Looking for pictures of motorglider failures
Old December 8th 19, 06:47 PM posted to rec.aviation.soaring
Default Looking for pictures of motorglider failures
I remember an engine that would not extend caused by a spark plug wire stuck to the muffler! Apparently the engine had been retracted without a sufficient cooling period and spark plug wire came to rest on the muffler and melted the insulation that turned to glue when it cooled down! Oddball malfunction for sure. Also heard rumors about pilots forgetting to add oil to the fuel in 2 stroke engines and another guy that accidentally added oil twice to the same batch of fuel. Then there was the pilot that leaned out his engine for peak power and melted a cylinder on takeoff. Seems to me that electric motors are the best way forward, but self launching with a motor in the nose gives very little prop clearance. The JETA looks promising.
JJ
Old December 8th 19, 06:51 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Dan Marotta wrote on 12/8/2019 9:38 AM:
HERE https://www.youtube.com/watch?v=Puia_yQxir8&feature=youtu.be is an example
of a jet sustainer failure to start.* Good glide path control, but I thought he
may have waited a bit longer than required before dumping his ballast.
On 12/8/2019 9:59 AM, Dave Nadler wrote:
On Sunday, December 8, 2019 at 11:46:36 AM UTC-5, kinsell wrote:
No one has mentioned jets? They can be unreliable to get started, and
there's been uncontained blade failures. Even had the engine depart the
A/C.
Interesting, I've heard of numerous failures to start and failure to climb,
but not uncontained blade failures or engine departing AC...
I'm pretty sure that qualifies as a self-launcher!
Old December 8th 19, 07:01 PM posted to rec.aviation.soaring
Motor in a sailplane = a complicated abomination, ......
An efficient light power plane utilizing sailplane aerodynamics = beautiful engineering.,,,,
Old December 8th 19, 08:06 PM posted to rec.aviation.soaring
Jonathon May
At 18:47 08 December 2019, Eric Greenwell wrote:
Some where there is a photo of a propellor blade sticking out of a
duo discus wing.It was part of the AD sent out after a hub failure left
the blades coming off.
wrote on 12/8/2019 10:01 AM:
Look at an FES sailplane - simple. Much simpler than a towplane,
and much
easier
to schedule when you need a launch. I was part owner of a
towplane for
years, and
it caused me more grief each year than the self-launcher I now
own. And
then there
are the avoided retrieves - simple and priceless!
Are we really having this conversation after all these years, with
80% of
gliders going out the factory door with an engine?
email
me)
https://sites.google.com/site/motorg...ions/download-
the-guide-1
Old December 8th 19, 08:51 PM posted to rec.aviation.soaring
Duster[_2_]
\J. May:
I think this may be what you're referring to?
https://assets.publishing.service.go...SAXT_05-16.pdf
Old December 8th 19, 09:06 PM posted to rec.aviation.soaring
Dave Nadler
with 80% of the gliders going out the factory door with an engine?
That is PRECISELY why we're having this conversation.
Looking forward to your contributions,
Best Regards, Dave
PS: Old, but still relevant (I need to see if Jean Marie has an updated version):
http://www.streckenflug.at/download/motorprobleme.pdf
Old December 8th 19, 09:17 PM posted to rec.aviation.soaring
Jonathon May
At 19:51 08 December 2019, Duster wrote:
\J. May:
left
https://assets.publishing.service.go...14f22aed915d16
01000000/Schempp-Hirth_Duo_Discus_T_G-SAXT_05-16.pdf
Thats the incident butI have see more photos one was of a blade
impacted with a wing still I insintue
Old December 8th 19, 09:29 PM posted to rec.aviation.soaring
Duster[_2_]
Not part of the accident report, but here are some additional photos of the hub failure accident mentioned. Kudos to the BGA and their mag for better coverage of such events and remedies. I believe this is the same one regarding the G-SAXT Duo?
http://glidingtauranga.co.nz/wordpre...-Engine-DI.pdf
Old December 8th 19, 09:36 PM posted to rec.aviation.soaring
Jonathon May
engine?
Best Regards, Dave
updated
version):
Prop blade punctured fuselage, dented fuel tank and restricted
aileron movement. It nearly took out the brakes as well. The prop
had flown 38 hours
Missing blade
The flight manual says to check for cracks in the hub every day. This
is what a very badly cracked hub looks like.
There are photos I will try to put a link in.
302 security failures T8 Soaring 17 April 8th 10 04:33 AM
MH EDS failures Philip Plane Soaring 6 December 16th 05 01:37 AM
Colibri failures? [email protected] Soaring 3 April 15th 05 01:30 AM
Colibri Failures. Stan Kochanowski Soaring 2 April 6th 05 02:00 PM
Colibri Failures. Stan Kochanowski Soaring 1 April 6th 05 01:24 PM
