Radar from the 60s
Old September 9th 03, 04:15 AM
Elmshoot
I seem to remember a rumour during GWI that one of the RNs air defence
ships apparently managed to detect F-117As using some form of '50s long
wave radar.
No rumor, fact. Stealth is not invisible to all frequiencies. Some will detect
at longer ranges than others. Understanding radar therory and a close reading
of Aviation week will confirm the rumor. During DS the Hummers kept track of
the 117's for the Airfarce. What radars were destroyed by the snake eaters on
the opening salvo of DS?
Sparky
Old September 9th 03, 04:57 PM
TMOliver
"WDA" vented spleen or mostly mumbled...
In the 60s carrier based A-3 heavy attack bombers flying above 40,000
feet often could approach a warship and not be detected on the air
search radar even when passing overhead.
As a 60s era carrier based Air Intercept Controller, I'll argue your claim
from two contrarian perspectives...
A. Unless some here can establish reasonable evidence to the contrary the
number of A3 strike sorties (or EA3 missions) routinely flown above Angels
40 will fit over in the slim and none category. Ops above 40 with any navy
a/c in the early 60s were simply not the norm, and even the most capable,
the F8s, were troubled by compressor stalls in certain attitudes.
Certainly, the advent of the F4 changed the picture, but F4s remained in
short supply until '64 or so.
B. I can't think of an aspect in which an A3 wasn't a well-painted target
(at least on the SPS-37 or 43, although I had no experience with low flyers
(but I knew few former A3 drivers who were happy flying low, them downward
firing seats lending little survivability to a low altitude mechanical
problem). I "learned" on an SPS-12, a gadget of lesser range, but there
were controllers who worked SPS-6s, high art and good intuitive skill
required.
TMO
Old September 9th 03, 06:04 PM
Chuck
'In the 60s carrier based A-3 heavy attack bombers flying above 40,000
search radar even when passing overhead.'
claim from two contrarian perspectives...
the number of A3 strike sorties (or EA3 missions) routinely flown above
Angels 40 will fit over in the slim and none category. snip
I disagree with "slim and none" but can't provide evidence except my
memories from VAH-1 and VQ-2.
target (at least on the SPS-37 or 43, although I had no experience with
low flyers (but I knew few former A3 drivers who were happy flying low,
them downward firing seats lending little survivability to a low
altitude mechanical problem). snip
I'm assuming a bit of wry humor when you wrote "them downward firing
seats"?
Downward - correct; firing - nope. No ejection seats in any direction,
on the "All 3 Dead" (A3D). Maybe the least favorite nickname but often
heard, especially from the folks who had earlier been flying the AJ
Savages aka "The Widowmaker" also sans ejection seats.
Chuck
HEAVY ATTACK COMPOSITE (VC-5,6,7,8,9) WEBSITE
http://community.webtv.net/charles379/USNComposite
FAIRECONRON ONE AND TWO (VQ-1/2) CASUALTIES
http://www.anzwers.org/free/navyscpo...r_AirCrew.html
Old September 10th 03, 12:34 AM
s.p.i.
TMOliver wrote in message ...
required.
TMO
Just one niggle TM, A-3s had no ejection seats, but they did have a
chute on the bottom of the fuselage.
If WDA's memories were of ops in the MED, his post has some merit.
There were many, many times in the summer months the SPS-10 (surface
search) would paint aircraft at angels 33 (verified with SPG-55 and
mode c) and not paint the carrier at 15,000 yards, while the SPS-49
would paint dead cow carcasses and other floatsam and jetsam (depress
the antenna on the 49 and it would paint a periscope really well) on a
glassy sea surface and not show the first aircraft above angels 5.
Old September 10th 03, 07:32 PM
WDA
Sorry, TMO, You got it all wrong!
What downward ejection seats in the A-3-3 are you talking about? The A-3
never had ejection seats!
Hell, we could get to 50,000 feet altitude in the FJ-3 in 1956!
A-3s flying back and forth over your black shoe radars without being
detected was so common off Pt Mugu that radar beacons had to be used to be
able to conduct ship's missile tests.
FYI, the A-3 probably had the most sophisticated ECM system in any USA
aircraft when the Vietnam "flail-ex" commenced. We took the ALQ-51 deception
repeaters out of our A-3s to install in A-4s flying over Hanoi. Later a
dozen other Navy.Marine a/c types also got the ALQ-51. We even had to cough
up fifty of them for Air Force photo recce a/c.
Meanwhile the USAF was putting the ALQ-76 "jamming pods on their F-4s.
"Protection" by that pod required their a/c to fly in rigid parade formation
to counter the Fansong radar. But if just one of the pod equipped planes
slid out of formation it was immediately tracked and nailed by Guidline
missiles. That was because the damned pods were actually beacons instead of
jammers!
CDR Dick Seymour [later the VADM commanding Naval Air Systems Command] took
a squadron set of ALQ-76 to Yankee Station with his A-4s but never put the
damned things on any of his aircraft going feet dry over NVN. He brought all
his pilots home safe.
Sorry, TMO, there's much more to the A-3 story than you are evidently aware
of.
WDA
VF-24, VA-192, 1955 - 1959
end
"TMOliver" wrote in message
navy
flyers
required.
TMO
Old September 11th 03, 12:44 AM
TMOliver
aware of.
I simply don't recollect the A3s or EA3s routinely operating above 40,000,
or presenting anything out of the ordinary as radar target. I do recall
pilots who had flown the FJ series claiming that its parameters greatly
exceeded those of the Demon which normally flew neither high nor long. In
the Med, the constraints against activating active ECM gear were almost
prohibitive.
It was not uncommon for low altitude A1 strikes to avoid detection (even
with their four paddled reflector), all of sudden popping up on the SPS-10C
which had to be finely adjusted to not mask snorkels in sea return.
TMO
Old September 11th 03, 04:11 AM
Red
"WDA" wrote in message
. net...
SNIP SNIP SNIP SNIP
formation
of
jammers!
WDA
Ah Hah! Flying the infamous SAM box with the ALQ-76. (The ALQ-76's were
amplifying beacons). The theory was to keep a 800-1000 feet between
aircraft. The signal return (+amplification) would look like one aircraft
and the SAM would guide to the center of the blip. Therefore the SAM will
detonate between the aircraft missing each by 400-500 feet.
Would you trust this device?
Red
Old September 11th 03, 06:40 AM
Walt BJ
I was flying USAF 86Fs and later 86Ds on Okinawa 54-57. I was told
Navy A3Ds would routinely cross overhead at 40+ on their way to and
from PI - Japan. Their cruising speed was high enough to give the Dog
fits trying to intercept them before running out of fuel.
Walt BJ
Old September 11th 03, 06:50 AM
Guy Alcala
. net...
SNIP SNIP SNIP SNIP
formation
of
jammers!
WDA
Allow me to point out that the Air Force fighters used the ALQ-71 (nee'
QRC-160-1) and later the ALQ-87 (nee' QRC-160-8) noise jammers, not the
ALQ-76. And the USN suffered greater percentage losses to SAMs in Vietnam
than the USAF did, despite all the navy a/c being equipped with the ALQ-51.
Both types of jammers had their advantages and disadvantages; the USAF began
using the ALQ-101 (nee' QRC-335) combined noise/deception jammer from 1968, on
those a/c that by nature of their missions (MiGCAP, Wild Weasel) had to fly
more independently.
With regard to Bill Allen's statement that the Air Force pods were "actually
beacons instead of jammers," that's rather subject to fine print. Certainly
by 1972 the VPAF/ADF SAM crews were sometimes operating in a "jamming strobe"
mode, decreasing the gain to use the jamming strobe for direction/elevation,
and a separate radar (often in another band) to provide range data. But AFAIK
they never had the capability to use a true home-on-jam capability; the SA-2
was command guided (unlike the Sparrow), so how could they? The USAF noise
jamming pods were also modified to jam the missile beacons (transponders)
starting around the end of 1967, which proved extremely effective until the
VPAF/ADF (actually, their Soviet advisers) made some changes to the
transponders to make this type of jamming more difficult. This took effect no
later than 1972, and possibly a bit earlier (I'd have to check a few sources).
Guy
Old September 11th 03, 06:30 PM
ZZBunker
"Charles Talleyrand" wrote in message ...
How good was shipborne radar in the 60s against a 2003 airforce? For example, could a 1964 ship detect an incoming modern strike
before the explosions began in the face of modern ACM.
A ship with 60s radar is useless against a 2003 airforce, unless
you're talking about a Vietnamese Air Force.
The only radars ships had back then were air search and tracking,
surface search, and missle guidance.
But likewise 2003 Airforce Radar is equally useless against 2003 Navy Radar.
I ask both because I'm curious about the past and because there are navies out
there using old-fashioned technology.
All navies use some technology dating back to at least the 5th Century BC.
It wasn't until the mid 19th century that navies even started to
use anything other than sails, compasses, knives, swords,
spears, fish barrels, and knots as their primary weapons.
And there's also armies out there using 10th Century technology,
and some of them are still winning wars, even against 21st Air Forces.
B-52 crew blamed for friendly fire death Paul Hirose Military Aviation 0 March 16th 04 01:49 AM
Ham sandwich navigation and radar failure David Brooks Instrument Flight Rules 47 December 31st 03 01:15 AM
F15E Radar question. Bill Silvey Military Aviation 5 August 30th 03 07:17 PM
Marine Radar in a plane? Jay Honeck Home Built 31 August 13th 03 07:56 PM
