new tire
Old September 24th 03, 05:17 AM
Newps
Hankal wrote:
What is the easiest way to brake the bead on a 600x6 tire.
Set it on the ground and carefully drive over the tire with your truck.
Old September 24th 03, 05:31 PM
Ron Natalie
"Newps" wrote in message news:718cb.420597$cF.130455@rwcrnsc53...
Sawzall?
Old September 25th 03, 01:17 AM
Newps
Naw, then you'd hit the rim of the wheel before you got to the bead.
Sawzall?
Old September 25th 03, 04:36 AM
Orval Fairbairn
In article wCpcb.426406$cF.132176@rwcrnsc53,
Sawzall?
I have always had good luck fully deflating the tire (valve stem
removed); placing the wheel/tire on a small board (to help prevent
scratching the rim), then standing on the tire, with one foot on one
side and the other on the other, then doing a sort of dance around the
tire. This process usually breaks the bead free in less than a minute.
Turn the wheel over and repeat for the opposite side. Usually, when one
side is free, the other follows even more quickly.
Am alternative is to build a bead breaker out of scrap material. A
simplified diagram follows:
o----------------o----------------- (Handle)
| __________||__
| ( Tire )
___________________________________
Old September 25th 03, 05:04 AM
Newps
I have only had to drive on a tire once. Every other time I can simply
take the nuts and bolts out of the wheel and pull the two halves apart.
Sawzall?
| __________||__
| ( Tire )
Old September 25th 03, 01:32 PM
Jay Masino
Years ago, I bought one of these inexpensive tire bead breakers from
Harbor Freight. I think it was like $25-30, and is meant for lawn tractor
tires or something. It's one of the best tools I ever invested in. It
holds down the tire, and has a little arm that prys the tire off the bead.
-- Jay
__!__
Jay and Teresa Masino ___(_)___
http://www2.ari.net/jmasino/ ! ! !
Checkout http://www.oc-adolfos.com/
for the best Italian food in Ocean City, MD and...
Checkout http://www.brolow.com/ for authentic Blues music on Delmarva
Old September 27th 03, 02:38 AM
Guy
I would have to say take it into the shop
*** Sent via http://www.automationtools.com ***
Add a newsgroup interface to your website today.
Tire Changer Juan Jimenez Aviation Marketplace 0 August 19th 04 03:58 AM
Tire inflation pressure Paul Lee Home Built 80 November 19th 03 08:56 AM
Nosewheel Shimmy and Scalloped Tire Redux, Plus Larry Smith Home Built 2 September 15th 03 05:03 PM
Scalloped Nosewheel Tire Larry Smith Home Built 7 September 12th 03 10:16 PM
Tire talc...baby powder? No Spam Owning 12 August 8th 03 06:03 PM
