Auto conversion cost post
Old December 27th 03, 10:42 PM
Ernest Christley
George A. Graham wrote:
On 25 Dec 2003, Ben Haas wrote:
So George, fill us all in on how you took a 5 speed trans and used it
to transmit 500-600 pounds of thrust from the prop when in a car there
is no thrust loads on the output shaft at all??
Sure Ben, Single deep groove bearings, and it is more like 300 lbs.
The stock output shaft is not used (too long).
George Graham
RX-7 Powered Graham-EZ, N4449E
Homepage http://bfn.org/~ca266
George, the last I heard, you had some teething pains with that
transmission PSRU and got some busted gears. I have to assume that is
all cleared up, but what is a 'single deep groove bearing'?
http://www.ernest.isa-geek.org/
"Ignorance is mankinds normal state,
alleviated by information and experience."
Veeduber
Old December 28th 03, 07:16 AM
Danny Lawhon
Does anyone know if someone has adapted a rotary to a zenair zodiac xl
sport
pilot plane yet ? I was wanting to know if its possible, also whats
average weight of a 13b with fluids,psru unit ect.. can it be done
with 300lbs or about ? they recommend 125hp max and 300 lbs , anyone
doing this right now ?
Danny..
On Sat, 20 Dec 2003, George A. Graham wrote:
On Sat, 20 Dec 2003, Richard Riley wrote:
- rebuild with race quality parts, proven PSRU, etc -
that the initial installation isn't significantly less than a zero
timed LyCont.
snip
is this a figment of my sleep deprived imagination?
Richard, It certainly must be a figment of somebodys imagination,
and that person is convincing himself.
Horsefeathers!
George Graham
Old December 28th 03, 11:49 AM
Larry Smith
"Danny Lawhon" wrote in message
sport
Danny..
timed LyCont.
snip
Horsefeathers!
George Graham
Graham probably has the best chance for hope in converting auto engines to
aircraft use. There's a Subaru conversion in Virginia that was tweaked out
and did reasonably well, but the owner finally gave in and went to an O-200,
which he says works much better for him.
Old December 28th 03, 12:52 PM
George A. Graham
sport
pilot plane yet ?
I doubt it, the installation ends up weighing about the same as an
O-320 if kept light, or an O-360 if using heavy parts, which I think is
too heavy for that bird.
George Graham
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 1 January 2nd 04 09:02 PM
Aircraft per hour cost Fitzair4 Home Built 0 December 1st 03 02:15 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 October 2nd 03 03:07 AM
