechanical or Electromechanical Analog Computer, which resolved the
pointing solution and time of flight (Fuze setting) solution for the
guns. Less sophisticated systems, such as those used by the Germans,
used the computer to move a set of pointers on the gun mounts, and the
Pointer and Trainer operators turned handwheels to move the gun's
position to match the computer's commands. The U.S., and later the
Brits, with better technology (Feedback control systems, Variacs adn
Amplidynes) were able to control the pointing of the guns, and the
setting of the fuzes directly. With the introduction of the SCR-584
autotracking (You lock it on to a target, and it tracks it
automatically) radar, which fed the Ballistic Computer directly,
Remote Power Control to the guns, and Proximity Fuzes, Anti-aircraft
engagements were completely automated - The Gun Crew's job was to feed
shells into the breech as fast as they could, and act as a backup to
the remote systems.
The U.S. Navy had a similar level of sophistication. All guns on a
large ship were remotely controlled in train & elevation by the Fire
Control Systems, and the firing of the guns was controlled by the
computer. These computers automatically tracked the designated
targets, and controlled rangefinders and pointing systems, as well as
the guns. (The Spotting and Rangefinding crews, once the system was
tracking, input corrections, rather than raw position inputs)
With the introduction of microwave radars, which could spot
shell splashes as well as track targets, and allow gunfire corrections
to be made, they were capable of completely blind fire. THis was a
significant advantage that no other combatant had. (The Brits came
close, but the Germans and the Japanese were never able to build
systems that could accurately position something as large as a 90mm
gun, let alone a Battleship Turret).
Pete Stickney
A strong conviction that something must be done is the parent of many
bad measures. -- Daniel Webster
Old January 20th 04, 04:33 PM
Kevin Brooks
"Peter Stickney" wrote in message
I just got off the phone with my eighty year old father. While he was fuzzy
on the specifics these many years later, he said that they had to input the
wingspan of the target into the computer at the gunner's station (otherwise
your system could not compute the range). The navigator input the B-29's
current airspeed into the CFC system from his location. The gunner then
tracked the target in his reticle, adjusting the stadia as you indicate. He
could not recall any requirment for temperature to be input.
Brooks
Old January 21st 04, 02:38 AM
Peter Stickney
"Kevin Brooks" writes:
I should have been more clear, I guess. The computer used an OAT and
barometric pressure reading in its solution, but that was read by its
own thermometer and anaeroid. The Gunners didn't have to dial it in.
They did have to set the baseline for the range reticle, as you
describe.
Pete Stickney
Old January 21st 04, 03:30 AM
Eunometic
(Peter Stickney) wrote in message ...
Several more sophisticated German systems existed.
1 Cleverly positioned cheek babettes on the Me 410.
2 The Ju 388 has a remotely controlled tail turret that had a duel
view persicope with ventral and dorsal optics for a single gunner who
could scan above and below the aircraft. It was ofset to avoid the
tail. (It was similar system to that of the A26 I believe)
3 The Heinkel He 177 had a single remote dorsal turret.
4 A Piaggio P.108 4 engined bomber had barbettes on the nacells. (I
think only a dozen entered service but they gave sterling sevice to
the Lufwaffe who captured them)
5 The FA13 system on the, Arado 240 and Arado Ar 440. (It had a
system called the FA13 with a periscope)
(The Ar 240/440 was to have an electric system but was switched to a
hydraulic one becuase of reliablity. The gunners reported difficulty
in spotting the attacking aircraft in the ventral view in time during
testing. I do not know if this problem was ever solved by anyone with
episcopes and wide angle optics including on the A26 or latter Ju 388)
6 The Ju 288 (a few of which entered service) had tail, chin/vental
and dorsal barbettes.
Some of the German systems had computing abillity that extended beyond
mere elevation.
In a fast aircraft that can be only intercepted in a tail chase these
periscopes probably make sense.
Those that missed out on service:
7 The Australian CA-11 WOOMERA (alson known as Wackett bomber, was
designated the CAC-CA-4)
8 The Bell XB42 Mixmaster. (Guns beautifull streamlined between
airlerons and flaps)
9 B36
The B29 unlike the B36 was weird because the sighting stations and
guns were so far offset that the computers had to compensate.
The B36 doesn't even seem to have a tail gunner?
The Germans had computing and servo systems for their ships.
Considering the extreme state of manpower shortages I can not see that
the use of the fully automatic systems could be justified. The
precision servo systems for the tens of thousands of German FLAK
systems would be impossible to build and service.
AFAIK see a flak predictor on the basis of a fusion of inputs from
sound, stereoscopic range finders, radar produces a firing solution as
to where the target aircarft will be in say 15 seconds and provides
elevation, azimuth, fuse timing and firing time data.
A fully servo opperated system would shave of a few seconds since the
servo could position the gun faster than the point and crank
opperators (giving the aircrat less time to evade) and save some
manpower however they would also require extra skilled manpower to
manufacture and service.
By this time the Germans were using 13 year olds and retirees to
opperate the FLAK.
I think designing such systems and building a few was well within
Germanies technical know how. Manufacturing in quantity would have
been beyond them.
The FLAK predictor computers were afterall already providing
milliampmeter signals to the display guages on the guns. The
American guns used big 100lb or so caste iron variable resistors/
potentiometers that must have taken a long time to machine and then
calibrate to the precision required. Add in the backlash free
gearboxes, servo motors and amplifiers and you have a task beyond the
scope of Germanies resources to supply and maintain in quantity in
quick time at least.
the remote systems.
Not quite completley correct. The early German systems would servo
azimuth to a computer. The complication of servoing elevation being
considered pointless and not worth the effort becuase of the ranging
systems used involved braketing the target in anycase.
Czechoslovak nuclear weapons? Warszaw Pact War Plans ( The Effects of a Global Thermonuclear War ...) Matt Wiser Military Aviation 25 January 17th 04 03:18 PM
please stop bashing France Grantland Military Aviation 233 October 29th 03 02:23 AM
What about the AIM-54 Pheonix Missile? Flub Military Aviation 26 October 5th 03 06:34 AM
P-47/51 deflection shots into the belly of the German tanks,reality ArtKramr Military Aviation 131 September 7th 03 10:02 PM
Laser simulator provides weapons training Otis Willie Military Aviation 0 August 28th 03 10:58 PM
