Bonded aluminum aircraft structures
Old December 23rd 03, 07:55 PM
asennad
Default Bonded aluminum aircraft structures
I remember seeing an article several years ago on a car company
developing a racecar using a bonded aluminum structure and rivet
reinforcing. It struck me at the time that this would make an improved
method of aircraft construction and I was wondering if this had been
used before on homebuilt aircraft and what might be the pitfalls of
such a system.
My thinking is that the aircraft's aluminum skins could be attached
over a wooden buck and adhesive used to attach the skins. Once the
adhesive has setup, the bulkheads could be installed, holes drilled
and rivets set. The rivets would still from the primary means of
fastening the panels and the adhesive could serve as extra
reinforcement.
I suggest this as I suspect it would make for a quicker way of
construction particularly as the buck could be reused for subsequent
aircraft.
Old December 23rd 03, 08:19 PM
Ron Natalie
"asennad" wrote in message om...
aircraft.
There are some use of aluminum adhesives in light aircraft. The Grumman
Tiger for example uses it on some of the parts.
Old December 23rd 03, 08:41 PM
Steve Robertson
The Grumman single engine line and the Beechcraft Musketeer line both used
bonded aluminum wing skins. It's been done successfully.
Best regards,
Steve Robertson
N4732J 1967 Beechcraft A23-24 Musketeer
such a system.
reinforcement.
aircraft.
Old December 24th 03, 01:25 AM
Morgans
m...
om...
aircraft.
There is one thing that everyone is not mentioning, while talking of bonding
aluminum. The process (that I know no more about than what has been
mentioned here, in the past) is very tricky, from a prep standpoint, and
quality control. It has been said that homebuilders lack the facilities and
experience to reliably complete the process.
Jim in NC
Old December 24th 03, 03:15 AM
This has been done with various degrees of success in sailplanes since the
late 1960s. Here are a few links that you might consider looking at:
http://www.soaridaho.com/Schreder/Sc...the_HP-18.html
http://www.soaridaho.com/Schreder/Co...all.html#wings
http://www.soaridaho.com/Schreder/Co...all_10-80.html
Schreder used bonded wings on the following models:
HP-16 - http://www.soaridaho.com/Schreder/HP...rst_Flight.htm
RS-15 - http://www.soaridaho.com/Schreder/RS-15/C-GPUB.html
HP-18 - http://www.soaridaho.com/Schreder/HP-18/N15DP/N15DP.htm
http://www.soaridaho.com/Schreder/St...03_Seniors.htm
I hope you find these links helpful in your quest for the optimum
construction technique.
P.S. I use to own an HP-16T
(http://www.soaridaho.com/Schreder/HP-16/N16VP.html) and didn't have any
problems with the bonded wings.
om...
such a system.
reinforcement.
aircraft.
Old December 24th 03, 04:42 PM
Scott Correa
om...
reinforcement.
You don't understand the process. Follow me
for a minute. If the rivets are stronger than the
adhesive, the adhesive only adds weight to the
structure. If the adhesive is stronger
(it is by the way) then the rivets serve no purpose
...... So why are they there????? Because the
rivets hold the structure in place while the adhesive
cures. Holes and fasteners are the cheapest
tooling you can use when gluing structure together.
Older alum race car tubs got glued together and
used pop rivets to hold it together while it cured.
The bond lines can only accept shear loads, not peel
loads so attachment of secondary structures to
the tub was usually mechanical fasteners. We
glued tubs together not because it was strongest,
but because it was the fastest way to get it done
and meet our design goals. Bonded aircraft are a
similar story. Its economics vs performance.
Somewhere there is a bean counter that has a curve that
shows the most economical way to get it done.
Scott
Old December 31st 03, 08:26 AM
asennad
I want to thank everybody who responded to my post. Great info for me
to think about. My main goal is to think about building a metal
aircraft in a shorter amount of time without going to full CNC.
Old December 31st 03, 03:58 PM
Ron Natalie
What makes you think it's going to be shorter? Something's got to hold
the thing in place while the glue dries. Your one off jigs might take you longer
than if you'd drilled some holes and cleco'd riveted things together. Perhaps
you can get by with glue and a smaller number of rivets.
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 1 January 2nd 04 10:02 PM
German OMF Aircraft Declares Bankruptcy Fitzair4 Home Built 3 December 11th 03 12:13 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 October 2nd 03 04:07 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 4 August 7th 03 06:12 AM
Homebuilt Aircraft Frequently-Asked Questions (FAQ) Ron Wanttaja Home Built 0 July 4th 03 05:50 PM
