Go Back   Home » AviationBanter forum » rec.aviation newsgroups » General Aviation
Destruction due to turbulence when below Va - how?
Old July 21st 04, 04:27 PM
Roger Long
Default Destruction due to turbulence when below Va - how?
It's not complete protection, it just loads the odds a bit more in your
favor.
The aircraft is as likely to be broken by a panicked response by the pilot
or a botched attempt to recover from an unusual attitude and being at Va
will reduce that probability significantly.
Roger Long
"Peter" wrote in message
I think I understand the reasoning behind Va, the max maneuvering
speed, being that the wing will stall (and thus dispose of the
loading) before it breaks. This is why Va falls as the weight falls,
because at any given IAS a higher weight takes the aircraft closer to
stall already.
So, how is it possible to have aircraft destruction due to weather,
e.g. flying into a strong updraught in a CB, if flying below Va?
A DOWNdraught would do it more easily because most aircraft designs
have a lower design limit for negative G.
Peter.
Return address is invalid to help stop junk mail.
E-mail replies to but remove the X and the Y.
Please do NOT copy usenet posts to email - it is NOT necessary.
Old July 21st 04, 06:08 PM
john smith
stall already.
Find a copy of "FLYING THE BEECH BONANZA", by John C Eckalbar.
There is a section in the book expressly dealing with this topic.
Old July 21st 04, 06:12 PM
Icebound
stall already.
Flying into an updraught (updraft) in a CB can cause destruction for other
reasons that just the consideration of Va.
The windshear may put the aircraft into an unusual attitude from which
recovery may be impossible before, say, Vne is exceeded.
Old July 21st 04, 06:41 PM
Mike Rapoport
Turbulence is gusts which change the airspeed. I recall reading one account
of a thunderstorm accident where the plane encountered a 80kt vertical gust.
In the Sierra Wave Project loads of +16G and -20G were encountered in a
rotor cloud at below Va..
I think it should be understood that these are extreme examples i.e. flying
into the worst part of the worst thunderstorm at the worst time. A one in a
million event. The usual breakup story is loss of control followed by an
overspeed were the pilot pulls the wings off in the recovery.
Mike
MU-2
stall already.
Peter.
Old July 21st 04, 06:47 PM
Mike Rapoport
The design limit is not really lower for negative G. Remember that you are
starting at +1G so, if the limits are +3.8G and -1.8G, the limits are both
2.0g away from steady state flight.
Mike
MU-2
stall already.
Peter.
Old July 21st 04, 07:15 PM
William W. Plummer
Mike
MU-2
stall already.
Peter.
Is it the tail or the wings that get snapped off. Hauling back on the
yoke loads up the elevator. The wings are near the center of gravity so
they don't get stressed as much.
Old July 21st 04, 08:08 PM
john smith
Mike has the idea. You need to look at a V-g/V-n diagram for your
aircraft to see where the load limits lie for a given airspeed. This is
how Eckalbar explains it.
Old July 21st 04, 08:10 PM
Tony Cox
stall already.
There was a long thread in January, "Va and turbulent air
penetration speed" which you ought to be able to find
on Google.
The short answer is that flying below Va (even at max
weight) doesn't guarantee that the wing will stall before
exceeding the load factor. Va is defined in terms of
what control surfaces can handle, not when the wings
will fall off; see for example FAR 23.423 and 23.335.
Old July 21st 04, 08:13 PM
Orval Fairbairn
In article MwxLc.67$eM2.51@attbi_s51,
Mike
MU-2
stall already.
Peter.
Sometimes it is aircraft components -- engine mounts, baggage
compartments, etc. that fail.
Old July 22nd 04, 02:33 AM
Mike Rapoport
"William W. Plummer" wrote in message
news:MwxLc.67$eM2.51@attbi_s51...
account
gust.
flying
in a
an
Mike
MU-2
stall already.
Peter.
Y.
I guess I don't understand what you are trying to say. If you pull back on
the yoke, the wing supports the weight of the airplane plus the load on the
tail multiplied by the load factor.
Mike
MU-2
Weapons of Mass Destruction running with scissors Instrument Flight Rules 23 April 24th 04 03:00 PM
My First Time In Severe Turbulence (Long) David B. Cole Instrument Flight Rules 6 March 10th 04 11:21 PM
Budgets of Mass Destruction B2431 Military Aviation 4 February 4th 04 05:38 AM
please stop bashing France Grantland Military Aviation 233 October 29th 03 02:23 AM
How much turbulence is too much? Marty Ross Instrument Flight Rules 8 August 21st 03 06:30 PM
