Maximum Speed of Airliner At Low Altitude
Old June 14th 04, 12:59 AM
Roger Helbig
Default Maximum Speed of Airliner At Low Altitude
Airline or Military transport pilots .. I would like to ask you some =
questions about the maximum speed that an airliner like a B-767 or 757 =
can travel at low altitude. Someone claims that the speed at altitude =
is much higher than that at low altitude because the drag of the wide =
body limits the maximum speed at low altitude. Can any of you comment =
on that?
Thank you.
Roger Helbig
-----= Posted via Newsfeeds.Com, Uncensored Usenet News =-----
http://www.newsfeeds.com - The #1 Newsgroup Service in the World!
-----== Over 100,000 Newsgroups - 19 Different Servers! =-----
Old June 14th 04, 05:42 AM
Andy Bush
Each aircraft may well have a different low altitude max speed...this will
be given in knots of Indicated Airspeed (IAS)...and typically is about
350-400 knots for passenger aircraft. At low altitude, IAS and True Airspeed
(TAS) are pretty much the same. While the low altitude max speed is
expressed in knots IAS, the high altitude max speed is expressed as a Mach
number. Passenger jet max mach numbers vary from around .8M to close to .9M.
At high altitude, IAS and TAS often are quite different, with TAS being the
larger value.
The low altitude max speed limitation is an airframe limit and not a drag
limit. In most cases, the jet could go faster but for various aerodynamic
reasons, is restricted from doing so.
"Roger Helbig" wrote in message
news:40ccdcd9@hughey...
questions about the maximum speed that an airliner like a B-767 or 757 can
travel at low altitude. Someone claims that the speed at altitude is much
higher than that at low altitude because the drag of the wide body limits
the maximum speed at low altitude. Can any of you comment on that?
Thank you.
Roger Helbig
-----=osted via Newsfeeds.Com, Uncensored Usenet News =---
-----= Over 100,000 Newsgroups - 19 Different Servers! =---
Old June 14th 04, 06:27 AM
Robey Price
After an exhausting session with Victoria's Secret Police, "Roger
Helbig" confessed the following:
some questions about the maximum speed that an airliner
like a B-767 or 757 can travel at low altitude.
Since I have a checkride coming up...Vmo is 340 KIAS for the 757 I
fly. "Clackers" start going off if you hit 340...ahem, I have seen
this in an Idle thrust descent.
The 757 is a very "clean" airframe. It does not like to slow down. If
a pilot turned the autothrottles off and simply firewalled the
throttles it would haul ass in the traffic pattern. How fast? Not
supersonic, but it requires surprisingly low thrust to hold the FAA
250 KIAS limit beow 10k'. I should have taken notes today (TIC).
Ramp down from altitude, it would probably scare the islamist ****
terrorist with all the warning noise from an overspeed (340+ KIAS). I
mean scare in terms of, "holy allah will this infidel made machine
hold together?"
Robey
Old June 14th 04, 11:20 AM
Cub Driver
I believe the max for any aircraft is 250 knots.
The restriction is lifted in certain cases, for example: military jets
doing a Missing Man at Arlington National Cemetery.
all the best -- Dan Ford
email: (put Cubdriver in subject line)
The Warbird's Forum
www.warbirdforum.com
The Piper Cub Forum www.pipercubforum.com
Viva Bush! www.vivabush.org
Old June 14th 04, 01:51 PM
Robey Price
After an exhausting session with Victoria's Secret Police, Cub Driver
Mil jets are not limited to 250 KIAS "due to operational need," as in
a routine Dash 1 procedure (eg 350 KIAS up Initial for the RF-101, 300
KIAS for the F-4, F-16, F-15). But in the radar traffic pattern we
held it down to 250 KIAS.
But Roger's question has to do with the physical limitation of the 757
not something written in an FAR.
Robey
Old June 17th 04, 06:07 PM
David Lednicer
Go to the FAA Type Certificate database at:
http://www.airweb.faa.gov/Regulatory...e?OpenFrameSet
Each type certificate lists the maximum operating airspeed and Mach
number. The airspeed is the limit until an altitude is reached at which
the Mach number listed equals the airspeed. Then, the Mach number
limits the aircraft. Be careful - some type certificates list the
airspeed in Knots Indicated Airspeed (KIAS), some in Knots Calibrated
Airspeed (KCAS), some in Knots Equivalent Airspeed (KEAS) and some in
Knots True Airspeed (KTAS).
GPS Altitude with WAAS Phil Verghese Instrument Flight Rules 42 October 5th 03 01:39 AM
#1 Jet of World War II Christopher Military Aviation 203 September 1st 03 04:04 AM
Aircraft engine certification FAR's Corky Scott Home Built 4 July 25th 03 07:46 PM
