300hp engine choices?
Old August 12th 03, 12:58 AM
ivo welch
Default 300hp engine choices?
hi: ok, it looks like I will need an engine in the 300hp range that
is certified. I really dislike the old and noisy lycomings and
continentals. the bombardier looks like a ways away. are there any
other reasonably good certificated choices?
/iaw
Old August 12th 03, 04:48 PM
Montblack
(Cory wrote)
Your requirements are pretty much mutually exclusive. Perhaps the
SMA diesel, although I think it's only 250 hp... You also need to qualify
"certified" for what?
I'll certify you a small-block Chevy 300hp if you want. Anybody
got a pen?
Talking with SMA at Oshkosh, found out their "diesels" are currently only
certified for Jet-A.
Thielert can run regular diesel fuel in their 135 HP 1.7 liter model - don't
know where they are with a 300 hp engine.
Montblack
Old August 12th 03, 05:14 PM
JerryK
"Diesel" is used as a technology, not the fuel. As I understand it, Jet A
is more readily available at European airports than 100LL.
"Montblack" wrote in message
(Cory wrote)
qualify
got a pen?
don't
Montblack
Old August 12th 03, 05:41 PM
JerryK wrote:
: "Diesel" is used as a technology, not the fuel. As I understand it, Jet A
: is more readily available at European airports than 100LL.
True enough. Trouble is, most people look at you funny when you
say "compression ignition engine," but a "diesel" engine that you run
Jet-A in makes perfect sense.
FWIW
-Cory
* The prime directive of Linux: *
* - learn what you don't know, *
* - teach what you do. *
* (Just my 20 USm$) *
Proposals for air breathing hypersonic craft. I Robert Clark Military Aviation 2 May 26th 04 07:42 PM
Car engine FAA certified for airplane use Cy Galley Home Built 10 February 6th 04 04:03 PM
What if the germans... Charles Gray Military Aviation 119 January 27th 04 12:20 AM
Objective Engine Discussion Rick Maddy Home Built 26 October 14th 03 05:46 AM
Corky's engine choice Corky Scott Home Built 39 August 8th 03 05:29 AM
