"Priceless" in Afghanistan
Old February 29th 04, 03:20 PM
Pechs1
John- 2. Shimano. Heard they've run Branford Bike out of the Shimano
distribution business. Hmmm. BRBR
They are just whinning along with Lictons, I think. They don't think it's fair
for shimano to try to protect their distribution and try to raise who deals
with their equipment to a higher level. Branford and Lictons are just concerned
about $$.
They could both resell shimano via MO or the internet, they just have to agree
to sell it in a MSRP range, or no supply. Too bad, I like they way the playing
field has been leveled.
P. C. Chisholm
CDR, USN(ret.)
Old Phart Phormer Phantom, Turkey, Viper, Scooter and Combat Buckeye Phlyer
Old February 29th 04, 04:04 PM
Pechs1
I'll tell ya another frustration. I read Kerry's voting record and the weapons
systems it involved. Some made sense(like the B-2) but others didn't like his
nay vote on the F-14A(what keep the F-4???) , F-15C and F-16. W/o those
programs we would have been in deep kimchee for GWI and II.
Bush seems like a deer in the headlights and Kerry seems like McGovern
reincarnated...yikess...
P. C. Chisholm
CDR, USN(ret.)
Old March 1st 04, 04:00 AM
BUFDRVR
Doesn't that thing do over the shoulder nuke deliveries? Pull up, throw
nukeout, continue over the top, 1/2 cuban 8 type thing, accel and run like
hell???I'll bet it does...
It was designed to do "lay down" nuclear bomb runs, not loft. I've seen them do
some pretty agressive (for a big plane) pitch outs, but I'm not sure if they
could execute an immelman or not.
BUFDRVR
"Stay on the bomb run boys, I'm gonna get those bomb doors open if it harelips
everyone on Bear Creek"
Old March 1st 04, 07:32 AM
Guy Alcala
Don't see why not. If the high-altitude designed B-47s could do them (admittedly,
with some serious wing fatigue problems as a result), then the low-altitude
stressed B-1 shouldn't mind.
Guy
Old March 1st 04, 12:22 PM
BUFDRVR
(admittedly,
It's not a stress issue, it's an excess thrust issue. The Bone may be able to
pull off an immelman,but I'm betting you won't find too many pilots eager to
test out that theory.
By the way, the B-47 could do many things niether the B-52 or B-1B can do.
BUFDRVR
  #28
Old March 1st 04, 03:22 PM
Peter Stickney
(BUFDRVR) writes:
(admittedly,
If it's qn excess thrust issue, than that would weight it even further
into the "Yes, sure the B-1 can do an Immelman" side. Of all the
things the B-47 didn't have, thrust was probably the most obvious.
According the the B-47S Standard Aircraft Characteristics, Takeoff
Ground Roll for a loaded B-47E-IV, without RATO, could be upwards of
10.500'. That's not exactly a high t/w. (A better context for excess
thrust numbers woudl be SEP at Combat Weight - in that case, the B-47E
data gives us 4450 '/mion @ Sea Level, a 1965-era B-52H gives
6500'/minute. (Score one for the Buff)
For that matter, I've flown planty of Immelmans in sailplanes - it's
hard to find a lower T/W than 0. (Although the roll at the top _was_
kinda sloppy_ What would be more important is Drag/Weight. If you'ge
got a really slippery shape, you won't lose speed as quickly with the
nose high.
If thrust exactly equalled drag (SEP = 0), it'd take _anything_ pulled
straight up anout 260 seconds to lose 300 KTS. Your entry adn exi t
speeds would be rather dependant on the airplane, of course. but
there's plenty of energy for a 2-3 G pull through 180 degrees.
Well, fly around the pattern trailing a parachute is one...
Tobogganing behind an overstressed KC-97 would be another.
Pete Stickney
A strong conviction that something must be done is the parent of many
bad measures. -- Daniel Webster
  #29
Old March 3rd 04, 02:10 AM
BUFDRVR
Remember, the B-47 did their immelmans from high altitude (and entered from a
dive obviously), the Afghanistan Bone would be entering from straight and
level, thus it becomes an excess thrust issue.
Cruising around, fully loaded (albeit a smaller load than a BUFF or Bone) at
40K+ and .90 mach. Doing an immelman at high altitude (not possible for a
BUFF...maybe for a Bone, but not from 30K+).
BUFDRVR
  #30
Old March 3rd 04, 05:44 AM
Peter Stickney
(BUFDRVR) writes:
Are you sure about that? Remember, the wing loading's a lot higher
than that of the B-52. Not a whole lot of excess G at altitude.
They did use Immelmans as an escape maneuver when they decided tht low
level was the way to go, and that the best way to do that was with a
LABS delivery. It didn't last long though, In the first 3 months that
they tried it in the field, they lost 3 airplanes due to structural
failure. They modified their technique to a low-level ingress with a
pop up to about 10-12,000' to drop a drogued weapon, and a diving turn
away immediately after weapon release.
Well, I'll admit I'm a little on the young side to have flown a
B-47. (But I was at Pease when the last one in service was flown in
to be a gate guard - U.S. Navy markings, and a North American
Autonetics crew. That was 76 or 77 or so) But I've known plenty of
peolple who have. For a loaded B-47, 40 Kft was about all you'd get.
Placard Limits are 425 KIAS up to Mach 0.86, meeting at 'bout 17.500'
I could run a o.86 at 36,000 (tropopause), but that was about it.
The 425 KIAS limit was pretty definite. Aince the wings were so
flexible, the ailerons would twist the wings, reducing, and eventually
reversing roll control. 425 KIAS was the point where you didn't have
any roll control.
Pete Stickney
Pilot who bombed Canadians in Afghanistan to sue US air force . Otis Willie Military Aviation 0 July 8th 04 10:38 PM
Airmen deliver 35,000 helmets to Afghanistan Otis Willie Military Aviation 0 June 30th 04 11:51 PM
[OT] Gullible Bush was suckered over bio warfare trucks No SPAM Military Aviation 1 March 29th 04 01:04 PM
"Priceless" in Afghanistan BUFDRVR Military Aviation 15 February 28th 04 05:17 PM
Priceless in Afganistan breyfogle Military Aviation 18 February 24th 04 06:54 AM
