Coronavirus
Old March 8th 20, 04:19 PM posted to rec.aviation.soaring
Default Coronavirus
The least of our worries just require guys to wear their o2 mask lol
Old March 8th 20, 04:32 PM posted to rec.aviation.soaring
Stephen Szikora
Default Coronavirus
That’s called thermalling.
Old March 9th 20, 01:12 AM posted to rec.aviation.soaring
Default Coronavirus
On Saturday, February 29, 2020 at 10:31:54 AM UTC-8, ProfJ wrote:
Turns out that another unexpected benefit of being a glider pilot is that you're thoroughly prepared for coronavirus. Got the oxygen set, the oximeter, the N95 masks and nitrile gloves from the last time you did fibreglass work ...all set :-)
A typical glider oxygen bottle may not last the many days that recovery will need. But in an emergency, a home oxyacetylene system would probably provide a long-term oxygen supply if hooked up to a MH pulse regulator.
Old March 9th 20, 02:26 AM posted to rec.aviation.soaring
Default Coronavirus
"a home oxyacetylene system"
Uh, I think it would be wiser to keep the acetylene cylinder closed. It really isn't that good for long-term health. Or short term, for that matter.
Old March 9th 20, 06:41 AM posted to rec.aviation.soaring
Frank Whiteley
Default Coronavirus
On Friday, March 6, 2020 at 3:03:59 PM UTC-7, Tom BravoMike wrote:
On Friday, March 6, 2020 at 12:57:36 PM UTC-6, Tony wrote:
Does it still cost $1000 to join plus ~$400/year at CGC or have the rates gone up since 2013?
http://soarcgc.org/content/fees.php
The new website is:
http://www.chicagogliderclub.org/ind...-02-13-24/fees
Since the SSA dues are wrong, I suspect other costs are not correct. There is a mismatch between the hourly rate for the club two-seaters on the fleet page and the fees page. Also, CGC moved to a smooth liability coverage a while back, I seem to recall that they also moved to self-insure their hulls, meaning members will probably require renter/non-owner coverage of some minimal amount. One chapter I'm aware of requires $30,000 minimum coverage.. I'd be surprised if it were that low for the K-21s and Duo Discus. That would easily add $500 or more to the annual cost of "membership" for the non-owner member.
Perhaps someone direct knowledge of this will comment.
Frank Whiteley
Old March 9th 20, 08:28 PM posted to rec.aviation.soaring
Pasi Pulkkinen
Default Coronavirus
And this is attached to the subject of corona virus how?
Old March 9th 20, 09:23 PM posted to rec.aviation.soaring
Frank Whiteley
Default Coronavirus
Nothing, but the thread drift started back on the 4th.
