Bucking bar and vice
Old September 5th 08, 01:58 PM posted to rec.aviation.homebuilt
mhorowit
Default Bucking bar and vice
New to riveting here.
Reading on basics show the impact on the manufactured head is
transmitted along the rivet and forces the bucking bar off the
bucktail. It then slams back, causing the rivet shaft to begin to
deform.
Because the bucking bar needs to move, does this mean it can not be
clamped in a vice? - Mike
Old September 5th 08, 02:14 PM posted to rec.aviation.homebuilt
John[_9_]
deform.
You could clamp it in vice. There is a process called back riveting
in which the rivet gun and a flush set is used to directly upset the
buck tail while the manufactured head is held against the bucking bar;
I have seen it used when someone is riveting flush rivets in thin
skins and the flush head is held against a flat plate. This would be
similar to what you propose. The key is to keep the slamming effect
to a minimum by keeping pressure through the rivet from the gun to the
bucking bar. Once the bar or the set or the rivet really move around
that is when you will have smiles at best or tool strikes at worst.
John Dupre'
Old September 5th 08, 07:14 PM posted to rec.aviation.homebuilt
John Kunkel
"mhorowit" wrote in message
deform.
The "slam back" of the bucking bar is classroom theory, in reality a
vice-mounted bucking bar will make the same shop head as a hand-held bar
(try it).
Picture a bulldozer pushing a Mercedes into a concrete wall, same process as
when using a hand-held or pneumaric rivet squeezer.
Old September 5th 08, 08:00 PM posted to rec.aviation.homebuilt
Orval Fairbairn[_2_]
In article
deform.
I would not clamp my rivets in a vice. What kind of vice do you have in
mind?
Gambling?
Drinking?
Sloth?
Gluttony?
Fornication?
Or, do you mean "vise"?
Remove _'s from email address to talk to me.
Old September 5th 08, 11:10 PM posted to rec.aviation.homebuilt
Dan[_12_]
Orval Fairbairn wrote:
In article
deform.
mind?
Gambling?
Drinking?
Sloth?
Gluttony?
Fornication?
I have an assortment of vises for various purposes. I guess my vice
is vises? Or vice versa?
Dan, U.S. Air Force, retired
Old September 6th 08, 02:28 AM posted to rec.aviation.homebuilt
jerry wass
In article
deform.
in mind? Gambling?
Drinking?
Sloth?
Gluttony?
Fornication?
I have an assortment of vises for various purposes. I guess my vice is
The man is truly wice beyond his years!!
Old September 6th 08, 09:27 PM posted to rec.aviation.homebuilt
Dan[_12_]
Jerry Wass wrote:
In article
deform.
in mind? Gambling?
Drinking?
Sloth?
Gluttony?
Fornication?
Vise guy.
Old September 5th 08, 08:28 PM posted to rec.aviation.homebuilt
Bob Kuykendall
Not in my experience, and I would dispute the assertion that the
bucking bar actually has to move. I've done plenty of rivets with a
bucking bar clamped in a vise, and have found it a perfactly
reasonable way to go. The dynamics are a bit different than with the
bucking bar held by hand, but plenty workable.
Where I found it necessary to control the dynamics of a bucking bar, I
constructed a machine that uses a Bilstein shock absorber to rebound
and reposition the bar. That was for riveting HP-18 sailplane box
spars. There's a page about it at Wayne Paul's Screder Sailplane
Designs web site:
http://www.soaridaho.com/Schreder/Co...ting_Tool.html
Thanks, Bob K.
PLEASE SIGN THE MITT ROMNEY FOR VICE PRESIDENT PETITION! Publius1787 Naval Aviation 0 April 8th 08 06:01 PM
Boeing Vice President To Speak (Available On-line) Larry Dighera Piloting 0 March 13th 08 09:46 PM
Shinn brake linings - bonding vice riveting Michael Horowitz Owning 0 July 12th 04 05:47 PM
Air Vice Marshal Tony Dudgeon Keith Willshaw Military Aviation 0 January 9th 04 01:43 PM
What is the reasoning behind the smaller radius vice presidential TFR? Larry Dighera Piloting 38 November 19th 03 05:04 PM
