Power port in panel?
Old October 5th 03, 07:17 PM
df
Kyler Laird wrote:
"Jay Honeck" writes:
What the heck is an "XLR connector"?
http://froogle.google.com/froogle?q=XLR+jack
An advantage to XLR is that you can find them at Radio Shack. Having
three pins (plus ground) gives you the option of being creative; add a
power line that isn't switched by the master, or run an audio input to
your intercom, for example.
--kyleer
I've used Morotola style plugs in various aircraft I've owned. The panel
side would be the female with the center conductor being B+.
Nice and small, just add a fuse and your done.
Old October 5th 03, 10:37 PM
Paul Sengupta
"Jay Honeck" wrote in message
news:N5Vfb.43971$%h1.28461@sccrnsc02...
Got an XLR connector put in my panel that I run my GPS off (28V
electrics).
Paul
(Hi guys, just popped in briefly!)
Hey -- where you been? We were just talking about you (behind your
monitor, of course... .
Hi Jay (et al)...sorry I've been a bit busy! Work and all that, no time.
Also been nice flying weather
here this summer! :-)
An XLR connector is normally used for professional audio, microphones and
things. They will handle
enough current for aircraft accessories. The advantages are low cost and
easy availability, and as
per your requirements, they lock. Usual is 3 pins (I only use 2 of them) but
you can get more if
you so desire.
Paul
Old October 6th 03, 12:34 AM
Jim Weir
The DISadvantage is that the rascals are HUGE compared to a decent aircraft
sized connector.
-An XLR connector is normally used for professional audio, microphones and
-things. They will handle
-enough current for aircraft accessories. The advantages are low cost and
-easy availability, and as
-per your requirements, they lock.
http://www.rst-engr.com
Old October 6th 03, 08:29 AM
Paul Mennen
decent aircraft sized connector.
I agree that the XLR connectors are bigger than necessary.
I've used a Coaxial DC Power Jack from Radio Shack (274-1576)
for in the panel and Coaxial DC Power Plug (274-1573) for
anything that plugs into it. (Each part cost $2.49). I wired
it to the Vbat bus thru an in-line fuse (also avail. from Radio Shack).
I have a little 12V lamp I sometimes plug in there for illuminating
under the panel when I'm trying to work under there. I also have
one of those car battery solar chargers - which I cut off the cigar
plug connection in favor of the DC power plug. (I usually have
a carbon monoxide detector plugged into my cigar lighter.)
I've also found this plug to be handy to power various gadgets
on occasion. (You never know when a little 12 volts comes in handy
Is this legal? Probably not. Ask me if I care.
By the way, don't make the mistake of using a phono jack/plug.
The problem is that the act of inserting the plug usually shorts
it out momentarily. Not long, but long enough to blow your fuse.
~Paul Mennen
Old October 6th 03, 02:48 PM
Dave Stadt
"Paul Mennen" wrote in message
m...
~Paul Mennen
Switchcraft makes a very high quality industrial version of the coaxial
power plugs and jacks. They have a set that locks so you can mount them
vertical if you want. Cost is reasonable and you can get them from any of
the large electronic supply houses. Once you see these the Rat Shack ones
will scare you.
Old October 6th 03, 03:50 PM
James M. Knox
"Paul Mennen" wrote in news:%Y7gb.7840$Fy3.5498
@newssvr29.news.prodigy.com:
I have the same thing in my plane (and yes, legal... all signed off G).
But I am going to swap them out one of these days. Believe it or not,
folks DO try to plug a headset into them. Doesn't work (doesn't even begin
to go in, since there is a center pin), and does manage to short out the
power (which just pops the fuse). But annoying. Next time I am going for
either something with a cover or something with completely recessed pins.
James M. Knox
TriSoft ph 512-385-0316
1109-A Shady Lane fax 512-366-4331
Austin, Tx 78721
Old October 6th 03, 04:12 PM
Kyler Laird
"Paul Mennen" writes:
it out momentarily.
I'd enjoy seeing you try to short a phono jack/plug. I'm guessing
that you mean a 1/8" or 1/4" phone jack/plug (where there are
multiple conducting segments on the center pin).
--kyler
Old October 8th 03, 08:08 AM
Paul Mennen
Perhaps I used the wrong terminology. Probably the RCA style phono
plugs and jacks would have worked. Once I used a typical 3 conductor
1/8" audio plug/jack combination and it didn't work. Shorted out nearly
every time.
~Paul
"Kyler Laird" wrote in message
it out momentarily.
--kyler
Old October 8th 03, 03:12 PM
Kyler Laird
I was surprised to see that my old DME uses an RCA jack for power (as I
recall).
every time.
Yeah, that makes sense. If you had used the "ring" as the ground and
the "tip" as the supply (leaving the other tip segment(s) unused) you
shouldn't have this problem, but if you put both the supply and ground
on tip segments or use the segment nearest the ring, you're in for
trouble. It's still not a great connector for power though.
I'm really warming to the idea of using XLR connectors. They're hardly
bigger than standard cigarette lighters and they're so readily
available.
--kyler
Funny story about naval [email protected] Naval Aviation 0 December 20th 04 04:37 AM
Diamond DA-40 with G-1000 pirep C J Campbell Instrument Flight Rules 117 July 22nd 04 06:40 PM
Air Force Academy Review Panel Releases Report Otis Willie Military Aviation 0 September 19th 03 04:45 AM
Air Force Museum forms review panel Otis Willie Military Aviation 2 August 29th 03 05:41 PM
Aircraft engine certification FAR's Corky Scott Home Built 4 July 25th 03 07:46 PM
