"RENABORNEY" wrote in message ... STR reading that a total of two F-102's were lost in combat operations, one of which occured over NVN. l). I have not heard that it was used as an air superiority fighter per se (kind of lacked the legs for that). SNIP The one lost over NVN was the one I meant when I referred to use as an air superiority fighter - my impression was that it was lost on a MIGCAP mission.... And it might noy have been a MIG, maybe a SAM got it... As for legs - isn't that what tankers are for? (At least some Deuces were modifed with this capability in the Sixties) I don't know what the full story is regarding air refueling. Yes, the F-102 could refuel using the hose and drogue method, but I don't know whether the probe was a pop-out type, or a fixed attachment. After going over a fair number of photos, I can't see any external evidence of permanently affixed probe, but then again most of the danged phots available on the web are either from too far away or of the left side of the aircraft (the probe was located on the right side of the fuselage near the cockpit). If it was fixed, then none of the photos I found of the Vietnam deployed aircraft (including one nasty victim of a VC sapper attack at Danang) showed them attached. There used to be an F-102 pilot that hung around here RAM; he might be able to answer the question. Brooks |
"Kevin Brooks" wrote:
I don't know what the full story is regarding air refueling. Yes, the F-102 could refuel using the hose and drogue method, but I don't know whether the probe was a pop-out type, or a fixed attachment. After going over a fair number of photos, I can't see any external evidence of permanently affixed probe, but then again most of the danged phots available on the web are either from too far away or of the left side of the aircraft (the probe was located on the right side of the fuselage near the cockpit). If it was fixed, then none of the photos I found of the Vietnam deployed aircraft (including one nasty victim of a VC sapper attack at Danang) showed them attached. There used to be an F-102 pilot that hung around here RAM; he might be able to answer the question. Walt BJ is still around and he flew the F-102. |
"Kevin Brooks" wrote in message ... I don't know what the full story is regarding air refueling. Yes, the F-102 could refuel using the hose and drogue method, but I don't know whether the probe was a pop-out type, or a fixed attachment. It was fixed and temporary. I could post some photos to alt.binaries.pictures.aviation if you're interested. |
"Steven P. McNicoll" wrote in message news ![]() "Kevin Brooks" wrote in message ... I don't know what the full story is regarding air refueling. Yes, the F-102 could refuel using the hose and drogue method, but I don't know whether the probe was a pop-out type, or a fixed attachment. It was fixed and temporary. I could post some photos to alt.binaries.pictures.aviation if you're interested. No, that's OK. You just confirmed my suspicion. Brooks |
"Kevin Brooks" wrote in message ... "RENABORNEY" wrote in message ... STR reading that a total of two F-102's were lost in combat operations, one of which occured over NVN. l). I have not heard that it was used as an air superiority fighter per se (kind of lacked the legs for that). SNIP The one lost over NVN was the one I meant when I referred to use as an air superiority fighter - my impression was that it was lost on a MIGCAP mission.... And it might noy have been a MIG, maybe a SAM got it... As for legs - isn't that what tankers are for? (At least some Deuces were modifed with this capability in the Sixties) I don't know what the full story is regarding air refueling. Yes, the F-102 could refuel using the hose and drogue method, but I don't know whether the probe was a pop-out type, or a fixed attachment. After going over a fair number of photos, I can't see any external evidence of permanently affixed probe, but then again most of the danged phots available on the web are either from too far away or of the left side of the aircraft (the probe was located on the right side of the fuselage near the cockpit). If it was fixed, then none of the photos I found of the Vietnam deployed aircraft (including one nasty victim of a VC sapper attack at Danang) showed them attached. There used to be an F-102 pilot that hung around here RAM; he might be able to answer the question. Brooks Extracted from: http://home.att.net/~jbaugher1/f102_1.html The F-102A was not equipped at the factory for midair refuelling. However, there were some examples of the F-102A that were fitted in the field with probe and drogue inflight-refuelling probes mounted immediately aft of the cockpit on the right-hand side of the fuselage. These were fitted for the purpose of ferrying aircraft from the US to Southeast Asia. The probes were removed upon arrival. Some ANG F-102As were also fitted with these midair refuelling probes. This was also as I remembered hearing it from a friend of my who was on one of the early F-102 fighter drags to SEA. Tex |
"Tex Houston" wrote in message ... "Kevin Brooks" wrote in message ... "RENABORNEY" wrote in message ... STR reading that a total of two F-102's were lost in combat operations, one of which occured over NVN. l). I have not heard that it was used as an air superiority fighter per se (kind of lacked the legs for that). SNIP The one lost over NVN was the one I meant when I referred to use as an air superiority fighter - my impression was that it was lost on a MIGCAP mission.... And it might noy have been a MIG, maybe a SAM got it... As for legs - isn't that what tankers are for? (At least some Deuces were modifed with this capability in the Sixties) I don't know what the full story is regarding air refueling. Yes, the F-102 could refuel using the hose and drogue method, but I don't know whether the probe was a pop-out type, or a fixed attachment. After going over a fair number of photos, I can't see any external evidence of permanently affixed probe, but then again most of the danged phots available on the web are either from too far away or of the left side of the aircraft (the probe was located on the right side of the fuselage near the cockpit). If it was fixed, then none of the photos I found of the Vietnam deployed aircraft (including one nasty victim of a VC sapper attack at Danang) showed them attached. There used to be an F-102 pilot that hung around here RAM; he might be able to answer the question. Brooks Extracted from: http://home.att.net/~jbaugher1/f102_1.html The F-102A was not equipped at the factory for midair refuelling. However, there were some examples of the F-102A that were fitted in the field with probe and drogue inflight-refuelling probes mounted immediately aft of the cockpit on the right-hand side of the fuselage. These were fitted for the purpose of ferrying aircraft from the US to Southeast Asia. The probes were removed upon arrival. Some ANG F-102As were also fitted with these midair refuelling probes. This was also as I remembered hearing it from a friend of my who was on one of the early F-102 fighter drags to SEA. Tex I thought that was how it worked, but I was not sure. Thanks. Brooks |
"Kevin Brooks" writes: "RENABORNEY" wrote in message ... STR reading that a total of two F-102's were lost in combat operations, one of which occured over NVN. l). I have not heard that it was used as an air superiority fighter per se (kind of lacked the legs for that). SNIP The one lost over NVN was the one I meant when I referred to use as an air superiority fighter - my impression was that it was lost on a MIGCAP mission.... And it might noy have been a MIG, maybe a SAM got it... As for legs - isn't that what tankers are for? (At least some Deuces were modifed with this capability in the Sixties) I don't know what the full story is regarding air refueling. Yes, the F-102 could refuel using the hose and drogue method, but I don't know whether the probe was a pop-out type, or a fixed attachment. After going over a fair number of photos, I can't see any external evidence of permanently affixed probe, but then again most of the danged phots available on the web are either from too far away or of the left side of the aircraft (the probe was located on the right side of the fuselage near the cockpit). If it was fixed, then none of the photos I found of the Vietnam deployed aircraft (including one nasty victim of a VC sapper attack at Danang) showed them attached. There used to be an F-102 pilot that hung around here RAM; he might be able to answer the question. The F-102 probe was a pretty ugly thing, with a pretty hefty-looking truss supporting teh front, and a feedline running almost the entire length of the fuselage. Apparently it was pretty draggy, and distubed the airflow around the tail. The probes were used during the trans-Pacific deployment of the 64th and 82nd FISs when they were sent out in '66, adn removed after arrival. -- Pete Stickney A strong conviction that something must be done is the parent of many bad measures. -- Daniel Webster |
| AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 03:26 PM |
| Bush's guard record | JDKAHN | Home Built | 13 | October 3rd 04 10:38 PM |
| Logging approaches | Ron Garrison | Instrument Flight Rules | 109 | March 2nd 04 06:54 PM |
| bush rules! | Be Kind | Military Aviation | 53 | February 14th 04 05:26 PM |
| us air force us air force academy us air force bases air force museum us us air force rank us air force reserve adfunk | Jehad Internet | Military Aviation | 0 | February 7th 04 05:24 AM |
