Inspiration for Homebuilders
Old May 26th 09, 12:57 AM posted to rec.aviation.homebuilt
Brian Whatcott
Default Inspiration for Homebuilders
This is a pointer to a home build 20 ft diam windmill on a 70 ft pole.
It features three 10 ft long laminated red cedar blades and nice looking
generator, tower couplings and gin....
http://www.otherpower.com/20page1.html
Brian W
(Thanks to Larry for the pointer on rec.boats)
Old May 26th 09, 04:06 AM posted to rec.aviation.homebuilt
Orval Fairbairn[_2_]
Brian W
I hope that you have good lightning suppression!
Remove _'s from email address to talk to me.
Old May 27th 09, 02:01 AM posted to rec.aviation.homebuilt
Brian Whatcott
Brian W
Ha! I noticed the maker specified a blade angle of 3 degrees at the
tips, increasing to (approaching) 9 degrees at the roots.
It took me a little while to get my head round this. The maker mentioned
the blades are set flat (undersurface) forward into the wind, and I
think he mentioned a target rotation rate of 65 rpm.
I imagine he was thinking of an AoA of 15 degrees at the rated wind. The
tips do a revolution in pi x 20 ft = 63 ft per rev - so the rotation
rate at 65 rpm would give a tip speed of 65rpm X 63ft/rev X 60 min/hr /
5280 ft/mile or 47 mph.
I guess the pitch angle for zero AoA at the starting windspeed 16 mph
would be atan 16/47 = 19 degrees from the plane of revolution, so for 15
deg AoA the pitch angle might be 4 degrees from the plane of revolution
at the tips.
And he mentions 3 degrees. But getting up to speed with stalled blades
would be an issue...
What's your take, Orville?
Regards
Brian W
Old May 27th 09, 02:53 AM posted to rec.aviation.homebuilt
Brian Whatcott
What's your take,
Orval
XXXOrville?XXX
(sorry 'bout that!)
Regards
Brian W
Old May 27th 09, 03:26 AM posted to rec.aviation.homebuilt
Brian W
at the tips.
Regards
Brian W
My first take is that you misspelled my name.
We had a big windmill on our farm when I was growing up. The plane of
rotation was parallel to the wind, rather than at a right angle. The fan
acted more as a wind turbine than a propeller. IIRC, the fan had about a
dozen curved steel blades. It also had a brake on it for when the winds
got too high.
Old May 27th 09, 05:16 AM posted to rec.aviation.homebuilt
jerry wass
Brian W
at the tips.
Regards
Brian W
got too high.
The blades were turned sideways (parallel to the tail) if they didn't
want it to pump any water---If you needed water you operated the lever
that placed the blades perpendicular to the rudder, tail,
whatever,-pointing into the wind, then you got some POWER..---OR--
did you have one of those weird looking things where the blades were
raked back severely at an angle about like the back 2/3 of a snowcone
cup? Jerry
Old May 27th 09, 05:13 PM posted to rec.aviation.homebuilt
Brian W
at the tips.
Regards
Brian W
got too high.
cup? Jerry
Neither. The fan was 10-12 ft diameter, fixed so the wind would always
turn the fan. Since the blades were curved (cambered), the advancing
blade had less drag than the receding blade. I think it was a
Fairbanks-Morse product, but don't hold me to that, and it was built
about 1910.
A lot of windmills in our area (Northern Illinois) were of similar
design.
AN ENGINE FOR HOMEBUILDERS Bob Home Built 65 June 5th 09 07:45 PM
A Camcorder for Homebuilders [email protected] Home Built 3 June 1st 08 03:27 PM
Inspiration by friends - mutal interest and motivation to get the PPL Gary G Piloting 1 October 29th 04 09:19 PM
Best Homebuilders Books? [email protected] Home Built 5 January 21st 04 01:06 AM
"Big" Jon Johanson --- an Inspiration Larry Smith Home Built 0 December 17th 03 05:01 PM
