Preheater
Old November 7th 03, 03:44 AM
G.R. Patterson III
Jay Honeck wrote:
That's sad, George. You really must move back to America soon, where we
don't lock the doors at night...
Three more years, if all goes as planned. Then Carolina here we come.
George Patterson
If you're not part of the solution, you can make a lot of money prolonging
the problem.
  #52
Old November 9th 03, 06:43 AM
Tony Roberts
Thanks very much for all of your replies.
They have given me food for thought and are very much appreciated.
Tony Roberts )
PP-ASEL
VFR-OTT - Night
Cessna 172H
  #53
Old November 9th 03, 03:21 PM
JFLEISC
There is, of course, the 'build it yourself' $50 propane preheater on page 84
of the October 2001 Kitplanes magazine. No batteries required. I use two of
them on my Cessna 172 and they do a pretty good job. Both fit into a small
flight bag.
  #54
Old November 10th 03, 09:48 PM
Steven P. McNicoll
"Ray Andraka" wrote in message
I have the Reiff cylinder heaters and oil sump heater. Mine are for the
narrow deck engine, so each cylinder heater is 50W. I think the sump
heater is 300W, so for my Six, a generator capable of at least 600W
should work fine. I think most of the portable generators are good for
about 1000W.
I purchased a Hot Padd heater from Reiff. The heater could not be mounted
on my engine in accordance with the supplied instructions, so I made do as
best I could. The adhesive didn't cure and the pad easily peeled off. I
returned the pad to Reiff for a refund, they sent it back to me with more
adhesive. Apparently I violated the warranty by not following the
instructions to the letter, (the fact that it was impossible to follow them
was of no interest to Reiff). I don't know if the Reiff heater is any good
or not, I do know that their product support and customer relations are
terrible. I won't do business with them again.
I purchased a "milkhouse heater" and some ductwork at a local home
improvement store. The cost was about $35 and it does a fine job.
  #55
Old November 10th 03, 09:50 PM
Steven P. McNicoll
"Victor J. Osborne, Jr." wrote in message
I've had Tanis in two planes and now have the Reiff product. The Reiff
was easier to install, doesn't mess w/ the CHT probes and is owner
installable
w/ an A&P signoff.
Everything is owner-installable with an A&P signoff.
  #56
Old November 23rd 03, 07:26 PM
hlongworth
Kyler Laird wrote
I second the generator idea. Electric heaters are *so* handy. You can
even put some in your cabin to keep your seat and instruments warm. If
you run the generator off of 100LL, you won't have to mess with carrying
(other) tanks of fuel.
Small generators often have 12VDC
outputs
http://www.mayberrys.com/honda/gener...ls/eu1000i.htm
so if your plane has a 12V system, you're all set.
Kyler,
What heater system do you power with the Honda generator? We are
deciding on what type of electric heater to put on our new Lycoming
engine which will work with a portable generator:
1. Tanis: ~$400-$600 (250w -500w) - cylinder/oil pan heaters
http://www.tanair.com/heatersystems.html
2. Reiff: ~$350 (4cylindersx50w= 200w + 100w oil sump = 300w) -
http://www.reiffpreheat.com/faaelig.htm#price
3. E-Z heat: $160 (300w or less)- oil pan heater
http://www.e-zheat.com/index.htm
4. Safe-Heet $130 (300w) - oil pan heater
http://www.aircraftsupply.com/categories.asp?cID=133
5. ProHeat pad - Model 512 $55 (250w) - oil pan heater (not specified
for aircraft but should work the same)
http://www.engineheaters.com/
We are leaning towards the Tanis/Reiff type system (for more
complete heating) but not sure whether they can be powered with a
portable generator such as the Honda EU100i or the equivalent Yamaha
EF1000iS (
http://www.usalight.com/yamaha/ef1000is.htm)
Thanks.
  #59
Old November 25th 03, 03:31 AM
Mike Rapoport
The people at Tanis are working on a generator that you might want to
research. Their primary objective is power to weight. I have thought about
a Honda generator for preheating in remote areas but I would need the 2K
version which is a lot heavier than the 1K.
Mike
MU-2
"hlongworth" wrote in message
m...
Kyler Laird wrote in message
(hlongworth) writes:
Sorry if I mislead you. I *don't* use a Honda generator with my
heaters. I do have a (big clunky) generator, and I do have Reiff
cylinder bands and oil heaters though.
We will most likely order the Reiff system but will go for the Turbo
version (4x50watts + 200watts = 400watts). The two main lightweight
portable 1Kw generators are Honda and Yamaha. Unless I find something
negative on the Reiff system and these generators, these combo seems
to be the best choice. Thanks.
  #60
Old November 25th 03, 04:48 AM
Steven P. McNicoll
m...
Lycoming intake preheater Dale Larsen Home Built 5 June 6th 04 11:32 PM
