Anyone know how to update an old Loran database?
Old November 29th 03, 05:12 AM
Tom Jackson
Default Anyone know how to update an old Loran database?
I have looked around on the 'net, and cannot find any reference to being
able to update an old Apollo loran database (like can be done with the
modern GPS units.)
I have an Apollo 604, with the latest update (1999, I think.)
It seems to me, that there must be some tech-wizards out there who could
figure out how to update such an animal -- i.e., there are a number of
places to get the "data" (FAA, DAFIF, etc.) - is there a way to configure it
in a file on a PC, then through some sort of interface upload it to the
"Flybrary"?
I think the Flybrary is probably some sort of EPROM (eraseable, programmable
read-only memory) that should be capable of being updated, if one understood
the protocol, data formats, physical connections, etc.
On the surface, this sounds doable - is it merely a pipe-dream?
At least, it could be a fun project for someone over these fine winter
months!
Old November 29th 03, 05:41 AM
Ben Sego
"Flybrary"?
snip
months!
It's certainly possible, and it would be an interesting project. It
would have to be done for the project interest. Do you happen to have a
spare one lying about?
B.S.
Old November 29th 03, 08:17 AM
Ben Jackson
In article W0Vxb.249031$9E1.1347467@attbi_s52,
Does your 604 lock on? I'm in the Pacific Northwest (GRI 9940?) and
bought a plane with a 604. It doesn't seem to acquire more than one
station (only one letter will capitalize).
I've just left it turned off but I can't tell if it's due to an old
database or bad antenna or what.
Ben Jackson
http://www.ben.com/
Old November 29th 03, 03:34 PM
Tom Jackson
My 604 works great. Just has old data.
"Ben Jackson" wrote in message
news:NJXxb.344043$HS4.2929329@attbi_s01...
Ben Jackson
http://www.ben.com/
Old November 29th 03, 04:29 PM
Paul Tomblin
The best "update" on a panel mount Loran is to rip it out and give youself
another 2 or so pounds of useful load.
Paul Tomblin http://xcski.com/blogs/pt/
Using vi is kind of like having sex. The first time to use it, it's kind
of awkward, but after using for a while you start to get good at it and
enjoy it. -- Eric Merkel
Old November 29th 03, 07:10 PM
Tom Jackson
What is wrong with a perfectly good piece of equipment, that religiously
scans through a series of pages, and continuously updates me on my course,
ground speed, distance to waypoint, ETE, etc.? As long as the system is
still up and running, I believe it is well worth the 2 pounds of useful
load - at least as a back-up to all of the other forms of navigation that I
use (VOR, handheld GPS, pilotage, etc.)
"Paul Tomblin" wrote in message
Old November 29th 03, 07:22 PM
G.R. Patterson III
LORANs work just fine with old databases. Many of them have an internal battery,
however, and when this goes dead, they don't work.
George Patterson
Some people think they hear a call to the priesthood when what they really
hear is a tiny voice whispering "It's indoor work with no heavy lifting".
Old November 29th 03, 07:29 PM
G.R. Patterson III
Maybe you should take a look at the thread entitled "GPS Degradation in ZDC/ZNY
areas". My LORAN is old, but it has two real good things going for it - it works
well, and it's paid for.
George Patterson
Old November 29th 03, 07:52 PM
I have both a II Morrow 618 Loran and a Garmin GPS in my aircraft.
The user interface on the Loran is MUCH MUCH easer to use than the
newer Garmin GPS. The Garmin interface is NOT intuitive and takes at
least twice as long to enter a go to point on the Garmin as it does on
the II Morrow loran. The GPS and the Loran always agree within less
than 1/2 mile so why get rid of a good navigation unit?
On Sat, 29 Nov 2003 15:29:24 +0000 (UTC), (Paul
Old November 29th 03, 08:54 PM
Jerry Springer
George Patterson
That is true, my Flybuddy quit working and I called Applo/Garmin/UPS to see how
much it would be to fix it and they said $250.00 just to look at it and replace
the batteries. I opened it up myself and found the internal batteries. (there
are two in the Flybuddy) I got the numbers of the batteries and then went on the
internet and found the same batteries for about $8.00. It was a very simple
matter to un-solder the old batteries and solder in the new batteries. Now my
Flybuddy GPS works as good as it did new.
Jerry
Database update at Landings Dr. Guenther Eichhorn Aviation Marketplace 0 May 11th 04 11:25 PM
Database update at Landings Dr. Guenther Eichhorn General Aviation 0 May 11th 04 11:25 PM
Anyone know how to update an old Loran database? Tom Jackson Home Built 8 December 3rd 03 03:15 AM
Garmin GPS-90 moving map Aviation GPS with latest Jeppessen database update installed Jerry Bransford Aviation Marketplace 5 October 2nd 03 04:31 AM
Database update for Foster LRN-500 loran? Ray Andraka Owning 4 September 3rd 03 07:08 PM
